Chain Life
Chain Life
Old 07-15-13, 06:51 PM
lawnerd
Bikes: Merlin Ti Frame, Marin Point Reyes
Chain Life
Hi. I just started commuting by bike and I have a question regarding how often I will need a new chain.
My commute is 22 miles each way. I have a 13 year old Marin Point Reyes. I never knew that you should check for chain wear and I have driven the bike regularly over the past 13 years (probably about 1 to 2 K miles per year. So, I checked it for wear and found that the chain was worn and that the cassette and chainrings were worn. So, I replaced the entire drive chain. I've done searches on chain life time and have seen some folks claim that you need to replace your chain every 500 miles! If that is true I'll need a new chain every three weeks.
So, commuters, how often do you need to change your chains? What do you think is the average life of a decent Shimano chain?
lawnerd is offline
Old 07-15-13, 06:59 PM
alan s
alan s's Avatar
Quoted: 1496 Post(s)
Liked 189 Times in 128 Posts
Chain life depends on how often you clean, how far you ride, and whether you ride in the rain or offroad. Get a chain checker, clean frequently, and replace when worn out. The particular brand of chain is not important. Get a Connex link to remove for cleaning.
alan s is offline
Old 07-15-13, 07:30 PM
J.C. Koto
apocryphal sobriquet
J.C. Koto's Avatar
Bikes: 2008 Surly Long Haul Trucker "The Truckerino"
Quoted: 11 Post(s)
Liked 3 Times in 2 Posts
Chains and chain maintenance are remarkably controversial topics. Assuming normal, non-extreme conditions, and if you keep it properly lubed, you should expect to get at least several thousand miles with the chain. I keep my current chain well-lubed and have a bit over 4300 miles with no noticeable indication of wear (measured with an aluminum rule) so I expect at least another couple thousand at a minimum, but we'll see. Probably about 1/4 - 1/3 of that on super dusty limestone roads/trails so I'm not exactly babying it either.
If you're commuting on normal city-type roads and keep up with a good lubrication regimen you won't need to worry about the chain for quite a while.
J.C. Koto is offline
Old 07-15-13, 09:20 PM
JPMacG
Liked 3 Times in 3 Posts
I get about 2000 miles from a chain. I have tried all sorts of things to extend their life. Different lubricants, different cleaning techniques, rotating through several chains, etc. It doesn't seem to matter in my case. They still last 2000 miles.
JPMacG is offline
Old 07-16-13, 06:38 AM
ItsJustMe
Señior Member
ItsJustMe's Avatar
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times in 7 Posts
I found that with my ride conditions (*) I get about 1800 miles before the chain shows as too worn.
HOWEVER - I found that if I just leave the chain on anyway, the drivetrain continues to work just fine until the whole thing has about 9000 miles on it.
If I change the chain at 1800 miles when the Park tool says to, well, the rest of the drivetrain lasts about 9000 miles before it's worn out, as indicated by the fact that when I put a new chain on, I get skipping.
So, my conclusion is to just leave the chain on and replace the drivetrain every 9000 miles. The alternative is to replace the chain every 1800 and STILL need to replace the entire drivetrain every 9000 miles.
My experience may not be the same as yours but it's the conclusion I've come to.
(*) My route at the time included 8 miles per day of gravel road which really gunks up a chain. I could put a brand new chain on, ride 20 miles in the rain and the next morning the chain would be too gunked up to even bend anymore.
Work: the 8 hours that separates bike rides.
ItsJustMe is offline
Old 07-16-13, 06:49 AM
droy45
tougher than a boiled owl
droy45's Avatar
Bikes: Fetish Cycles Fixation / Fuji S12S / Gary Fisher MTB / Raleigh Grand Prix / Ross Professional / Kent comfort cruiser
Chain wear depends on alot of factors. Weather, conditions, dusty or dirty etc. All chains have a 1/2in pitch meaning 1/2 inch between links. Just use a 12in ruler and measure from a chain pin to the 12 in mark and it should line up perfectly with a pin there when the chain is brand new. Use the top section with pressure on the pedals. As time goes on measure it occasionally and when you see 1/16 - 1/8 in of stretch, it is worn. It will continue to run ok but then it starts to ride on top of your chain ring teeth and cassette which causes them to get wear on the leading edge and you will eventually have to replace the entire drivetrain. I generally get about 1500 miles on a chain but I use mine in winter conditions with salt/snow and grime so that wear is on the extreme side of things.
droy45 is offline
Old 07-16-13, 06:50 AM
KevinF
Keep on climbing
Bikes: 2004 Calfee Tetra Pro
Quoted: 26 Post(s)
Liked 2 Times in 1 Post
Put 20 cyclists in a room and you'll get 20 different opinions on chain wear, maintenance, etc. So this thread won't be coming to any sort of definitive conclusion.
