Power meter numbers, trainer versus road
Quoted: 119 Post(s)
I'm thinking that power numbers may be less accurate on a trainer due to there perhaps being more flex or give versus the unforgiving surface of the road. I'm using the Stages crank arm power meter. Thoughts?
Quoted: 2952 Post(s)
Liked 3,106 Times
I don't think the PM knows or cares about the road surface since calculates torque from strain gauges in the crank arm.
Quoted: 57 Post(s)
Accuracy will be identical; the PM will measure the force you apply to the pedals equally. You may encounter different resistance and motivation on the road. For instance, being surprised and chased by a dog resulted in my first ever 1kw+ reading.
Bikes: CharlesraP
Quoted: 19 Post(s)
In my case, im nearly 100% sure that my power meter (power2max) is reading lower indoor.
I would say about 20-30b watts aroung 250-300w and it its even worse at higher power. And Im not talking about loss of power due to heat soak. I can notice the lower readings within 3-4 pedal strokes.
The best example was last saturday when I did my first ride outside. It was so easy to do 500-600w seated vs indoor where its nearly not possible.
My guess its probably due to some drivetrain/tire loss.
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
Depends where the PM is. If it is on a trainer and at the tire (a roller) it could be lower by ~10W vs on the pedals.
I prefer the at the tire devices as it measures the net result including all losses.
Pedals measure you , which is good, but what hits the ground matters most.
Quoted: 105 Post(s)
Speed is less than useless as a training metric.
Why would you purposely put back in varying factors by measuring at the back wheel? Crank friction, chain wear/lubrication, different cogs, whole drivetrain, hub friction loss.
Thread Killer
Quoted: 3153 Post(s)
Liked 1,717 Times
Quoted: 105 Post(s)
The only way that power meters differ from spedometers is that they eliminate Factors that throw off your personal energy expendeture.
Crank friction is constant as long as bottom bracket bearings are serviceable, chain wear would have no effect on power, chain lubrication would have an effect only at an extremely low level of lube, I have no idea why you think different cogs would affect power measurement, and hub friction loss is only an issue after the hub has read the power.
Liked 371 Times
Speed also has aero loss, which I care about too.
But there is equipment loss and it is not totally trivial.
Liked 371 Times
When training for TTs it is about the only thing we use. Some positions generate more power and are less aero and visa versa. It is the fastest setup that matters most and it is not always where the most power is being generated, nor the most aero - it is the fastest.
Quoted: 105 Post(s)
How are you controlling for the moving air during this TT training?
Liked 371 Times
Position.
It is not much a factor here, or I know when it is. 5mph ocean breeze off the right, then off the left are pretty predictable.
Then there is the indoor track.
Then there is Palomar (aero position not important).
pluralis majestatis
Bikes: a DuhRosa
Quoted: 537 Post(s)
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Races are won by going the fastest at just the right times, regardless of how much power is put out.
Using power in training to figure out how to maximize speed is the opposite of useless.
Bikes: CharlesraP
Quoted: 19 Post(s)
It is widely reported that it is harder to produce power indoors than outdoors. There are a few hypothesis for that, but I haven't heard of power meters somehow misreporting just because they happen to be inside until now.
Bikes: bikes
Liked 1,429 Times
Then it doesn't really matter. Simply riding more will help the vast majority.
Regardless, speed is far from useless and has been the de facto inducator of fitness for as long as people have tried to measure endurance progress.
Thread Killer
Liked 1,717 Times
