cantilever verses v brakes
I have a few older mountain bikes. One is my commuter and the other I use to ride dirt trails. What I am wondering is if I change from cantilever to v brakes will there be any gain in braking performance? Which on is better for street and the same for dirt.
Still learning
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times
You can change from canti's to V's - BUT you will need to change the brake levers to ones compatible with V's, which require more cable pull.
V-brakes are less expensive, and easier and much faster to set up.
Once set up correctly, both V-brakes and Cantilevers work very well.
I have bikes with both types, and would not change them just for the sake of change.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
For all practical purposes, V-brakes are way better. The main advantage of cantilevers is that they can be adjusted to fine tune mechanical advantage versus rim clearance. The down side of that is that it is possible to set them up poorly, and depending on the design of the cantilever it may be easy to do so. V-brakes are way easier to set up and adjust.
I would switch any bike with a non-drop handlebar to V-brakes as soon as budget allowed. Note that you will need to replace the brake levers too, as V-brakes require more cable pull.
My Bikes
My Bikes
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Which raises the question: what drop bar brake levers would work best with V-brakes?
www.rhmsaddles.com.
www.rhmsaddles.com.
Keener splendor
Bikes: Yes
Liked 3,868 Times
My Bikes
My Bikes
Quoted: 1627 Post(s)
Liked 630 Times
I had a pair of V brakes on my C-dale ST600 when I bought it. They worked great, but were very grabby. I switched back to cantis and got the better modulation I was looking for.
@cncwhiz, PM me if want to pick up a pair of Shimano BR M600 brakes cheap.
Quoted: 3811 Post(s)
Liked 6,707 Times
I've been running Nashbar v-brakes on my primary commuter for the last couple of years, both with drop bars and with upright bars (and different levers, of course). Braking power is excellent, and modulation is just fine.
I've been at it since 1976 and never had a problem with cantilevers. I only 150 lbs so just about any brake works well for me. Folks read way too much internet BS and believe it as Gospel. Cantilever brakes work well when set up correctly.
Quoted: 821 Post(s)
Liked 255 Times
I have Paul Neo/touring combos on two bikes and Campy CX cantis on another.
Zero issues.
The best thing you can do to any brake is add Kool Stops.
All three are ridden hard on mud, gravel and our city streets.
I am pleased to report that I have not been involved in fiery crashes while riding these bikes.
Quoted: 821 Post(s)
Liked 255 Times
Best "fix" you can do right now.
Yes, they are better than stock pads.
Quoted: 1608 Post(s)
Liked 2,216 Times
Looks like Cane Creek also offers a lever for V's. Dia Compe made some as well, often found on tandems. One of them usually has dual cable capability for operating two calipers at one time while using the the other for the rear drum brake.
Quoted: 2432 Post(s)
Liked 638 Times
My canti's are pretty much as powerful as my v-brakes and they have better modulation as mentioned. That's important on a MTB with tight singletrack. The trick is setting your toe in and yoke height correctly. You know you have it right when you have a firm lever, otherwise they'll feel a little mushy. Black (not red) Kool Stop pads are freaking awesome. I do love v-brakes, they're very easy to set up.
Agreed.
Zero issues.
Zero issues.
Fresh Garbage
If you don't want to change your brake levers you can also look up mini-V brakes as an option. They're made to work with road levers.
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
Its also because I find cantis to work perfectly fine for how and where I ride. I am 230, no lightweight, yet I stop in a distance that I find acceptable with cantis.
Vbrakes seem to grab and 'stick' much faster, at least based on how I use them. I dont want to lock up the wheel every time I touch my brakes.
As was just mentioned, you can get mini-Vs and use the same brake levers as you have for cantis(or caliper) brakes.
I have old DeoreXT cantis from 1987(I think) and a couple sets of Diacompe which are XCM and XCE level. These are all 35+ years old and work perfectly fine with new pads installed. As mentioned, it just requires setting them up properly and vbrakes for sure set up faster .
Bar Ends Forever
I love v-brakes. Even the cheaper ones I've used feel really smooth and stop great. I plan on converting both of my mountain bikes to v-brakes at some point.
They don't look as good as cantilevers but I'm more interested in being able to slow down my bike efficiently.
MA is lower in the V brake Hand lever ,. because the MA/ cable pull demand is Higher in the V brake ,
Cantilever is a Higher MA in the hand lever and a bit lower MA in the calipers.
The pad to rim requirement for operating clearance , is much tighter with V brakes .
https://en.wikipedia.org/wiki/Lever
'Better' in the end, is just an Opinion.
Bikes: Yes
Liked 3,868 Times
I think this is kind of like single pivot versus dual pivot caliper brakes. Pretty much any brake out there will be capable of generating enough braking power to exceed the traction of your tires. It's just a matter of how hard you have to squeeze the lever to get that power and what it feels like between initial engagement and max power.
If you're the type to obsess about brake feel cantilevers are pretty much perfect because you can adjust them to get nearly any feel you want. If you're the type who likes to attach a cable and be done with it, cantilevers are awful because you have to adjust them to get the feel you want.
I have relatively weak hands so I like really responsive brakes. Even my otherwise vintage road bikes have dual pivot caliper brakes. For rim brake bikes with post mounts, I prefer V-brakes over cantilevers. For the bikes with disc brakes, I really like hydraulic discs.
The one exception to the above is my cyclocross race bike. I'm still using cantilever brakes on that because modulation is extremely important and easy brake engagement gets me in trouble. In almost every other situation, I prefer being able to stop with minimum lever pressure.
In theory, it is possible to set up cantilever brakes to have the exact same feel and mechanical advantage as a V-brake, and with flat bar levers this is even possible in reality. The big difference is that with V-brakes the only thing you have to worry about is attaching the cable so that the pads are the right distance from the rims. With cantilevers, the braking power varies with yoke height and a small difference in yoke height can make a pretty big difference in braking performance.
My Bikes
My Bikes
Bikes: Yes
Liked 3,868 Times
BTW, if you want to really geek out over cantilever brakes check out this online tool that gives you a visual model:
MAITOY: Cantilever Brake Geometry
For some reason it doesn't work in Chrome (at least, it doesn't for me) so you might need to dust off Internet Explorer if you're a Windows user.
My Bikes
My Bikes
Quoted: 821 Post(s)
Liked 255 Times
I'm pretty familiar with two local cross teams.
They use "mostly" cantis, with a few using Vs.
All of them seem to be doing pretty well with their choices.
To quote a friend, "brakes, who needs brakes? "
Look folks, if you really want an upgrade go with Shimano discs.......
Bikes: Schwinn Paramount P15, Fisher Montare, Proteus, Rivendell Quickbeam
Quoted: 12 Post(s)
The thing I don't like about V's is that the pads have to be very close to the rim in order to brake properly. Canti's allow a little more space which is better when your rim is slightly out of true so it doesn't rub.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
I like the look of cantis than any other brakes- better than any sidepull or centerpull brakes.
As far as the differences between canti and V-brakes... I haven't messed with a whole lot of V brakes- but they've both been great brakes. I've had issues with roller cam brakes- but I figured out the problem was the levers I was using, not the brakes or their setup.
Commence to jigglin’ huh?!?!
