Professional repair of tubulars
#51
Quoted: 6556 Post(s)
Liked 58 Times
#52
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
#54
Liked 58 Times
#55
Liked 58 Times
I purposely picked butyl for better air retention and better durability around the valve stem. Several of my Vittoria tubular tires with latex tubes have failed at the valve stem. In fact that is the only type of failure I have experienced with those tires. So I wanted a stronger tube in that area...just not THAT much stronger.
Replacement latex tubes were about $5 more. I thought the weight would be the same.
#56
It's MY mountain
Liked 2,980 Times
OK, well poking around weight weenies, (700c 18-25) I see the lightest latex tube is 54g and the heaviest butyl tube is 122.
So extreme to extreme would only give you 68g difference. Can't blame the whole 80g difference on the tube. Maybe they used heavier thread to stitch it up too?
Or maybe your measurements are off.
#57
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
I was going to laugh at you then I went and took an off the shelf run of the mill butyl tube that I sell all day and night and weighed it (with my coffee scale) with a 60mm valve - 89g
As others alluded to - either something is off or something else is in play.
Grand scheme - if 80g was an issue then you should have just bought a new tire.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
#59
Liked 58 Times
#60
Liked 58 Times
#63
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
#65
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Been patching tubs myself, but its getting tiresome and finger abusive. Rallys are verbotten now, rock cutting is way too prevalent on our rural roads with sharp inbedded rock aggregate. Ribble still lists the Vittoria Pave and Roubaix on line. Tire Alert sounds like a good choice, might need to try them.
Bill
Bill
Semper Fi, USMC, 1975-1977
#66
I've been on the same set of tubulars for several weeks now - on daily rides which sometimes includes long stretches of gravel.
Tufo 22s: very puncture resistant tires, with minimal tread wear.
I know that I have at least one pinprick flat in the front, and who knows how many in the rear.
Anyway, 20cc of Stan's in each keeps them inflated, and riding as if nothing happened. It is a rare puncture that is even noticeable, before the liquid latex seals up the hole. It takes something truly special to cause the tire to become flattened, something that would have killed a clincher tire.
#67
Liked 58 Times
