What do old people ride, lets see your bikes
Old 04-03-24, 08:58 AM
  #3551
terrymorse
climber has-been
terrymorse's Avatar
Quoted: 3432 Post(s)
Liked 3,567 Times in 1,793 Posts
Originally Posted by pepperbelly
2013 Roubaix Comp
Can we talk about those handlebars?
Ride, Rest, Repeat. ROUVY: terrymorse
terrymorse is offline
Old 04-03-24, 09:06 AM
  #3552
pepperbelly
old newbie
Bikes: Specialized Roubaix
Quoted: 541 Post(s)
Liked 359 Times in 182 Posts
pepperbelly is offline
Old 04-03-24, 09:41 AM
  #3553
terrymorse
climber has-been
terrymorse's Avatar
That is an "extreme" bar position.
"extreme"
Drop bars usually are not rotated that far upwards.
Same goes for brake levers. Hood placement should enable a neutral wrist position, which I doubt that one does. Also, braking from the drops will be rather difficult.
Maybe the extreme bar position is compensating for another bike fit problem, like too long of a reach?
Old 04-03-24, 10:33 AM
  #3554
pepperbelly
old newbie
Quoted: 541 Post(s)
"extreme"
I don’t know. It was like that when I bought it used and I never thought about it. I had a bike shop replace the bar tape after I bought it and they never said anything.
Should the bars be rotated forward?
I guess I really should get the bike fit to me.
Old 04-03-24, 11:15 AM
  #3555
curbtender
curbtender's Avatar
Quoted: 1611 Post(s)
Liked 2,593 Times in 1,225 Posts
Not a problem. Some people only ride the brake hoods. It has to be pretty windy before you see me in the drops. If you are not sure you can adjust them down to try it out. Here is a good explanation on that...
curbtender is offline
Likes For curbtender:
Old 04-03-24, 11:49 AM
  #3556
pepperbelly
old newbie
Quoted: 541 Post(s)
https://youtu.be/rNKxVcy5Skk?si=d5tljJS9kTzB4MAK
I most ride on the hoods but now and then I get into the drops.
If I rotate them forward would the hoods be a further stretch to reach?
Old 04-03-24, 01:13 PM
  #3557
t2p
Quoted: 1401 Post(s)
Liked 1,886 Times in 1,085 Posts
bars could be rotated (down) - ? - and or shifter / brake assemblies could (should) be rotated (down)
good starting point for mounting shifter / brake assemblies is to align the bottom of the brake lever to the bottom portion of the handlebar drop with a straight edge (ruler or whatever) … then go from there … (someone else can probably better describe this and / or provide a visual)
a different stem might be more appropriate for you … a stem with rise (zero or 5 - 15 degrees ?) … maybe the stem could be flipped to provide +5 to 7 (? - can’t determine from the pic) … and/or - shorter stem with a rise could provide a better position for you on the bike and be more comfortable … ? … and then the handlebar and shifter / brake assemblies could be better oriented … shifter / brake assemblies could be lowered on the handlebar drops to provide a better and more neutral position for shifting and braking (from hoods and drops)
t2p is offline
Likes For t2p:
Old 04-03-24, 05:38 PM
  #3558
curbtender
curbtender's Avatar
Yes because the bars will be a little lower. Who ever rolled them back probably liked to ride more upright.
Old 04-03-24, 06:54 PM
  #3559
pepperbelly
old newbie
Quoted: 541 Post(s)
I will try it. This would be the easiest adjustment to mess with.
Old 04-03-24, 07:22 PM
  #3560
SpedFast
Just Pedaling
SpedFast's Avatar
Bikes: YEP!
Quoted: 334 Post(s)
Liked 522 Times in 348 Posts
I think you'll like it. IN that current config there is almost no way possible you could use the brake levers while in the drops. My old wrists won't bend like that. But brakes aside, I find the drops my goto position for comfort. It didn't used to be like that, but then I come from a MTB background. As I've aged I've gotten lazy and the drops are where I always end up, especially when I get tired and fatigued. Good luck
SpedFast is offline
Likes For SpedFast:
Old 04-03-24, 08:14 PM
  #3561
pepperbelly
old newbie
Quoted: 541 Post(s)
Until I rid myself of my “aerobelly” the drops aren’t comfortable but I really want to get this setup correctly.
