Road rims for disc brakes (or can I ride rim brakes rims with disc brakes?)
Old 08-29-13, 01:36 PM
FatBottomedGirl
FatBottomedGirl's Avatar
Hello,
Are there rims compatible with thinner tires (19-28mm range or anything that would allow to ride 23 and 28mm tires) that are also compatible with disc brakes?
I know the use of skinny tires is not common with disc tires but is there a physical reason preventing it?
Also, can I use a rim-brake rim (which is way easier to find for skinny tires) with a disc brake? (assuming I have it built with a disc-compatible hub, obviously!!)
I know rim-brake rims have a brake track, but is the lack of brake track the only specificity of a disc compatible rim? or does it have something??
Thanks
FatBottomedGirl is offline
Old 08-29-13, 01:48 PM
woodway
Squeaky Wheel
woodway's Avatar
Quoted: 38 Post(s)
Liked 8 Times in 6 Posts
I had wheels built for my commuter using Mavic Open Pro rims and DT Swiss disc hubs. And here I find out a year and 7800 miles later that I was supposed to use disc-compatible rims The braking surfaces on the rims are pristine however. I run 25c tires. The setup works great.
woodway is offline
Old 08-29-13, 01:53 PM
TrojanHorse
SuperGimp
TrojanHorse's Avatar
Bikes: Specialized Roubaix
Quoted: 1105 Post(s)
Liked 61 Times in 45 Posts
I'd steer clear of using rim brakes on rims that don't have a braking surface but the other way? Who cares!
TrojanHorse is offline
Old 08-29-13, 03:36 PM
FBinNY
Quoted: 4361 Post(s)
Liked 17 Times in 17 Posts
Disc brake wheels don't care which rims are used. It's only an issue with rim brakes.
There are some disc only rims, which don't have a suitable brake track, though I suspect there's only marginal weight savings, and mostly an issue of cosmetics, ie. painted rims.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FBinNY is offline
Old 08-29-13, 04:03 PM
FastJake
Constant tinkerer
FastJake's Avatar
Quoted: 81 Post(s)
Liked 35 Times in 29 Posts
Every rim is "disc compatible." Use whatever rim suits you best, regardless of whether it's rim brake compatible or disc only.
Disc brake proponents like to claim weight savings with disc only rims, but I have yet to see it.
FastJake is offline
Old 08-29-13, 04:05 PM
GeoKrpan
George Krpan
Quoted: 12 Post(s)
There is an advantage to using rim brake rims. The wheels can then be used on both disc brake and rim brake bikes. Find some complete road bikes with disc brakes and see what rim they're using and the way they're spoked.
GeoKrpan is offline
sreten
Bikes: 20" Folder, Road Bike
Hi,
You can use any rim you like for any tyres you like.
Brakes on skinny tyred road bikes are more about
speed control at speed than sheer stopping power.
rgds, sreten.
sreten is offline
Old 08-30-13, 09:00 AM
FatBottomedGirl
Thank you all!
Old 08-30-13, 03:23 PM
rydabent
Quoted: 1799 Post(s)
Liked 303 Times in 192 Posts
Discs dont know what kind of rim it is stopping as others have said. However if you have disc brakes you can use a more aero rim. Some rims used with disc brakes can also be designed stronger.
rydabent is offline
Jay28
General Cycling Discussion
19
08-30-15 07:46 PM
sing
Folding Bikes
24
04-30-13 09:24 AM
hybridbkrdr
Bicycle Mechanics
17
11-22-10 11:56 PM
the_um
BMX
3
10-25-10 11:13 AM
daven1986
Bicycle Mechanics
12
12-14-09 05:48 AM
