Does this Fork Look Bent?
Bar Ends Forever
I'm looking to buy this bike and I was wondering if the fork looked bent in a little. I'm not usually great at telling damage like this, but something about the fork just looks a little odd in the first picture.
Bar Ends Forever
Quoted: 5978 Post(s)
Liked 2,894 Times
It's impossible to render any meaningful, opinion from a photo like either of yours. It might be possible with a straight broadside angle, but even then not assured.
You have two choices. You can test ride the bike and see how it tracks riding no hands, or you can put a straight edge on line with the head tube and see if the upper straight sections of the fork blades are in line. Best bet would be to do both.
FB
Chain-L site
FB
Chain-L site
don't try this at home.
Quoted: 989 Post(s)
Liked 536 Times
The brake cables look kind of sloppy, I'm not sure how good a mechanic he is. The front cantilever brake yoke cable seems to have slack. But that's all fixable.
I wonder if he's done anything to it. The bars are angled oddly, and still have old foam "tape". He supposedly trued the wheels, and serviced the bearings, but didn't fix the downward angle on the saddle or level the bars? The chain is half on and half off the big chainring, and the front shift lever angle is odd--is it halfway between the big and small chainrings?
The fork looks okay, but it's hard to tell from the angle.
Those photos are quite wide angle, with the camera quite close to the bike. Have him stand the bike up, zoom all the way out and stand back at least 15 or 20 feet. He should stand straight out from the front fork to take the picture. Then there won't be as much distortion in the picture.
More photos
from the photobucket album. The seller didn't even bother to get the chain onto the chainring. The small ring seems to have all the recent usage. Does it even shift to the big ring? !
The front brake photo in the album seems to show an old yoke cable, with a shiny new brake cable. But the cable is kind of mangled below the clamp, like he clamped it way too low, then adjusted it later. (It's probably still too low.)
I thought the brake pads looked old fashioned, with four sections instead of one big pad with slits in it. But a google image search found these for 99 cents. The nuts holding the pads don't look new either. You'll likely want to replace the pads with better ones.
The rear derailleur cable looks old, but it'll work okay.
With no tires, you can't test ride. How convenient.
More photos
Bar Ends Forever
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12996 Post(s)
Liked 7,916 Times
Fork looks fine to me. 2nd pic shows upper legs to be parallel with headtube.
Bikes: '00 Koga Miyata Full Pro Oval Road bike.
Quoted: 475 Post(s)
Liked 8 Times
Hard to tell from those crappy pics but it does look straight to me too. I agree with rm-rf too, the bike looks like a 'before' pic when nothing has been adjusted. All fixable of course. So he's asking $30 for the bike? Seems like a decent enough deal to me if everything works reasonable well.
Disco Infiltrator
Quoted: 3133 Post(s)
Liked 2,116 Times
Probably the least of your concerns!
Genesis 49:16-17
Genesis 49:16-17
Bar Ends Forever
Yeah, $30. I mean it's at least worth that in parts and if I brought another person with me I could test the front derailleur even without tires. I guess since the fork seems to be straight I'll at least check it out.
The rear derailleur is going for more than the bike itself: Vintage Suntour V T Luxe Rear Derailleur Short Cage Classic Road Touring | eBay
Quoted: 475 Post(s)
Liked 8 Times
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1265 Post(s)
Liked 339 Times
The fork looks bent to me. I have to agree it also looks unfixed and derelict.
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
If it is bent, it doesn't appear to be much. How does it ride? If it rides acceptably well, you should be able to get several more decades of use from it.
Expired Member
Quoted: 3800 Post(s)
Liked 5,800 Times
I won't make a guess about the fork, but the seller obviously doesn't know much about bikes or just doesn't give a flip. Of course for $30 you can't expect much....
Quoted: 989 Post(s)
Liked 536 Times
30 dollars! A good deal for someone that likes working on bikes. Maybe you can ride it as-is, with just some cable adjustments, oil the chain, adjust the saddle and bars, and new tires (maybe new rim tape if any spoke holes are showing at the tape edge)
An overhaul on a bike like this is pretty straightforward. I've used Park Tool's repair web site to find out how to do stuff. But it'll require tools -- cable cutters, bottom bracket tool, cone wrenches, pedal wrench, etc. The costs add up for a one-time overhaul. You have to like doing stuff like that.
Quoted: 2627 Post(s)
Liked 3,181 Times
Yes, worth more than $30. If nothing else, that's at least $30 worth of cleaning.
Bar Ends Forever
Thank you everyone
I'm gonna check it out Thursday. I realize he hasn't done what he says he has but I can do most things myself and I need a project anyway.
Disco Infiltrator
Liked 2,116 Times
What does "W/O HP." on the rims mean?
Genesis 49:16-17
Genesis 49:16-17
Bar Ends Forever
I think it means it's a high pressure clincher rim
At least that's what I got from this thread: https://www.bikeforums.net/bicycle-me...raya-rims.html
Bar Ends Forever
Liked 2,894 Times
W/O -- Wired-on which is the more proper term for what we call clinchers. BITD, clincher referred to a different design, that used overlapping and interlocking flaps to stay on.
Here's a link to a page of a 1938 tire and rim catalog where you'll see the W/O, or wired on terminology.
HP -- high pressure. I continued to use wired-on for non-tubular tires but 2-3 generations out nobody knows what I man, so I've signed up for the clincher club.
FB
Chain-L site
FB
Chain-L site
Quoted: 428 Post(s)
Liked 340 Times