Old 04-03-24, 08:32 PM
  #3562
pepperbelly
old newbie
Quoted: 541 Post(s)
Can you show me about how the bars should look? I just want an approximation so I know about how much to adjust them.
Old 04-03-24, 09:00 PM
  #3563
big john
big john's Avatar
Quoted: 8285 Post(s)
Liked 9,055 Times in 4,481 Posts
Really it matters most if you are comfortable with it but here is a Cannondale with a bar shaped like yours. The bar is rotated a bit further down than yours.
Remember bars come in lots of different shapes and sizes, different reach and drop configurations.
big john is offline
Likes For big john:
Old 04-04-24, 09:34 AM
  #3564
SpedFast
Just Pedaling
SpedFast's Avatar
Bikes: YEP!
Quoted: 334 Post(s)
A good starting point is rotating the bars to make the bottom of the drops level with the ground and then rotate them until they feel right for you. Just remember, as mentioned earlier, the more you rotate them up, the closer the hoods come toward you. If they're too close to you you'll find that you're putting more weight on your arms which will affect your wrists and shoulders. There is a sweet spot where you'll find that your arms aren't leaning on the bars and that's what you want. With time and hours in the saddle that will change as your body develops and you lose your 'Aero; physique.
SpedFast is offline
Likes For SpedFast:
Old 04-04-24, 10:25 AM
  #3565
t2p
double yikes !
t2p is offline
Old 04-04-24, 10:30 AM
  #3566
t2p
another double yikes - this one offers flat bar and drop bar !
t2p is offline
Likes For t2p:
Old 04-04-24, 10:31 AM
  #3567
t2p
my fav
t2p is offline
Old 04-08-24, 07:58 PM
  #3568
Wildwood
Veteran, Pacifist
Wildwood's Avatar
Quoted: 3898 Post(s)
Liked 4,836 Times in 2,229 Posts
Originally Posted by non-fixie
After a short spell of experimenting with wider tires and even 650B wheels I'm back to normal with my latest build: 700C and skinny tires.
Been mulling @non-fixie 's comment about returning for a narrower tire after trying wide (and admiring the eleganté build). Not reading too much into it, but.....
I put 33mm tires on a road bike and felt the sloppier (slower, softer,... IDK the best word) handling was offset by the cushioned ride over rougher surfaces. Fair compromise, I reasoned, for some rides. But not with fast downhills.
I purchased a set of Barlow Pass, lightweight 38mm, but moved the intended bike before the new tires got mounted. I'm almost afraid to mount the 38s on another bike for fear I will further compromise steering for comfort. Ohhh, the distress of indecision. Possibly for the '71 PX10, most others won't accept 38mm.
Wildwood is offline
Likes For Wildwood:
Old 04-09-24, 03:15 AM
  #3569
50PlusCycling
50PlusCycling's Avatar
Quoted: 552 Post(s)
Liked 820 Times in 412 Posts
My newest bike. I’ve been averaging about 30 miles per day on this bike. In June I’ll be riding it out to the Hiramatsu hot springs resort in Atami, and in July I will ride it from Wakkanai in Hokkaido to my home in Tokyo. The building in the background behind the bike is the Tokyo National Art Center, which is across the way from my home.
50PlusCycling is offline
Old 04-09-24, 11:34 PM
  #3570
Fredo76
The Wheezing Geezer
Fredo76's Avatar
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 920 Times in 447 Posts
Blue Bella came out nice, I think.
Blue Bella @ Rio Grande
24 1/4 lbs. (11 kg) as shown. Have added bottle cages and a pump since, and will be riding with a spare sew-up under the seat, too. And a little triangle bag, if I can find it. So here it is before it got cluttered up. :-)
Fredo76 is offline
Likes For Fredo76:
Old 04-16-24, 01:33 PM
  #3571
ascherer
ascherer's Avatar
Quoted: 938 Post(s)
Liked 2,945 Times in 981 Posts
Bottom row center is one of my wife's bikes. The rest are my regular riders, in the "grab-and-go" racks in the garage.
