Handlebar installation trace
Quoted: 4195 Post(s)
Liked 3,837 Times
Careful installation? Place masking tape on either side of where the stem clamp will end up to help protect the finish. Andy
AndrewRStewart
AndrewRStewart
Quoted: 2026 Post(s)
Liked 1,095 Times
Yes, remove the stem faceplate completely, install the handle bar and orient it in the desired final position and then reinstall the face plate. Don't rotate or slide it sideways once the face plate is in place.
Quoted: 741 Post(s)
Liked 818 Times
+1 on the Sharpie. I have black bars on a couple of bikes, and the black marker works wonders. The gun metal gray on my Ultegra drivetrain isn't so easy to touch up. I found a Sharpie paint pen at Joanne's craft shop that did wonders on an old gold Raleigh frame. Not perfect, but from 10 ft away, not too bad.
Before ...
After ... not perfect but from 10 ft. away ... A couple more coats made it better.
Before ...
