[Dahon Vitesse D8] Rear derailleur snapped
Old 12-10-13, 04:30 AM
larrydeer
Hi all,
Last March I bought a brand new Dahon Vitesse D8 and this morning, whilst I was cycling, the rear derailleur (NEOS 8 SPEED, DAHON SPECIAL EDITION) snapped in two. I would like to replace it with a better one (my budget is max 80). Any suggestion?
At the moment I am thinking cycle with no rear derailleur removing 7/8 chain links using a middle gear. Can I do that?
I know that probably I have to buy a sort-of adapter if I want to use a Shimano derailleur. Is it true?
Thanks.
Larry.
larrydeer is offline
Old 12-10-13, 11:28 AM
ThorUSA
Bikes: to many
Quoted: 213 Post(s)
depends on what vitesse frame you have .. send us a pic and we will be able to tell you if you need an aadapter or not... I do have them for sale but shipping would be an additional 20 bucks and it would be cool if you do not need one to start out with ...
wonder how that derrailleur broke, they are usually pretty bombproof ... :-(
Best Thor
ThorUSA is offline
Old 12-10-13, 04:11 PM
chagzuki
Bikes: Brompton, Dahon Vitesse D5
Quoted: 52 Post(s)
Er, get the Neos 2. As far as I understand Dahons have a reversed cable pull so the derailleur has to match shifter.
What country are you in?
chagzuki is offline
Old 12-10-13, 06:08 PM
BruceMetras
Quoted: 113 Post(s)
Liked 5 Times in 4 Posts
The Neos is a rapid rise derailleur as opposed to a High Normal type that is most commonly used ... and uses a Low Normal shifter (a High Normal shifter will work, but the shift indicator numbers will be reversed) .. the Neos is a pretty good choice for small wheeled bikes as it's very compact and optimized for crisp shifting..
BruceMetras is offline
Old 12-10-13, 06:21 PM
BruceMetras
Quoted: 113 Post(s)
Looks like CH WHITE has the Neos pretty cheap..
bike13760
Folding Bikes
15
12-10-18 08:35 PM
mikysylv
Bicycle Mechanics
2
09-17-17 10:39 AM
diogocyrineu
Folding Bikes
5
08-07-17 11:13 PM
yelworc
Folding Bikes
57
08-04-17 05:57 AM
myrridin
Bicycle Mechanics
0
10-20-11 12:11 PM
