Diagnose pics of damaged fork steerer
Bikes: 1976 Schwinn Super Le Tour, tricked out with modern components. Shimano Alfine 11 internal gear hub. Dynamo hub. Titanium racks and bottle cages. Mercier Kilo Wide Tire dropbar singlespeed
Quoted: 44 Post(s)
Liked 8 Times
See pics and diagnose the cause of the damage to this fork steerer. Despite the scoring looking quite deep in the pictures, upon measuring the scoring, I confirmed that they are no deeper than the milled slot in the fork steererr that the slotted washer mates with. I am guessing this was caused by a loose headset, which must have caused the steerer to come into contact with a stationary part of the headset -- probably the headtube top race. Fortunately, I found this in the process of taking this fork out of service, to replace it with a NOS fork and a new cartridge headset. I would think that if this fork were used for a long time in this current condition that the steerer would eventually crack off at this scored section, right?
Interestingly, the scoring is on the front-facing section of the steerer. I would have thought that a loose headset causing the steerer to rub would cause it to rub on the back side. Is my logic accurate or inaccurate?
Quoted: 5833 Post(s)
Liked 2,666 Times
Yes, the likely cause is a loose headset, but could also be some kind of debris, or a misloaded ball when you assembled the headset.
The shape and location of the gouge has me thinking if maybe it's below the headset altogether. Maybe the rivet or screw holding on a head badge.
However, you're right that if it were rubbing against the lip of the headset, the worst damage would be toward the back. I'd start the diagnosis by installing the upper race and locknut to gauge the height vs. the headset, then looking for corresponding damage in the headset or head tube .
FB
Chain-L site
FB
Chain-L site
Bikes: 90 Raleigh Chill MTB, 92 Trek 1200, 2004 Trek 2300, 67 Sports, 70 Sports, 71 Philips, Lotus Challenger, 74 Super Course, Univega Gran Tourismo, Nishiki Seral
Wouldn't that steerer be a stronger steel than anything it would likely come in contact with? That's a serious gouge, almost looks intentional, like someone was going to cut down the steerer and found out their old rusty hacksaw blade was no match for the chromo steerer.
Quoted: 44 Post(s)
Liked 8 Times
Ah ha. I like your reasoning, and I bet it came from a ball becoming trapped where it should not have been. I will pull the fork and inspect the head tube to look for a head badge rivet as a possible cause, too. Man, to think of a steerer shearing off -- what a terrifying thought. Yeeeeeeeeeeeeeoooooooooooch!
Quoted: 44 Post(s)
Liked 8 Times
I would think that a hardened ball bearing would be far, far harder than cromo steel, and the profile of the score pretty much matches the profile a a loose ball bearing.
That blue looks familiar, is that fork off a Raleigh Chill mountain bike, a Tange Bigfork by any chance?
Quoted: 44 Post(s)
Liked 8 Times
Tange fork on the Panasonic-made frame of a 1976 Schwinn Super Le Tour 12.2. My darling baby, which I bought brand-new with my paper route money. Many tens upon tens of thousands of miles on the old girl. I bought a NOS Tange fork with the standard stem diameter so I can get away from the dumb Schwinn-specific stem diameter. Glad I did, now that I discovered this damage.
Liked 2,666 Times
Love or hate various bike designs, but most of the older systems evolved when materials and processes were less reliable and so had a certain amount of redundancy and safety built in. I think back to vintage fork steerers that had a safety device in the form of a wooden dowel plug extending from the fork crown to well in to the lower bearing. Steerer snaps, and the plug prevents a face plant.
FB
Chain-L site
FB
Chain-L site
Señor Member
Quoted: 649 Post(s)
Liked 293 Times
but is not exceptionally hard or immune to scratching or grinding
It happened to me. Luckly I knew something was wrong, so I was almost stopped when it broke. I landed in front of an ice cream place, on my face. All those folks wating to get ice cream cones saw me leave half my face in the street. It hurt.
