What condition does the road tire need to be in to be considered unsafe?
Old 05-10-20, 08:37 AM
Finklestein
Been riding on zwift for quite a while on on of the kinetic trainers and my bike tire feels slicker compared to my front one, but not that significant I think. What condition does the road tire need to be in to be considered unsafe?
Finklestein is offline
Old 05-10-20, 08:44 AM
datlas
Beyond Bogus
datlas's Avatar
Quoted: 12832 Post(s)
Liked 1,808 Times in 959 Posts
Should be fine unless you see cords/casing.
Addiction is all about class.
datlas is offline
Likes For datlas:
Old 05-10-20, 08:47 AM
eduskator
eduskator's Avatar
Bikes: TCR Advanced Pro 0 Disc
Quoted: 338 Post(s)
Liked 167 Times in 129 Posts
Until your threadwear indicator marks tells you to replace it. If you have a feeling they need to be replaced, replace them!
eduskator is offline
Old 05-10-20, 08:52 AM
Iride01
Type faster than I think!
Iride01's Avatar
Bikes: '20 Tarmac Disc Comp '91 Schwinn Paramount '78 Raleigh Competition GS
Quoted: 1650 Post(s)
Liked 536 Times in 411 Posts
If the inner tube isn't bulging out the sidewall, it's good to go. I've never had a wreck or even felt unsafe anytime I've flatted on a bicycle. Perhaps other have horror stories but I have never experienced anything remotely unsafe feeling.
You should consider where you are going to be riding and how a flat might impact you in those areas. If a tire is getting close to looking bad, I'll change it a week or so before I do an organized century ride or such.
Iride01 is offline
Old 05-10-20, 08:55 AM
MinnMan
MinnMan's Avatar
Bikes: 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 1515 Post(s)
Liked 743 Times in 443 Posts
It's been on the trainer and probably has worn down to a flat profile. This is not ideal for performance, but it doesn't really affect safety unless, as noted above, the cords are showing.
Also, for the most part, getting a flat tire is more of a nuisance than a safety hazard.
MinnMan is online now
Old 05-10-20, 09:18 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 3131 Post(s)
Liked 477 Times in 353 Posts
No worries.. on your type of trainer, even if the tire blows your axle is locked in.
Sy Reene is offline
Likes For Sy Reene:
Old 05-10-20, 03:07 PM
shelbyfv
Quoted: 1810 Post(s)
Liked 1,182 Times in 672 Posts
Yes, probably safe enough on the trainer. If you move on to riding outdoors, maybe treat yourself to a nice new pair as a reward.
shelbyfv is offline
Old 05-12-20, 07:57 AM
topflightpro
topflightpro's Avatar
Quoted: 1580 Post(s)
Liked 311 Times in 215 Posts
If you are having some slipping issues on the trainer, wipe the drum and tire down with some rubbing alcohol to clean it off. That often helps improve grip.
If that stops working, you can take some sandpaper to the tire to rough it up some. Sometimes tires glaze over a bit when used on the trainer a lot, and the sandpaper clears that and adds a bit more grip.
Last option, you can buy grip tape that you stick to your trainer drum, but that will chew up tires and can create a bit of a mess.
topflightpro is offline
Old 05-12-20, 08:01 AM
GlennR
Passing on your left
GlennR's Avatar
Quoted: 1974 Post(s)
Liked 941 Times in 500 Posts
you're worried about tire safety on a trainer?
Whats the worse that can happen?
GlennR is offline
