What did you do for your Hybrid today
#901
Bikes: 2019 Trek X-Caliber 8 and 2019 Trek FX2
Quoted: 19 Post(s)
Thanks for the tips!! I ordered these from amazon, Zefal "Cristophe" Mountain Bicycle Half Toe Clip. I know they say for mountain bike but read reviews saying there fine for any bike. They were cheap enough and seamed to have pretty good reviews. I got size l/xl for my size 13 shoe, hopefully they will work out.
I have thought about clip less but going to try these out and see where it goes from there.
#902
Quoted: 5224 Post(s)
Liked 3,584 Times
#903
Quoted: 19 Post(s)
Thank rumrunn6. I do like the look of yours. This is all new to me. Up until last year I never really took cycling all that serious. After finding some nice bike paths and realizing how enjoyable it is I’m hooked.
#904
Quoted: 19 Post(s)
Mine came in and seamed ok but not liking the bulky plastic look. I did order a pair of velo orange stainless steel deep half clips. With that said I am very curious on your set up.
#905
Liked 3,584 Times
Mks Double Strap Toe Clip L
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
using a bench vise & locking pliers I just snapped of the top part just below the rivets, then filed the edges
then I opened them up a bit with my hands for more height
for more depth I DIY'd spacers using nuts, bolts & plastic/vinyl tubes from the hardware store
this gives me perfect foot placement on the pedal axis
regardless of footwear
even size 14 Columbia boots
I also use Sunlite Pedal Extenders, 9/16" to 9/16", 21mm Long so the sides of my feet aren't leaning off the side of the pedals giving me 5 1/4" from crank to outside edge of pedal. the 3rd photo shows the pedal extender visible & not all photos were taken after the extenders were added
#906
Quoted: 19 Post(s)
Wow rumrunn6, you definitely put a lot of time and effort into you clips!! Great description of details and parts as well!! Sometimes you just cant beat custom made, I will try out the stainless ones I purchased and keep yours in mind for sure. I will let you know how mine work out!!
Thank you again for great detail on yours!!
#907
Liked 3,584 Times
#908
Proud hobo biker
Bikes: 2019 Surly Ogre, 2016 Giant Anyroad 2, Lightspeed Roadrunner trike, SE Tripel (in process)
Quoted: 202 Post(s)
#909
Proud hobo biker
Quoted: 202 Post(s)
rumrunn6, great modification. I just gave away a set of metal clips or I would give this a try.
I've used spacers before but just to make toe clips fit on MTB pedals.
#910
Bikes: I'm a Flatbar Guy
Quoted: 356 Post(s)
oh those look really good! but I don't mean looks wise, I mean features & benefits, but they do look fine as well. guess I didn't know about them when I made my own. sounds like you will be all set, but since you asked, this is what I've done for 3 bikes
#911
Liked 3,584 Times
thanks. wonder why they don't make stuff for clown feet, like mine
#912
Quoted: 1002 Post(s)
Liked 237 Times
I added a second light up higher. Cygolight Hotrod 50. Works great in conjunction with the much bright Hotshot 150. But while the 150 can be seen from further away it can only be seen straight back. The 50 has a wider field of view.
(Does not mount horizontally like this normally. I had to get creative)
#913
Quoted: 356 Post(s)
I really love my FXS6 but I was never happy with the way the derailleur stuck out from the chain stay of the bike. Shimano has the Shadow Derailleurs for the MTBs but just recently came out with the Shadow Derailleurs for the Ultegra groupset. I really like the way the Shadow Derailleurs tuck up under the chain stay, they look so much cleaner, they also eliminate the big shift cable loop and the shift cable is routed to the inside which is much cleaner, also it protects the derailleur a little more from getting snagged on a protruding object.
I found a good deal on a Ultegra Shadow rear derailleur and decided to install one just because I like the cleaner look. I am also running a 12/25 cassette so I went with a short cage derailleur, I had to remove 3 links from the chain, but the bike shifts even crisper than it did before, so win win !
I’ve installed a bunch of derailleurs and this one was bar far the easiest to set up. The Limit screws and B-screw are allen head, so adjustments were easier than using a screw driver. The barrel adjuster is also really precise, only needed a couple clicks of it and had it shifting and sounding nice pretty quick.
BEFORE:
AFTER:
BEFORE:
AFTER:
#914
Liked 3,584 Times
good job!
#915
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
It looks like the Ultegra one doesn't have a clutch. Could you compare the shift effort of the Shadow vs. non-Shadow? I understand the tension springs are much tighter on Shadow derailleurs, making downshifts (to larger sprockets) more of a physical effort on the shifter (more spring pressure to overcome). Does your experience match that, or do you not perceive any meaningful difference?
#916
Quoted: 356 Post(s)
#917
Liked 762 Times
I've been thinking about replacing the derailleur on my Trek Verve (currently an Acera M360) with a clutchless Shadow derailleur (Acera M4000). I don't need a clutch in my situation, either, but I had heard that the Shadow derailleurs (even the clutchless ones) required more cable tension to shift because of stiffer springs. Maybe that's not the case; maybe the review I read was on one with a clutch. In fact, maybe that was your report I remember. With the clutch on, shifting requires more effort, but with the clutch off, it's no different than the old non-Shadow derailleur?
I would change mine for the same reason as you: the cleaner look and nicer cable routing.
#918
Quoted: 356 Post(s)
I just rode 30 miles today on my FXS6 and the new shifter was flawless, it’s quieter and it felt a little easier/lighter to shift, I’m guessing because it’s new ? I had a m4000 on my Fuji Crosstown and it shifted really nice and they’re probably not that expensive. I don’t believe the spring tensions are any higher on a Shadow derailleur compared to a standard one
#919
Bikes: 2000 Trek 720 Multitrack (plus)
Quoted: 48 Post(s)
#920
New rear tyre 32mm. I haven't tested yet, but I can see is gonna be an upgrade from the previous one.
#921
Bikes: 2007 Specialized Sequioa Elite
Quoted: 9 Post(s)
Well, just got my new 2018 Trek Verve 3 a couple weeks ago for my birthday. Given Iowa weather, have only gotten to ride it once. Swapped my Topeak rear rack/bag from my road bike to this bike, originally swapped the iSSi Flip Pedals from my road bike, but just put the stock Verve pedals back on. Liked the bigger platform under foot.
Today just added some Bontrager bar ends and the Mirrycle mirror. Need to get some more riding time in to make sure mirror is adjusted where I want it. But should be good to go for a while if we can just stop having snow and start having some better riding weather!
#922
Liked 762 Times
The white paint looks great. I have similar bar ends on my Verve 3. I have not yet done the Mirrcycle mirror like you have, but I plan to.
#923
Bikes: 2022 LiteSpeed CHEROHALA CITY, 2019 Canyon Roadlite 9.0 CF LTD, 2015 Giant FastRoad CoMax 1, 2001 Mongoose Pro Triomphe,
Quoted: 129 Post(s)
Liked 84 Times
https://www.bikeforums.net/hybrid-bi...set-tires.html
