Shimano 105 rubber hood twists out of place - fix?
Bikes: Trek Domane 4.3
Quoted: 193 Post(s)
Liked 50 Times
My right rubber hood on my 105 shifter keeps working out of the little notches. Pretty clear it's from gripping and twisting when I shift and it slowly works out of place until it stops me from shifting.
I can pull it back into place but it doesn't stay put - should be be glued down somehow? Or am I just not pulling it back into place tightly enough?
Some other solution? It's a minor annoyance, but still an annoyance.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Replace them.
Likes For cxwrench:
Bikes: 1970's Piasentin Super Vitus 971, 1979 Carlton Professional, 2005 Trek 5000, 2011 Niner EMD, 2018 Argon 18 XRoad, 1990 Diamondback Master TG Centurion
Quoted: 56 Post(s)
Liked 73 Times
This happened to me with a Shimano Sora hood after I installed new bar tape. After examination, I determined it had wrapped the bar tape too far up on the shifters and this was covering a couple of the cut-outs where the hoods sit. After re-wrapping the bar tape to make sure the cut-outs were not covered, the hoods fit securely and snuggly and the problem went away.
Likes For NatusEstInSuht:
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Quoted: 851 Post(s)
Liked 1,082 Times
What model 105 shifters are these, 7,8,9,10,11 speed? Are you absolutely certain that the hoods are mounted on all the shifter tabs that hold it in place. Some need to be checked carefully that the rubber is locked into the tabs. Of course, as mentioned, they just could be worn out.
Likes For Crankycrank:
Quoted: 2614 Post(s)
Liked 1,958 Times
Better buy some extras and keep them in a cool, dry place if you're planning to keep the bike or shifters more than a few years. Shimano will change the design and orphan the spare parts (again).
Likes For pdlamb:
Klaatu..Verata..Necktie?
Quoted: 10483 Post(s)
Liked 12,004 Times
Just not the ones you need. But the ones you DON'T need, they'll keep making forever.
Likes For genejockey:
Quoted: 193 Post(s)
Liked 50 Times
Likes For drewguy:
