Anyone using a 10 Speed D/A Crankset with 11 Speed?
Bikes: 02 Litespeed Ultimate, 84 & 85 Raleigh Grand Prix, '84 Raleigh Prestige, 85 Raleigh 555 RSL, '20 Raleigh Tamland, 38 Raleigh, 85 Landshark "Raleigh", '84 Marinoni Levi's Raleigh, SB4484, SB7979, Raleigh SSCXWC, 87 Raleigh USA 531 Prototype
Quoted: 202 Post(s)
Liked 147 Times
I'm in the middle of throwing together a 2003 Litespeed Ultimate, and want to use a Dura Ace 11 group, but the Crankset is one of the ugliest available IMO. Has anyone used anything else with this setup successfully? I like the look of the 7800 much better, but I'm guessing that's likely not compatible with 11 speed. Thanks!
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
It's probably alright.
But that 9000 crank grew on me quite a bit. Looks miles better than every other four arm job.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Likes For Kimmo:
Likes For noodle soup:
Quoted: 202 Post(s)
Liked 147 Times
bike whisperer
Liked 716 Times
Actually, the anodising fade on 9100 is pretty impressive. Not such a fan of the asymmetric fade on the hubs, though... But at least I guess it leaves the door open for big lulz at anyone who puts their rim brake front in backwards.
Batüwü Creakcreak
Quoted: 228 Post(s)
Liked 288 Times
On the flip side, do the newer 11 speed cranks work with a 10 speed setup? I've read mixed things about it and it looks like there are a LOT of inexpensive 11 speed compact cranks on the market since it appears that's what everyone is running these days.
bike whisperer
Liked 716 Times
You probably want to run an 11s chain with an 11s crank. You might run into trouble getting the trim position on the fd dialed in.
