CO2 question...
CO2 question...
I'm interested in switching from my frame pump to a CO2 inflator. Will a 16g cartrdige have enough air to inflate a 700c tire to 120 psi after inflating it a little and then deflating it to prevent a pinch flat?
Thanks!
Thanks!
Should Be More Popular
Quoted: 22607 Post(s)
Liked 8,929 Times
Disgruntled Grad Student
Bikes: CAAD 10, Cross Pro, Cross Comp, TK2
yeah, 12g cartridges are plenty. Best method I've found for more than adequate inflation: (i forget what kind of co2 inflator i have, but it threads onto schrader valves, but not presta). Screw schrader adapter to presta valve, screw inflator to schrader end, screw co2 cartridge into inflator. Everything in the system is sealed pretty well, and there's virtually no loss, and no worry about somehow not having enough CO2 per cartridge.
also, I usually have some leftover in the cartridge, which can make for a fun practical joke of spraying your riding buddy on the back of the neck or knee with a cold spritz of CO2. (use at your own discretion)
Gluteus Enormus
Bikes: Yes
What size tire, 23 or 25? I'm inclined to say no, it would probably not reach 120psi if you deflate the tire after a quick shot and then inflate again from the same cart.
Quoted: 1186 Post(s)
Liked 289 Times
Normally, when I hear pinch flat I think of a flat caused by hitting a bump and having the tire bottom out on the rim pinching the tube and creating two small holes i.e. "snake bite". I presume you're referring to having a small portion of the tube protruding out and pinched between the tire and rim. I just visually inspect the tire to make sure this isn't happening.
Bikes: IRO SS / Trek 2.1 / Trek 5.1
oh, didnt even see the thing about using some, then deflating.... idk if that works, but its unnecessary, as described above. if you really want to inflate it some to check, maybe carry a crappy micro pump to augment your CO2 use - just enough to check things out, let the CO2 do all the work, but youll have the pump onhand if things get really dire?
Bikes: 2007 Trek Madone 5.9 (Shimano DA), 2008 Kuota Khan (SRAM Red), 2009 Giant OCR2 ( Shimano 105 ), Lynsky R340 ( SRAM Rival )
Yes, I inflate, bleed it down, then inflate to 120 psi, still have some left.
Oh and carry at least 2, I carry 3 or 4 if going for a long ride.
I usually just give it one little shot to give the tube some body and then put the tube in, haven't had any issue with pinch flats. I carry 16 gram cartridges, and while I don't know how high the PSI gets I don't need to use the whole cartridge to make the tire feel fine to ride home on. I decided to get the "full feature" CO2 inflator that has a hollow handle that serves as a place to store the cartridge as well. I've heard you can get frost bite if you're not careful with the tiny one. I don't much care about the minor additional weight and it seemed like an easier route to take. I usually carry three cartridges which is probably overkill, but they fit in my jersey fine, and I don't care about the additional weight, so why not?
I just flatted yesterday for the first time since I actually bought the co2 inflater and cartridges. I did pump up the new tube a bit with my mini pump, both to give it shape and give it a head start once it was seated. I used 1 16g cartridge and the tire (23) was rock hard and the cartridge got very cold, which was welcome in my drippy sweat.
Much much much better than pumping the mini pump until my arm falls off, which is what I did in the past.
One suggestion that I'll do in the future is to include a couple of packets of "wet ones". They are similar to the old KFC wipes (napkins with some cleaner fluid built in). Since my rear tire flatted, I got my hands very greasy with the chain. Did my best to clean them off, but managed to get my white bar tape a bit dirty.
Quoted: 551 Post(s)
Liked 277 Times
Put your tubes inside a zip bag with talcum powder. This will enable the tube to "roll out" inside the tire easier and helps to slip away from pinches.
Bring rubber or nitrile gloves and put it in with the inner tube bag.
Bikes: Raleigh R600 105/DA, Specialized Allez Elite 105
BRING MORE THAN ONE CO2 CARTRIDGE. You will be as mad as I was when you happen to screw up inflating it.
Bikes: Cervelo RS, Specialized Stumpy, Schwinn 974
Orr, have you tried black bar tape? It does a great job of hiding rear-flat repair "evidence".
Quoted: 630 Post(s)
Liked 369 Times
edit: You can also install it without touching
To my surprise a little citrus degreaser easily brought back the white bar tape after a messy incident just like yours.
Riding Off to the Next Adventure, RIP
Removal: shift rear DR into smallest cog, release QR, then apply pressure with right hand middle and pointer finger onto derailleur cage to release tension, then push both sides of the QR down to release wheel from dropouts.
The installation is easy enough to figure if you can remove it without getting dirty.
"Well, folks, here's the deal: I'm the best there is, plain and simple. I mean, I wake up in the morning and I piss excellence. You know, nobody can hang with my stuff. I'm just a....just a lean, shaven, American winning machine."
Quoted: 551 Post(s)
Liked 277 Times
I find that putting the RD to the middle cog is easier than putting it in the smaller cog.
monster
Quoted: 12 Post(s)
I have a dumb question...Will a CO2 cartridge lose air if you don't use it? It's been months since my last flat (knocks on wood) and I've had the same 2 cartridges in my bag.
Quoted: 551 Post(s)
Liked 277 Times
Yes it is.
