Homemade Chain Lube
Homemade Chain Lube
Just wondering if anyone knows how to make some Chain Lube? I am currently in India and I have asked around a few places and no one has chain lube, but there must be 500 million bicycles in India, so they have to use something. Just wondering if anyone has some tips of what to do.
I have heard a 3:1 ratio of mineral spirits to motor oil will work. I can just imagine myself now asking for mineral spirits here and getting a head wobble (those who have been here will know what that is like). Can I use paint thinner? Should I use another de-greaser? What kind of oil (is 10-30 fine, or is there something better)?
If someone knows of one that works well in dry weather (it shouldn't rain for at least another 2 months) that would be great. There is a lot of dust here and having a lube that picks up everything isn't the greatest (however I am close to being desperate and will take any lube soon).
Any help would be appreciated, and I thank you in advance.
Quoted: 12198 Post(s)
Liked 1,499 Times
This may be dumb, but can you get Dupont Teflon MultiUse spray there?
I use it on almost everything, and it's great stuff.
https://www.lowes.com/lowes/lkn?actio...9963-D00110101
Motor oil by itself isn't all that bad.
Paraffin wax works OK in dry climates. It requires removing the chain and putting it in a can or pot of melted wax. Fish the chain out with a wire and hang it so the excess drips off before it cools. Way back in the day I used to do all my chains this way. Needs very frequent treatment in wet weather though.
I would use "real" chain lube if you can get it, but 40 years ago either of the two things I mentioned were pretty commonly used.
I mix 1 part motor (automobile) oil to 5-10 parts paint thinner aka mineral spirits. I use an old White-Lightning lube bottle to drip-dispense, carefully control volume. No point in making a mess or wasting material.
This lube mix is heavy on solvent for a reason: I carefully drip lube onto the top of lower chain run, with rag/paper towel below to catch run off. Do one little section at a time until full chain length cleaned and lubed. This CLEANS the chain, which is at least as important as preventing rust and reducing friction on the resulting clean chain. This works so well (clean / lube in one step) that I never have to actually clean the chain as a separate maintenance operation.
Since this mixture is mostly solvent, it evaporates, leaving a thin film of oil. If you lube 2-3 days before riding the chain is drier and noisier than if you ride the morning after lubing. So, this is a relatively short-lived lube. To me this is a non-issue since I lube/pump/inspect before each ride.
The solvent by itself imparts some friction-reduction, but it works better with oil added. The oil will coat better, evaporate much slower and greatly ****** (how funny r e t a r d is prohibited) corrosion rate of the chain surfaces.
Breathing paint thinner is a bad idea. You must store bike outdoors (not in room where you sleep) if you use this lube regularly. Otherwise lube just before riding - by days end it's pretty much dry again.
It's flammable too. No smoking.
Heavy rain will wash the lube out of the chain faster, just like all other commercial bike lubes.
Increasing oil in the mix naturally puts more oil onto chain - this may last longer, and it may attract more dust since oil usually seems to capture dirt better than solvent (which evaporates much faster).
I've tried a few different motor oils, and it didn't seem to affect performance one way or another. I've even tried used motor oil. The amount of oil and solvent used in a month is very small; this will make it difficult for you to buy and store. A pint of paint thinner should last for months. You could use virtually any motor oil from 5W to 30W viscosity. Maybe you could use the excess paint thinner for cooking fuel - or sell/barter to someone for food.
Motor car oil, 10W-30 grade works fine. You will likely find oil bottles or cans on the side of the road, or if not, at a petrol/fuel/gas station. Take off the cap, check that the oil remaining in the container is new, pour into the cap, and apply a drop at a time to each roller.
Otherwise, just buy a small squeeze plastic bottle with a relatively fine nozzle, get some engine oil, fill the bottle and carry it with you. A 100ml bottle should do you for a year or longer.
I use that grade engine oil on all my bikes and have done for years, including go-fast bikes. I ride bad gravel roads every day on my commuter bike that uses a second-hand 7sp chain and is getting close to having done 6,000km with that same chain, without a clean, and with application of the oil from a eye-drops bottle when the chain gets chattery. (It's an experiment in progress and I'm expecting to get 10,000km from it)
Doing anything else is a waste of time, energy and money, in my opinion.
