Bad info high in Google results
Old 12-22-23, 09:54 AM
  #101
kcjc
Quoted: 90 Post(s)
Liked 47 Times in 34 Posts
Originally Posted by cyccommute
Friction shifters have more of a place than seat posts or headsets as part of a “group”.
For a "group," possibly. L'Eroica would agree, but I don't believe that's your gist. For a "groupset", it comes and goes which was the point. They are two different words with different meanings.
A crankset does include the bottom bracket. Without a bottom bracket, the crank is just a fairly boring wall hanging.
If the manufacturers, sellers, and cycling heritage don't agree, does that make you right?
Finally, the OP and yourself seem to say that Bike Gremlin should do better. Why don’t you do “better” by starting your own website. I’m sure you and the OP could bang one out in a day or two…considering his encyclopedic knowledge. Quite complaining unless you are going to do something about it.
In case you missed it, it was about sharing bad or incorrect information. One can already access definitive sources, so we don't need to do so. One is Sheldon Brown's Bicycle Technical Info, and the other is Park Tool.
kcjc is offline
Old 12-22-23, 10:59 AM
  #102
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6221 Post(s)
Liked 4,221 Times in 2,367 Posts
“Group” and “groupset” have been used interchangeably for the entirety of the time I’ve been riding bikes seriously. That’s from the late 70s onward. Some companies have provided all of the components for making a frame functional, including headset, seat post, and even stem. Others have provided only the drivetrain. Still others have provided various combinations. The definition has also changed over time.
Again, it varies. This groupset from State Bicycle includes the bottom bracket. Shimano for a time sold external bottom brackets with the crank. They didn’t usually sell a bottom bracket with an internal bearing crankset because the length of the spindle varied with the needs of the frame.
You, however, are missing the point. Bike Gremlin (and myself) was saying that the bottom bracket is an integral part of the crankset. Not from the standpoint of that the bottom bracket is, or should be, sold with the crank arms but from the stand point of the bottom bracket is necessary for the crankset to used on a bicycle.
​​​​​​​In case you missed it, it was about sharing bad or incorrect information. One can already access definitive sources, so we don't need to do so. One is Sheldon Brown's Bicycle Technical Info, and the other is Park Tool.
No, I didn’t miss your point. I’m saying that you and others are making mountains out of molehills. Sheldon Browns page isn’t perfect. There’s lots there to disagree with. The point is “disagreement” not that the information is bad or incorrect. The same applies to Bike Gremlin’s page. It isn’t perfect but it exists and it’s not as horrible as the OP makes it out to be. Were 6 speed cassettes made? Yes. Are they made any more? No. Are 6 and 7 speed cogs and/or spacers the same width? No. Are they damned close? I’d say 0.05mm isn’t enough to quibble about.
Again, if you can do better, do so! My career was in chemistry. If I used an old method that didn’t give reliable results, I didn’t complain to the method developer that the method should be better. Often that would be impossible because the original method was developed decades earlier. I improved it by developing a better method. If the developer of the method was still around, I’d work with them on making the method better.
Same idea applies here. Either develop a better method or work with the developer to make the product better.
Stuart Black
cyccommute is offline
Likes For cyccommute:
Old 12-22-23, 11:07 AM
  #103
smd4
Quoted: 3514 Post(s)
Liked 2,927 Times in 1,776 Posts
Some even with a chain.
smd4 is offline
Old 12-22-23, 11:15 AM
  #104
base2
I am potato.
base2's Avatar
Quoted: 1790 Post(s)
Liked 1,631 Times in 934 Posts
Am I alone in thinking that Kontact could/should be a staff writer for Bike Gremlin to really get into the situation and use his encyclopedic knowledge to correct it?
Actually doing something to help seems like a win/win.
Car dependency is a tax.
base2 is offline
Likes For base2:
Old 12-22-23, 11:22 AM
  #105
smd4
He's too good for that.
smd4 is offline
Likes For smd4:
Old 12-22-23, 11:28 AM
  #106
kcjc
Quoted: 90 Post(s)
You forgot the "o" as in "groupo".
The word is called "drivetrain".
Nice use of whataboutism. If you were to rename the elements, I'm positive you would be laughed out of the room.
kcjc is offline
Old 12-22-23, 11:43 AM
  #107
Bike Gremlin
Mostly harmless ™
Bike Gremlin's Avatar
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times in 130 Posts
Jokes aside, for anyone interested, this is the BikeGremlin guest-posting policy.
