Built A Bike Stand Today
One of the obstacles of commuting is making sure you are prepared and then getting out the door. Each year when I get my bike out and ride I have to park it way off to the side or behind things. 100% of the time it’s a pain. So … I buil a bike rack out of pvc pipe. I haven’t glued it yet, nor have I put any sand in the bottom pipe to add stability, but I think it will work just fine.
I based my design on someone else's and linked to it in the below post over in Clydesales & Athenas.
https://www.bikeforums.net/20176550-post3.html
Non omnino gravis
Bikes: ...a few.
Quoted: 2010 Post(s)
Liked 408 Times
Very cool designs. I like the PVC just because I can see leaving and using it outside all winter to spray down my bike without having to lean it against the kids' basketball post. The more stylish ones just wooden work
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,103 Times
"Honey, have you seen my cutting board?"
Genesis 49:16-17
Genesis 49:16-17
Non omnino gravis
Very nice, @DrIsotope, you have some abilities that are beyond me.
As for what I just produced, I have to modify it. I just put on the Topeak rear rack and now the rear wheel won't fit in there. I've already got a modification in mind, I just have to see if they make the pvc elbow I'm wanting.
A PVC stand, similar to the one you made, was my first bike stand. However, I have since replaced it with a superstand I got for cheap, plus an additional superstand knock off. These stands did not cost much more than the materials needed to make the PVC, but I did already have the PVC pipes from putting in sprinklers a few years back which is why I made one.
The biggest downfall of the PVC stand was the footprint it required. I didn't use glue or sand with mine and it held the bike fine. If you don't use glue, it is easily customizable for wheel size.
Non omnino gravis
