Cheapest chiense sealead bearing front hub?
I need sealed bearing front hub 100mm OLD, 36 spokes, without disk brake, with regular nuts what's the best deal i can find in china?
Aliexpress or similar please share link if you find. $20 or cheaper.
Similar to this, any color will do (hub diameter does not have to be big like pictures below)
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
$20? Look for used. Your Google works as well as mine.
Likes For Rolla:
Quoted: 1364 Post(s)
Liked 1,685 Times
If there is a bike co-op near you, I suggest you look there. I broke the rear axle on my 1997 26" 7-speed MTB. I bought a comparable used wheel for $20 and they put my gears on it for $5.
Likes For BobbyG:
Quoted: 4227 Post(s)
Liked 2,489 Times
Formula hubs are pretty cheap.
Likes For wolfchild:
Need new.
Aliexpress has plenty sealed bearing hubs around $20 including shipping, except most of them are quick release and for some reason 36h sold out at moment only 32h available.
I'm using "Pasak" brand sealed hub front and back. Much cheaper than Novatec but still good quality. I've used it rain or shine, no issues. The only problem for you, all I can find is quick release. 36h is very rare.
Likes For koala logs:
Guest
Liked 3,270 Times
Clark W. Griswold
Quoted: 4422 Post(s)
Liked 4,066 Times
Bottom feeding gets really expensive, I wouldn't build a wheel with the cheapest hub you can find it isn't worth the time and the money.
