Basic Tools - Cone Wrenches - What's your advice?
Bikes: Stevenson Custom, Stevenson Custom Tandem, Nishiki Professional
Quoted: 367 Post(s)
Liked 196 Times
I am reading, Bicycling Magazine's "Complete Guide to Bicycle Maintenance and Repair" (1990) with a cover recommendation by Greg LeMond no less, I found this book in a used bookstore in pristine condition. So the first thing I will try to learn how to do is service my vintage hubs (they range from Campagnolo, SunShine, Shimno, etc.) and wondered which size and what brands of cone wrenches you would recommend and how many of each? Also will they all work on the different hubs I've mentioned, my guess would be yes, but again a guess, as I will be servicing bikes ranging from 1972 to the late 1980s.
As to brand I am more a quality vrs a. vintage name person, but if they both match up that's fine too. By quality I mean my S&K socket set I got at 16 which 50 years later works and looks like new. You can get what you pay for.
My thanks for your advice and for any suggestions on tutorials/YouTube videos you've found that were helpful in learning how to service hubs.
Quoted: 887 Post(s)
Liked 335 Times
I have Park and Pedro's cone wrenches and like them. They're not too pricey and work well.
The standard basic cone wrench set was a pair of 13/14mm double sided, and a pair of 15/16mm double sided. For example: (2) Park DCW-1, and (2) Park DCW-2. This will be sufficient for most vintage quality hubs, campy, normandy, etc. You may run into 17mm lock nuts occasionally, but you can use a regular 17mm combination wrench for those. Metric combo wrench set also recommended.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,480 Times
You can work on any vintage bike with four wrenches: three double-ended park tools (the dcw series) and an adjustable wrench.
My three dcw double-ended wrenches are two of the 13/14mm variety and one 15/16mm. On occasion, it would be helpful had I a second 15/16mm wrench, but I make due.
On occasion, I also use my socket set.
These dcw wrenches are about $7/ea on ebay.
Quoted: 367 Post(s)
Liked 196 Times
Thanks exactly what I hoped to learn will add these tools to my Bike Tool box.
Bikes: 86' Centurion Ironman
Quoted: 628 Post(s)
Liked 316 Times
For a front hub , a skinny cone wrench I use for the inside cone . For the skinny nut that goes on the outside against the fork , I use a thicker wrench . Easier for me to keep the thing on .
Tools are a collector item for me , It's hard for me to have too much . I'm almost to the point of needing one more tool box .
Quoted: 4806 Post(s)
Liked 3,928 Times
I have a pair each of 13/14s and 15/16s that are nothing special and that I have been using since the early '80s. Never saw any need to go better, They have held up just fine and work as well now as when new. I sometimes use a 17 for the locknut, but almost every locknut I've seen has been quite hard and ordinary crescent wrenches work just fine. Which ever is closer I use. I don't use the cone wrenches for the outside nut. Good chance of slipping and damaging the wrench.
Ben
Ben
Quoted: 237 Post(s)
Liked 83 Times
You only need nice cone wrenches in a shop setting since the cheap ones tend to wear/round/bend quicker due to being so thin. For annual hub rebuilds for the home mechanic, cheap ones that come in a $50 bike tool set work fine. Just don't try to abuse them as pedal wrenches. What will make hub adjustment considerably easier though is a way to keep the axle in place while you manipulate the cone and the locknut.
Quoted: 4559 Post(s)
Liked 2,802 Times
My no-name cone wrenches have sloppier tolerances than better cone wrenches, but so far it hasn't been a problem because cones and locknuts don't involve too much torquing. The problem is with the same kit's no-name thin stamped metal wrenches intended for bottom brackets and other components where the sloppy tolerances can result in slippage and rounded off nuts or even bending the tools.
Ditto the advice to try a generic tool kit. I got a kit labeled Venzo VPT from Amazon a couplafew years ago and most of the tools have been very good. In particular the chain tool is so good it makes up for the less satisfactory bottom bracket tools. I've added a few better quality tools here and there but only after determining the kit tool wasn't quite stout enough, particularly for bottom brackets. Nashbar used to sell some pretty decent tool kits, but the Nashbar marque is in semi-limbo at the moment, no idea whether the new owner will stock the same tool kits.
Quoted: 628 Post(s)
Liked 316 Times
I have some Pedro's stuff .
https://pedros.com/about-us/
Not bad for $20 .
https://www.jensonusa.com/Bike-Hand-...iABEgKJ0vD_BwE
Not bad for $20 .
Quoted: 1627 Post(s)
Liked 630 Times
I bought a set of Ice Toolz 13x14x15x16x17x18 on eBay. Good value, but they are pretty thin, so if you abuse them they'll get damaged.
https://www.ebay.com/itm/37X3-37A1-3...cAAOSwdx1aDs1R
Quoted: 796 Post(s)
Liked 522 Times
Liked 3,928 Times
Ben
Quoted: 235 Post(s)
Liked 349 Times
I have a set of Sugino and a set of really old, can't remember the name of but they still work wrenches. You can still find these Suginos on "auction" sometimes. I clean them and put them back into case when I'm done, so they still look good - my other ones.. well I don't want a picture of those! For the amount of time I use them, what I have works fine for me. I used to work In a bike shop, so appreciate quality tools - but I also need to be reasonable about considering price for home-use tools.
Quoted: 90 Post(s)
Liked 137 Times
The first set I got when I got back into repairing bikes 12yrs ago came in a Nashbar set of tools I bought, then I added some Pedro's & Park. I really like the Nashbar & Pedro's better then the Parks, they just hold up better, in fact the shop I help at also bought some Pedro's to replace the worn out Park wrenches. I have had park wrenches round over with some really tight cones in the past. I use my cone wrenches more then most home shops would.
Glenn
Glenn
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
https://www.parktool.com/product/axle-vise-av-1
Quoted: 367 Post(s)
Liked 196 Times
Again, just what I needed to find out in this discussion, great help. I have started watching some of the choices available on the bay, but will also check out LBS. It's good to have a brick and mortar in town.
Quoted: 367 Post(s)
Liked 196 Times
But now I have an additional question. I have found that cone wrenches can be made in a single size jaw, 13mm, or in a double sized jaw , 13mm and 14mm, etc.
Is this a good or bad idea?
How does this work out in practice?
Is it better just to stick with the single size jaw and avoid the stresses put on the bigger jaw located out at the end of the jaw where there is a lot less metal to take the stress of a reluctant nut?
Thanks for your advice and thoughts.
señor miembro
Liked 6,480 Times
The only bad thing about the double-sided tool is sometimes you need a comfortable handle to remove a stubborn nut, and the tool can hurt your hand. So I use a rag on the end.
For the home mechanic, the positives outweigh the negatives.
Quoted: 367 Post(s)
Liked 196 Times
So here is how I've ended up, but first background on the choices. I started in Vintage bikes with a Nishiki Professional and have since added five more vintage Japanese racing bikes. So when I came across these used, and from pictures in good condition, Sugino cone wrenches, their price and the quality I have found in Sugino components just struck a cord. I have a lead on an additional 15/16 mm cone wrench and will soon have a set of two in each of these necessary sizes.
My thanks.
Liked 630 Times
My thanks.
Quoted: 235 Post(s)
Liked 349 Times
Funnily enough, I still have the set of Sugino cone wrenches I bought when I was 13 or so. A long time ago. They are very solid and worth looking for. At the time they were the cheaper alternative to Campy wrenches, but the quality and function is similar. They're just not quite as pretty. It wasn't unusual for shops to use these. Usually there were a few campys, a few suginos, maybe some old VAR.