Older than dirt
Bikes: Too darn many.. latest count is 11
Best thing to use *if* they have it in a third world country is Bar and Chain oil. It's made for chain saws. In the US, available in about any hardware store and cheap. After that, just straight weight 30w oil also works well.
-R
-R
Thanks for the reply. It looks engine oil will work in a pinch (just be careful to apply it to every roller), but I am going to try the 1:5-10 ratio of oil to thinner. Thanks a lot.
This formula is suppose to be similar to Prolink, which is one of the best chain lubes: 3 parts mineral spirits to 1 part Mobil 15 w 50. Lots cheaper.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
Yep. Mineral spirits works best but paint thinner is ok. You want to keep that ratio more along the lines of 1 to 3 or 1 to 4 parts oil to mineral spirits.
Kaffee Nazi
Bikes: 2009 Kestrel RT800, 2007 Roubaix, 1976 Lambert-Viscount
From Yahoo:
"Synthetic motor oil now days is certainly thin enough for chain use. the molecular structure of synthetic oil is fantastic and is great at what it is designed to do - resist high sheer loads in an engine. That is all it is really good for. On a chain you do not have sheer but rotational friction inside the roller at the pin. That is actually the only place that the lubrication is necessary. The very reason why chain lubricants are made to penetrate is the outside needs no lubrication.
You don't want to use motor oil because it will:
1. Sling off the chain as it it made to film off of parts and be pumped though a filter and back into engine parts. Engineers worked really hard to make it perfect for that job.
2. Attract dirt. Another property that those good petroleum engineers did was make a product that carries the contaminants to the filter. Bikes don't of course have that filter so the gritty material will wear your chain and gears.
3. It is wash out resistant. Good for resisting rain, but it resists mild chain cleaners too. Oh, you can cut it, but usually to remove it all you need a solvent not detergent.
The types of products you want for a chain:
1. Wax based "dry" lubricant. This is a modern formulation of a wax made to emulate paraffin that used to be melted onto chains. This new chemical mix is a carrying solvent and wax that penetrates where you need it and the solvent evaporates leaving the wax behind to do the lubrication. Since wax is dry no attraction of dirt. Wax is also very water proof so it's good in the rain. Draw back is that this formula is the hardest to clean off a chain, and your chain had to be thoroughly cleaned of any petroleum before using. It won't stick to the metal of the chain with a petroleum film in the way. Read the label.
2. Dry Teflon Lube. Very good lubrication as Teflon is the slipperiest substance known. It works with a carrying agent just like the wax. It is a bit wetter as the carrier has a light oil to try to keep the Teflon in place as Teflon itself is transferable. Too slippery to stay on it's own when not baked on like a frying pan. Teflon as a lubricant is like tiny micron sized bearings and they are in the plastic family. They wont break down in water but can be flushed out easily with detergents that break down the carrying oil.
3. Wet lubes. Think of them as just better oil for the task than motor oil. They still attract dirt and need more cleaning. Water resistant to rain and actually the best choice in the rain, as long as you know you will have a cleaning job when you are done in the rain.
4. New tech ceramic impregnated lube. This is the new twist on the wax and Teflon. A carrier bring ceramic powder that burnishes onto the metal. It takes a couple applications to get it right with break in riding in between. (read the label) It promises to be the best of all words -- if it works.
Source(s):
29 years in the Specialty Maintenance Chemical industry. We make the stuff."
Source(s):
Bikes: Old Bike: 1975 Raleigh Delta, New Bike: 2004 Norco Bushpilot
Liked 5 Times
Motor oil might work in a pinch, however it's intended for a different purpose, cooling of high heat engine parts, resisting the products of combustion, carrying dirt to the oil filter. As time goes on the engineers make it less and less suitable as a general purpose lubricant.
From Yahoo:
See Sheldon Brown's article on this.
2. A bicycle chain is typically not enclosed in a chain case, at least in the US. It's going to get dirty no matter what lubricant you use.