Top: Falcon, Paramount, Mercian
Bottom: PX10, Mrs. ascherer's Motobecane, Raleigh Pro Mk I. I have a Shogun touring bike in cold storage that will undergo a transformation and hopefully rejoin the regular rotation.
ascherer is offline
Old 04-16-24, 08:52 PM
  #3572
Wildwood
Veteran, Pacifist
Wildwood's Avatar
Never seen 3 such nice saddle covers. 20' digital image inspection.
Are Easterners more prone to 'covering (pun intended) all bases' than Westerners? - just talking USA of course.
Wildwood is offline
Old 04-17-24, 10:41 AM
  #3573
ascherer
ascherer's Avatar
Quoted: 938 Post(s)
Jandd saddle covers. I started getting them to use while transporting bikes on a car rack, and leave them on the leather saddles while they're at rest. Very sturdy and well-priced even when they're not on overstock sale. I like their tubuar tire carriers and saddle wedges too.
ascherer is offline
Likes For ascherer:
Old 04-17-24, 10:43 PM
  #3574
cyclezen
OM boy
cyclezen's Avatar
Bikes: a bunch
Quoted: 517 Post(s)
Liked 645 Times in 438 Posts
Yeah, I know - bizarre. Wildwood with
Shimano (integrated levers) instead of Campa, a 1st
electronic shifting - first, Di2 Ultegra
disc brakes - hydraulic even, a first
more than 29cogs, on a road bike, a first
no skinny frame tubes, first
room for 40mm tires, first on a road/gravel drop bar bike
e-bike, first
batteries, first
but ... even with nothing on the bars & stem I'm not sure my mantra is still valid:
clear your handlebars and your mind will follow
After 35+ adult years of active cycling = a little new is inevitable for a 70+ cyclist who still wants to crank it on, sometimes.
Besides I'm worth it and always ready for a charge.
Initial ride = 100% success.
SO a year and 1/2 ago... Are you still riding it? Interested in your thoughts on the Gain (and e-bike roadie thing).
...maybe you've already done a write-up, somewhere else on BF?
Ride On
Yuri
cyclezen is offline
Old 04-18-24, 06:30 PM
  #3575
Wildwood
Veteran, Pacifist
Wildwood's Avatar
Ride On
Yuri
Thanks for following-up.
The short version is - I really like it, serves my specific purposes and has been 100% reliable, without so much as a flat tire. I did not change a stem or a handlebar or a saddle. Only added an 'off brand' range extending battery, which also has been working without issue. Guessing mileage since Oct '22 at ~2000miles. I have 38mm Barlow Pass tires ready as replacements, for hard 28mm (but no flats)
My specific primary reason for 'needing' an ebike is: the 32mile round trip commute to babysit grandkids proved too tiring for me to be effective with them. I still have a dozen rideable standard road bikes that are used when not 'commuting'. The secondary reason for 'needing' an ebike was to regain the ability to ride The Cascades again (faster than 3 mph uphill for miles). Third reason = I feel more comfortable running errands with less muscle power in my hilly local area. Fourth, I had not bought a new bike in years and with every other road bike base mostly covered why not go motored, electronic shifts, with hydraulic discs? .
My longer comments will follow later tonight.
Commuter Wildwood, recently.
Cascades Wildwood = after climbing to this point, 10 miles more to ~6,200 ft elevation (I think). It was a 3 day cycling weekend using Crystal Mt Resort as a base.
The motor made the mountain trip not only possible, but far more enjoyable. A real aerobic event for me, obviously less muscularly demanding. Maybe sad to some members, but not from my 72yo perspective.
Which offers a segue to the larger topic of ebikes and motors. My opinion is that my 30 lb Orbea Gain, Class1 250w rear hub motor with assist to 13-14mph is perfect for me. Others may want more assisted speed and are willing to buy the extra power and associated additional drivetrain maintenance. I have been - and remain - a guy who likes to pedal, but acknowledges that I can't pedal uphill as well as I would like. Would I want an ebike as my only bike = No, the cycling experience would be lacking. But the road ebike is another arrow in the quiver of cycling's world of satisfaction.
60 years apart (1959 - 2020) not that much change for a pedal bike.
Wildwood is offline
