Presta valve extender
Quoted: 7 Post(s)
Hi,
I own deep section wheels (404 Zipp clincher).
I need 80mm valves.
Is it possible to use inner tubes 60mm non removable core with a valve extender?
All valve extenders that I find or for removable cores.
Thank you.
I need 80mm valves.
Thank you.
Quoted: 441 Post(s)
Liked 470 Times
In theory yes there are extenders that can be used on tubes without removable valves. In practice the ones where you remove the core and install onto the extender itself work more reliably.
Quoted: 7 Post(s)
Do you have a link to those extenders?
thanks!