Relja
Bike Gremlin is offline
Likes For Bike Gremlin:
Old 12-22-23, 12:15 PM
  #108
icemilkcoffee
icemilkcoffee's Avatar
Quoted: 1562 Post(s)
Liked 1,734 Times in 974 Posts
Snark aside, the honest truth is that BikeGremlin is a master at web design and search engine optimization. The best thing for him to do, is to handle the web design for the Sheldon Brown website. Right now John Allen is doing a good job with the content, but the website is maddenly and frustratingly hard to navigate. There is no need to duplicate Sheldon/John Allen's info. It just needs to be organized better.
icemilkcoffee is offline
Likes For icemilkcoffee:
Old 12-22-23, 12:35 PM
  #109
Bike Gremlin
Mostly harmless ™
I've already exchanged a few emails with the good people keeping that site alive (and still keeping it up-to-date as far as I know).
Found it - it's a bit funny, but nice, I think - sent this in 2019:
Hello,
My name is Relja Novović, from Serbia. I contacted Mr John Allen via Facebook and they recommended to email you with this, so here it is:
I think that Sheldon Brown website and should be preserved for future generation as a treasure of information (and more).
Thank you for keeping it running - it is very much appreciated (by most of the cycling community for all I know).
While I'm writing this, I'm hoping it is a waste of time and you have it all covered, but just in case:
if you need any help with website backups, hosting, security, or any other technical aspects, I'd be happy to help, whatever I can, in my own free time.
Best regards,
Relja
With Tarzan English and all. LOL
Edit:
My site's design was done by my friend Maša.
I just implemented all that she said (colours, layout, she listed how every single detail should look, with hex. colour codes since I'm awful at visuals).
BIkeGremlin website redesign story
Old 12-23-23, 09:33 AM
  #110
TMonk
Not actually Tmonk
TMonk's Avatar
Bikes: road, track, mtb
Quoted: 2640 Post(s)
Liked 3,153 Times in 1,660 Posts
Originally Posted by Homebrew01
Ok everyone, let's stay on topic.
bump
"Your beauty is an aeroplane;
TMonk is offline
Likes For TMonk:
Old 12-23-23, 10:06 AM
  #111
Chuck M
Happy With My Bikes
Chuck M's Avatar
Quoted: 884 Post(s)
Liked 2,308 Times in 1,118 Posts
Originally Posted by Kontact
Now you can say that I'm being unfair, but I have to tell you that I am also a walking encyclopedia of bike mechanic stuff -
Before this gets locked, I wasn't around here when Sheldon Brown was posting but I'd wager he didn't call himself an encyclopedia and he would not have entertained this argument that someone else's site should be shut down on his authority. There are (IMHO) some encyclopedic posters here mostly in the C&V forum that would not call themselves encyclopedias either. I think more people would agree that you should ask the mods to close this thread than those thinking this other guy should take down his site.
Chuck M is offline
Likes For Chuck M:
Old 12-23-23, 10:29 AM
  #112
Kontact
Kontact's Avatar
Quoted: 4412 Post(s)
Liked 1,567 Times in 1,029 Posts
Quote me where I said he should take down his website.
Kontact is offline
Old 12-23-23, 11:07 AM
  #113
Chuck M
Happy With My Bikes
Chuck M's Avatar
Quoted: 884 Post(s)
To be fair, it was the fellow you started this thread about that suggested you asked for it to be taken down. And your attitude has suggested that he didn’t make that up.
Chuck M is offline
Likes For Chuck M:
Old 12-23-23, 11:24 AM
  #114
Kontact
Kontact's Avatar
So I complain that someone posts a lot of misinformation, and then you quote that guy as evidence against me?
Kontact is offline
Old 12-23-23, 11:25 AM
  #115
smd4
So you admit that you’re doing nothing but complaining?
smd4 is offline
Old 12-23-23, 11:29 AM
  #116
Chuck M
Happy With My Bikes
Chuck M's Avatar
Quoted: 884 Post(s)
lol. I think your mom could tell you that you are her favorite and you would argue with her.
Chuck M is offline
Likes For Chuck M:
Old 12-23-23, 11:32 AM
  #117
Kontact
Kontact's Avatar
Lol, I think you're up to the same baloney as BikeGremlin. To be fair.
Quote me or don't comment about me.
Kontact is offline
Old 12-23-23, 11:33 AM
  #118
smd4
He’s spot-on. To be fair.
smd4 is offline
Old 12-23-23, 11:54 AM
  #119
TMonk
Not actually Tmonk
TMonk's Avatar
closing for review. there may be more bickering than useful content in this thread.
TMonk is offline
