About to straighten out my derailleur hanger. Any advice?
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
I've done it with my Ti Merlin hangar. Not that big a deal. As mentioned do small things, test and continue. Don't go for a homerun on the first attempt.
Likes For Sy Reene:
Quoted: 2488 Post(s)
Liked 2,957 Times
How did the bending operation turn out?
ignominious poltroon
Quoted: 2242 Post(s)
Liked 3,443 Times
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,000 Times
Frames with integral hangers aren't set up to accept replacement hangers. Of course, if there's enough meat there, a skilled mechanic can modify it to mount a replaceable hanger, but I'm talking about an advanced skill level. I wouldn't expect that in someone asking if straightening us OK.
This is totally unnecessary unless the wheel is badly untrue. On a true wheel, every point is on the same plane, square to the axle.
I love various raw veggies in tempura. My favorite is thick cut onion slabs, ie. 10mm or so, fried until just tender. Sometimes, I'll salt the onion first, otherwise dip in a sauce to eat. The alcohol trick sounds interesting, I'll give it a shot.
Onions as tempura is delicious love it. The alcohol works quite well.
Quoted: 5793 Post(s)
Liked 2,585 Times
Doubtless, one would want to avoid using a badly untrue wheel as a reference. However any rideable wheel -- passes through brake shoes without rubbing -- is true enough to align the RD to well within half a degree.
So, as a practical matter, one needn't obsess about indicating anywhere on the wheel.
Clark W. Griswold
Liked 4,000 Times
One of the first and most important lessons one learns as a manufacturer is how to set tolerances and avoid pointless (expensive) precision.
Likes For veganbikes:
Quoted: 242 Post(s)
Liked 455 Times
I'd start by getting it somewhere near straight using vise grips or a crescent wrench, so you can limit the major bending to the mid/upper part of the hanger; if it was a bare frame I'd use a bench vise. It looks like you might need to close the dropout a little too: in that case the bench vise would definitely be my preferred tool. Then finish it off with the alignment tool. Make sure you screw it in firmly, and that it lies flat against the hanger. Tweak a little bit, check against the wheel in three places, repeat as required.
If you don't have the proper rear derailleur hanger alignment tool then either buy one or bring it to a shop...or you certainly can just kludge it using a pair of vice grips, etc. as grumpus suggests and hope for the best...it's not my bike so I don't have a monkey in this circus...
Likes For Kai Winters:
Liked 2,585 Times
OTOH one of my self appointed roles on this forum is to be a counterweight offsetting the tendency to obsessively paint lilies.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Liked 2,585 Times
But, yes, a vice grip would be my absolutely last option. If you're not strong enough to move it with a hex key, consider that the wheel's axle has thr same thread.
Likes For FBinNY:
Quoted: 969 Post(s)
Liked 1,631 Times
GREAT! that changes everything.
Then after getting it as close as possible use the Park Tool...
Of course John, You know this...
Likes For zandoval:
Liked 2,585 Times
Why are people making a simple job complicated. There's no need to use a vise or do the job in 2 or more steps.
Steel's yield strength is a fixed property, so the same force is needed for this as to tweak the hanger on a newly built frame.
If the tool is strong enough for that (as it obviously is), then it's strong enough to horse this hanger home.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Two points.
First, the hanger straightening tool may work, but I've staightened a lot of stuff, and if I had my choice, I would pull the wheel off, lay the inboard side of the hanger on something flat, and push on the outboard side with a hydraulic press, it's a more foolproof way of doing things, you won't overshoot, and due to springback, if that doesn't flatten it, put appropriate spacer under the inboard end and press again.
Regarding the yield strength of steel staying constant, no it doesn't, not after cold working, and yielding is cold working. (For not a large bend, perhaps not too bad.) Take a steel paper clip and bend it, now try to straighten it, where you bent it will be harder to bend back to straighten, as it has been cold worked. Before alloy steels, cold working was how you made a strong sword or knife from low grade steel. That is why "piano wire", guitar strings, et al, have typical tensile strengths of 380,000-425,000 PSI (extremely high strength), from steel (iron with carefully controlled carbon content) with no alloys, no heat treatment, because of the cold working (via drawing the wire through a die). What DOES stay constant is the elastic stiffness of the steel, the Young's Modulus, that does not change within families of materials, even as yield and ultimate strength changes (with a few rare exceptions of newer exotic metal alloys).