3. The $10 1-gal jug of biodegradable citrus degreaser from Home Depot works really well for me.
Although certainly not optimized, motor oil for lubricating bicycle chains is fine, as orated by the Great Jobst Brandt.
With regular cleaning/maintenance, my motor oil-lubricated chains have lasted me more than ten thousand miles, each.
Where in India are you?
I use Singer sewing machine oil. Easily available and works OK. I clean the chain off the bike with diesel, dry and immerse it in a pie dish with oil, but you could use it from a dropper too.
Quoted: 19 Post(s)
I have tried all the chain lubes made for bicycles, what a scam. I do not like any of them.
Tungsten Disulfide and Molybdenum Disulfide (MoS2) may be the best dry lubricants. But on chains it may still need a highly viscous oil. Thew price of Molybdenum is going up because they have found that it improves batteries.
Long Chain Fluorocarbon – Teflon PTFE is a saturated aliphatic fluorocarbon, and maybe the most slippery substance known, but I would not want to use it even if it were affordable.
Only when a dirty chain is oiled, or has excessive oil on it, can this grit move inside to cause damage. motorcycle chain and chainsaw lubricants are better yet, because they have volatile solvents that allow good penetration for their relatively viscous lubricant....
Pins inside full bushings of (six element) chains are well protected against lubricant depletion because both ends were covered by closely fitting side plates. Some motorcycle chains have O-ring seals at each end. In the swagged bushing design there is no continuous tube because the side plates are formed to support the roller and pin on a collar with a substantial central gap. In the wet, lubricant is quickly washed out of pin and roller and the smaller bearing area of the swagged bushing for the pin and roller easily gall and bind when lubrication fails. Jobst Brandt
Maybe I didn't mention that this viscous lube lasts several months!!!
Viscous oil verses Dry Wax lubes:
Viscous lube will stay in your chain much much longer than anything else, but there is a chance that it will absorb dust and grit into the chain links.
But only when a dirty chain is oiled, or has excessive oil on it, can this grit move inside to cause damage.
To make oil viscous enough you need a soupy like substance such as aluminum oxide, STP uses zinc oxide. Thin it with Naphtha to flow it into the links from an eyedropper. Be sure to let the distillate evaporate before riding. Aluminum oxide or stearate can be acquired from artist paint maker suppliers.
This viscous lube lasts several months in dry conditions!!!
Motorcycles used to use viscous lubricant, but are now using dry wax lubes that are diluted by solvent so you can spray it on the chain. I believe that the wax pushes out of the chain too fast, but maybe floor wax is hard enough to stay put, but it would need to be hard as nails to keep it in the links for more than a few days. Maybe if floor-wax was mixed with a little bit of Molybdenum Disulfide and thinned out enough to penetrate?
Teflon PTFE is a saturated aliphatic fluorocarbon polymer, please don't add more Teflon to the environment!
I think the best solution could be Tungsten Disulfide or Molybdenum Disulfide (MoS2); dry lubes that can be mixed with an evaporation solution so it would flow into the chain links. But I do not know what would keep it there, other than a tiny bit of 'not-too-viscous' oil (STP is too viscous by itself, add a little light oil before adding solvent).
All other chain oils are variations on sewing machine oil. Bike shops tell you that the thin stuff washes out the road dirt from your chain. And it may actually do that to some degree if you lube your chain often enough. But I hate having to lube my chain or do any work at all on my bicycle in the winter. And the thicker the oil is, the less likely that dirt will get into your chain.
Quoted: 3469 Post(s)
Liked 1,473 Times
Another vintage thread from the past.
One thing the OP should be able to find in abundance in India would be either Kerosene or Diesel. Using a mix of either with motor oil would work just fine.
Bikes: Trek Emonda SL6 .... Miyata One Thousand
Quoted: 63 Post(s)
Liked 29 Times
use the same stuff that they lube scooter/motorcycle chains with in India
there are zillions of them riding around
Quoted: 760 Post(s)
I've used DIY lube for years, after trying all the expensive mainstream lubes.
ATF does not have a lot of lubrication properties - it is mainly a light hydraulic oil with a lot of detergent. Yes, yes, it has some lubrication properties, but the bushing clearances in a automatic trans are much greater so they can get away with it.
