650b conversion tire clearance question?
Quoted: 8 Post(s)
Liked 5 Times
My carbon disc braked CX bike that I use for gravel unfortunately has woeful tire clearance in the back. In the image below, you can see while it can clear a 38c tire (true width, it's listed as 42c), it's not enough to actually ride the bike. I'd say the max you can fit is a 36.
I want to put wider tires on my bike, so I've been toying with the idea of converting to 650b. My question is how does tire clearance for a 38c tire translate to a 650b wheel, and does anybody have experience with such a conversion? Will this amount of clearance allow me to clear at least a 650x42c tire (like the Cannondale Slate), since that's what I want to run? If not, how wide of a 650b tire can I use with this amount of clearance?
God bless disc brakes. The 650b conversion would not be possible on a rim braked bike without lots of extra headache.
Ive been toying around with doing a 650b conversion on an older frame I have sitting around. This article has helped figure out what to measure and where. Good luck.
https://www.bikeman.com/bikeman-blogs...sion-guidlines
Bikes: 1997 Rivendell Road Standard 650b conversion (tourer), 1988 Schwinn Project KOM-10 (gravel/tour), 2013 Foundry Auger disc (CX/gravel), 2016 Cannondale Fat CAAD 2 (MTB/winter), 2011 Cannondale Flash 29er Lefty (trail MTB)
Quoted: 167 Post(s)
Liked 5 Times
Measure the width of the seat stays, chain stays, and fork 19 mm lower (closer to the axle) than the widest part of your current tire. That's where the widest part of a 650b tire will fit.
650b (584 mm) rims are 38 mm smaller in diameter than 700c (622 mm) rims, which equates to a 19 mm smaller radius.
Looking at your picture, the stays look pretty narrow for quite a ways. They're designed this way to improve heel clearance, but it does you no favor for tire clearance.
So, it looks like you wouldn't gain much in tire clearance with the smaller wheel diameter. You might be able to fit 650 x 42 mm tires, but maybe not.
Also, changing from 700 x 33 tires (what your bike is designed around) to 650 x 42 tires would lower the whole bike about 1 cm. Not a ton, and CX bikes usually have relatively high bottom brackets. So, probably not a big deal, except at CX races where you'd want the pedal clearance.
Quoted: 1873 Post(s)
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Bikes: Kona Kahuna DL Drop Bar - Sensah SRX Pro 1x11 (2012 Frame), Giant Toughroad GX 1 - Shimano Road Hydro + SLX 1x10 (2018), Diamondback Sync'r - SRAM NX 1x12 (2020)
Quoted: 160 Post(s)
Liked 97 Times
Another note on BB Drop: I converted my bike with a 68mm BB Drop and 170mm cranks to 650Bx42 tires and occasionally had my foot hit the ground when pedaling. I was also running flat pedals so running clipless should yield better results. If you have a 60mm BB drop you should be fine.
Also since you didn't mention the fork I assume you have ample clearance there...
