Univega Superstrada: can it be cleaned up?
I originally bought this for the Suntour Superbe groupset on it. Initially, I thought the frame was too far gone. I am no expert, but the workmanship is very nice on this frame. The rusted areas are "solid" for the most part; tap on these areas with a screw driver and they still seems solid. Well, I am re-thinking this frame. I know an auto body guy that may be able to paint the effected areas. But will paint hold? Does anyone have experience trying to spruce up rusted areas like this? Or am I headed down an expensive road with a bike that is not fixable. Any opinions or experiences out there to share?
Bikes: '68 Raleigh Suberbe, '92 (German) Centurion Equipe, '85 Schwinn Peloton, 1983ish Zunow Road Racer project, '69 Squanch Super Tourer, 1980 Bianchi Super Corsa, '82 Austro-Daimler Vent Noir, '89 Miyata 914 project, 1982ish Bianchi Rallye
Quoted: 294 Post(s)
Liked 9 Times
Hard to say. Pic 6 looks the worst. Looks like the lug point is almost gone? Might be an illusion.
I would guess that if you drill w/wire brushed these areas you'd find the damage minimal, but sometimes it is worse than it looks. A bit of rust can bubble up paint a lot, though, without eating very much steel away.
You should remove the paint down to bare metal in those spots and look very carefully. And then have a neutral party do the same. Then rust treat and prime while you decide the next step.
If there aren't deep pits or holes, the frame might be fine.
Agree. You'll need to clean all the rust off to properly check the frame. Go slowly, don't grind, or aggressively sand good metal away. Those tubes are very thin, so be careful. That's a shame, that was a sweet frame.
Should I use a steel wire brush or brass?
Quoted: 294 Post(s)
Liked 9 Times
Brass if you got it. But a steel brush is fine as long as you stop when you hit metal. If you brush through the steel then it was rusted through anyway.
Show us pics when done!
Probably okay. Some people soak a rusted frame in a weak solution of oxalic acid to remoe the paint. Somone will probaly explain it in detail in a few more posts.
Bikes: '73 falcon sr, '76 grand record, '84 davidson
Quoted: 59 Post(s)
Liked 22 Times
remove the rust in any number of ways, touch up the paint (or not), rebuild, and ride.
As others have said, clean all those rust area down to clean metal. Check them for weak spots. If it seems solid you must treat and prime. Then decide what level of paint finish you want, perfect being a full repaint to beater/rider for a spot paint blended in.
Good luck, those Univegas are nice frames.
That ain't just any Univega!
It looks like you can still save it at this point, but it should be obvious once you hit the rust with a wire brush. The worst seems to be the bottom point of the upper head tube lug. You may have to build that up with bondo or putty and sand to get the shape back.
Also check inside the tubes.
As nice as it would be to save the original tomato soup red paint job, it would probably be easier at this point just to strip the whole thing with chemical stripper, do the wirebrushing, prepping and priming yourself, and then take it to your friend to spray.
You need to send that frame/fork to me. Problem solved.
Too nice quality frame to throw away.
Seriously though, soda blasting (not sandblasting!) the rusty spots, touch-up or overall repaint, and 'frame-saver' treatment of the inside of the tubes.
BTW, what year is that frame? Serial number??? Many Univega frames of the 80s were built used by Miyata and used the Miyata serial numbering system.
M is the year of manufacture, which is 1984 according to the Miyata serial numbering system. BUT, looking at the 1984 Univega catalog, the Superstrada came in gunmetal gray only that model year. HOWEVER, bikes manufactured September through December would be 1985 models, and still have the 1984 serial number. The '85 Superstrada came in tomato red.
It's been a long time, but IIRC Univega was just starting to farm out their cheaper models to cheaper subcontractors at this time. The mid to high range was still Miyata made. I remember putting a couple of these tomato bikes together BITD. They were a great bike, especially for the price, but they didn't sell that well, at least at my LBS.
I just was doing some more research, and found the OP's post from January here on BF.net with the serial number -- T-Mar gave you the year --
So there we have it. 1985 model Superstrada - which was Univega's second-from-the-top racing model. Triple-butted frame tubes, Cr-mo stays, and fork. Very similar to the '85 Miyata 'Pro Miyata' in specs, which was also equipped with SunTour Superbe Pro components.
Definitely worth trying to save that frame. That one looks to be a 54cm frame.
Quoted: 4722 Post(s)
Liked 3,036 Times
Several possible approaches:
1. strip and repaint.
2 remove the visible rust, neutralize and touch-up the affected areas.
3. remove the visible rust, neutralize and clear coat the affected areas
4. use as is
5. sell the frame
Ultimately, the choice will come to the OP's relative weighting of aesthetic versus financial considerations.
4. use as is
5. sell the frame
I forgot I had posted on this bike before. The first letter of the serial could be and N or M. I believe meausured it awhile ago, 56cm. Some people may not agree with this, but I think this frame is a good candidate for conversion to STI. Maybe used group, 105 or Ultgra.
bentrider
Bikes: Trek R200, Bike Friday NWT, Radius Hornet 2, Cruzbike Sofrider, Vision R-40 BF/ R-42, Actionbent Litespeed/ Jetstream, Bacchetta Giro (20 and 26), Tern Verge P9, Ryan Vanguard, Burley Limbo, Rans Stratus/ Wave/ V-Rex, Dahon Helios, others...
Quoted: 14 Post(s)
I wouldn't consider 105 or Ultegra an upgrade over the top of the line Suntour Superbe Pro in any way. More modern..yes.. but better? Not really. Unless you are just after more convenient shifting.
Yes, you are correct. I should have phrased my comment that way. Personally, I'm 'old school' on all of my road bikes - they all wear SunTour barcon friction shifters!
Yes, looking for more convenient and smooth shifting. I have more than enough 7 speed friction bikes.
+1, one big advantage to many of these eighties frames is that they can handle 28 mm tires. I,m thrilled with the way my last conversion (Gitane Trophee 1980) rides With 28 mm Gp 4000 and ten speed Ultegra. My 87 Team Miyata takes 28 mm so maybe this frame also does.
Soda won't remove rust. If you want to protect the good metal, try Evaporust. Designed to work by submersion, you can wrap the affected areas in rags soaked in Evaporust,cover in plastic to keep wet, then, hours later, rinse well with water and dry immediately. It will NOT hurt good metal. Buy at auto parts stores. Best stuff I've ever used on vintage,rusty car parts. It's the Holy Grail for saving rare steel.