I tend to get ~2500 miles out of a chain. I clean it on-the-bike once a week (~150 miles or so), re-lube it, and that's about it. I have one of those Park Tool "chain checkers", but I find that they indicate that the chain is "worn out" long before my trusty ruler indicates that the chain has stretched 1/16". (One link is exactly one inch, so on a brand-new chain, one foot should be exactly 12 links).
To clean it, I just spray some degreaser on a rag and scrub away. Seems to get it reasonably clean. I've used other chain cleaning methods, and no matter what I do, within 50 miles, it's looking like I never touched it.
All kinds of good info is here: https://sheldonbrown.com/chains.html
KevinF is offline
Old 07-16-13, 11:36 AM
xtrajack
xtrajack
xtrajack's Avatar
Bikes: Kona fire mountain/xtracycle,Univega landrover fs,Nishiki custom sport Ross professional super gran tour Schwinn Mesa (future Xtracycle donor bike)
Pretty much the the system that I use. I replace the entire drivetrain every spring
xtrajack is offline
Old 07-16-13, 11:44 AM
alan s
alan s's Avatar
Including the crank? If so, it gets a little expensive.
alan s is offline
Old 07-16-13, 11:52 AM
baron von trail
baron von trail's Avatar
Bikes: 3 good used ones
Quoted: 83 Post(s)
Yep. My experience mirrors this. If I do nothing but regularly clean and lube my chain, the whole drive train lasts about 5 years before the thing won't shift smoothly anymore. That's maybe 12,000 miles, give or take. If I get anal, meaning go by what the gage tells me, I'll be replacing chains every year.
I am currently running on a chain and drive from 2009 that is today a full 1/4 mm over the max (replacement recommended about 1/2 mm ago). But, she still runs well. The chain and drive will probably be OK through winter. I expect to replace it or the entire bike in the spring--bike is a 2004.
baron von trail is offline
Old 07-16-13, 11:55 AM
baron von trail
Quoted: 83 Post(s)
The ruler shows only stretch, not wear. The gage thingy shows actual wear. If that matters to ya.
Old 07-16-13, 07:12 PM
gerv
In the right lane
gerv's Avatar
Bikes: 1974 Huffy 3 speed
Quoted: 44 Post(s)
Liked 7 Times in 6 Posts
Probably just one chain ring.
gerv is offline
Old 07-16-13, 09:35 PM
Mr. Hairy Legs
Super-spreader
Mr. Hairy Legs's Avatar
Location: where black is the color, where none is the number
Bikes: shiny red tricycle
Quoted: 1167 Post(s)
Liked 101 Times in 97 Posts
If you're riding in wet/crummy conditions it can wear out in 500 miles easily. Otherwise, I'd expect to get at 1000 before worrying about it.
Mr. Hairy Legs is offline
Old 07-17-13, 04:13 PM
ItsJustMe
Señior Member
ItsJustMe's Avatar
Quoted: 446 Post(s)
Not if you buy cheap cranksets on sale. I think I paid $15 for the crankset that's hanging new in the box in the garage right now. Normally $50 I think.
But no, I normally do not replace the crankset, just the chain and cassette.
On some cranksets it might be possible to flip the chainring and get double the life out of them. Not always though, depends on whether the chainring is offset from the crank.
I could replace just the chainring with the most wear, but given the price of entire cranksets that I buy (I got one on clearance from Nashbar for $8 once, for a triple), it's actually cheaper to just replace the whole thing.
Old 07-17-13, 04:26 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
chain wear can be measured, you change the chain when it exceeds the chosen limit..
More often and the other stuff the chain contacts, lasts longer,
let it go and replace everything else, is the other plan. guess that one chose you.
fietsbob is offline
Old 07-17-13, 04:52 PM
wolfchild
Quoted: 4227 Post(s)
Liked 2,488 Times in 1,286 Posts
What's the difference between a stretch and wear ??.
wolfchild is offline
Old 07-17-13, 05:11 PM
DiegoFrogs
DiegoFrogs's Avatar
Bikes: '77 Centurion "Pro Tour"; '67 Carlton "The Flyer"; 1984 Ross MTB (stored at parents' house)
Quoted: 169 Post(s)
Liked 93 Times in 61 Posts
"Stretch" is just the sum of the play introduced in the links due to wear. The chain isn't being plastically deformed. The plates and rollers are being worn abrasively through usage.
DiegoFrogs is offline
coffeesnob
Bicycle Mechanics
22
10-19-16 03:24 AM
crsuperman34
Bicycle Mechanics
25
05-02-14 07:49 PM
ezdoesit
Bicycle Mechanics
5
07-13-10 10:26 AM
jakerock
Singlespeed & Fixed Gear
11
03-15-10 11:08 AM