Quoted: 242 Post(s)
Liked 455 Times
Doing emergency repairs in the field, I'd put a hex key into the RD mounting bolt and muscle it home by eye, adding the RD cage as my guide.
Rider. Wanderer. Creator.
Bikes: Bike Friday Pocket Rocket, Cinelli Hobootleg, Zizzo Liberte
Quoted: 394 Post(s)
Liked 782 Times
Which highway?
JohnMFlores.com | YouTube: JohnMFlores
Insta: JohnMichaelFlores | TikTok: @johnnymotoflores
Quoted: 503 Post(s)
Liked 436 Times
NOPE NOPE NOPETY NOPE ! ! !
Likes For grumpus:
Likes For grumpus:
Quoted: 1612 Post(s)
Liked 2,594 Times
Picked up the tool locally and it gets used all the time. I've moved some pretty tweaked ends. Don't think he is going to have a problem with that.
Likes For curbtender:
Thread derailleur
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 367 Post(s)
Liked 462 Times
He has the alignment tool. From the photos the hanger looks to have been pulled back and twisted in, which is more than I'd expect the tool to cope with, so I suggested getting it in something like the right orientation before setting it with the tool. There's no way the tool could manage to close the dropout, if that is indeed required. Even if it just needs pulling out, the tool is acting on the end of the hanger, but the main distortion appears to be at the top of the hanger - perhaps not a crucial difference, but it could end up S-shaped rather than flat.
Only difference for me might involve plunking a properly spaced hub in there to keep everything else stationary.
Hard to tell if the hanger distorts in other directions. Could present Mr Flores with more problems.
Quoted: 242 Post(s)
Liked 455 Times
A rear derailleur hanger alignment tool is designed to align a hanger in a variety of planes.
I've...carefully and slowly...re-aligned bent and twisted hangers bringing them back into the exact and correct position. Especially so on a steel hanger that is part of the frame/dropout. I prefer aligning steel hangers as steel is far more moveable and far more forgiving than an aluminum hanger especially some of the hangers I have to align that are so cut out...for no good reason...the metal is thin and far more prone to snapping than wonderful steel whose molecules love being manipulated.
I do not ever recommend using the incorrect tool unless absolutely necessary because using a tool such as 'vice grips' with all its lovely teeth is going to mar the metal, regardless of type, same with pliers, and even adjustable wrenches though and adjustable wrench is less likely but I also have to take into the consideration the person doing the 'manipulating'. In general they are clueless and cause far more harm and damage than if they just left it alone.
You want to learn how to do this stuff correctly and have the correct tools? Buy a used bike...cheap...doesn't matter what kind...and practice on it using YouTube videos as a guide. Or better yet hire a reputable shop mechanic to teach you basic service and maintenance skills during the winter months when customers are few and time is more available.
Quoted: 1944 Post(s)
Liked 2,164 Times
An alignment tool is the best way to go. That said the accuracy of bending a steel hanger back is "somewhat" dependent on the number of speeds you are running.
Some years ago I used a precision square in the dropouts and an 18" crescent wrench to straighten a bent hanger. I think the use of a precision square over a Harbor Freight square is the key, at least in one's own mind.
But I'm running an 8 speed cassette and the Centeron probably picks up enough of the visual out-of-tolerance.
If I were doing it today, I'd get an alignment tool. I have a lot more tools now than I used to have, and many only get occasional use. I somehow survived my ham fisted era.
John
John
Quoted: 503 Post(s)
Liked 436 Times
This. Kai went all nopity nope on you, when you merely suggested starting the fix with another tool.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
I don't know.
Quoted: 317 Post(s)
Liked 853 Times
I had a cx race bike that was mis-shifting recently (replaceable aluminum hanger on cf frame). I complained about it to my bud in the parking lot at a race. He took my bike and said, "I'll be right back". He came back three minutes later with it fixed. He had the tool in his car. So why is this thread still going?
Liked 2,594 Times
