Help finding Kestrel 4000 PRO SL seat part
I have links to both my bike and parts but as a new user I'm not allowed to post links. I apologize for the workaround I'm submitting. Thank you to the community.
I was gifted a Kestrel 4000 PRO SL (Kestrel bicycles -> 2012 -> Triathlon -> 4000 Pro SL Sram Red)
I went to my local shop for a fitting and was told it is missing the collar on the seat to adjust/set the seat height. I'm also not allowed to upload pictures but in doing my best to describe this, it is the clamp that holds the frame and the seat stem together.
It seems Kestrel has been purchased by another company and I'm hoping this forum can help me find the right part.
The seat post on the Kestrel site is described as "Kestrel Aero Carbon w/Ritchey Clamp System"
I believe I'm able to find this part but it has a couple of different sizes. I'm hoping for some guidance on what size I might need, and confirming I'm looking at the right thing. (Performancebike dot com search for RITCHEY WCS ALLOY 1-BOLT SEATPOST COMPLETE CLAMPSET)
Thank you.
Thank you.
Thread derailleur
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 367 Post(s)
Liked 464 Times
Difficult situation for you. Tri bike with an ovalized collar and low production quantities.
I recommend approaching Ritchey to see if they kept a stash.
I took the below screenshot of an old listing for the model from 2012.
Good luck...
Good luck...
Likes For roadcrankr:
Quoted: 6198 Post(s)
Liked 4,814 Times
You say your are looking for the collar to adjust the seat height. That's on the seat tube, not the seat post. The complete clamp set you list seems only to be for the clamp on the seat post to hold the saddle/seat and only really controls the tilt of the saddle and it's fore/aft position in the rails.
Welcome to BF.
Did the bike shop suggest anything? This is an issue for old bikes with essentially a unique part that is only used on a few bikes. It can be an issue for new bikes too with unique profiling of tubes, bars and stems.
Welcome to BF.
Likes For Iride01:
Thank you. Yes, I think you're right; I'm looking for a different part than what I identified. Do you know how I would describe this part? The bike shop called it a "collar." The shop suggested I call the original owner asking if they had it, and it seems they do not. The picture posted in the replies is indeed the same bike. For additional clarity, the part I'm looking for is just above the red paint on the frame where it meets the stem of the seat.
Liked 4,814 Times
Did you buy it directly from the previous owner or from a listing on eBay or somewhere else. If it wasn't disclosed that the clamp was missing, then you have some recourse to get your money back for the entire bike.
And if you purchased it with a credit card then call the card issuer and see what options they might offer for a bad purchase.
Likes For Iride01:
Liked 4,814 Times
In that case, since you have little invested in it, then you might just get a stainless steel worm clamp and bend one part of it into the Vee to fit the trailing edge. But only if that seatube and seat post use that type compression to hold it snug.
Though admittedly I will have exhausted every other possible avenue to find the proper clamp before resorting to that. Good luck! There are some on Ebay for the aluminum models of Kestral. Isn't that a carbon bike? But again, when desperate enough and not finding anything else, I might would try one if it looks like it might work.
The worst that could happen is you mess the bike up and it breaks so it can't easily be repaired. But that might be after 5, 10, 20 or more thousand miles or kilometers of enjoying the bike by riding instead of just it taking up space unused..
I think there is a 5 post daily limit for noobs till you get beyond 10 posts. So a reply isn't necessary till you get some more input from others that you might want to answer.
Likes For Iride01:
Quoted: 839 Post(s)
Liked 1,064 Times
Here is something that MAY work. This seller gives length and max width and compare with measurements on the outside of your seat tube (not seat post). Fuji Kestrel Aero Carbon seatpost collar Seat Post Clamp 31 x 49mm | eBay If it fits the price is pretty high but you may be able to find another new one on the net with some detective work for less $$ and even if you don't find another less expensive version you have a free bike + $62 for the clamp. A deal i would take any day.
Likes For Crankycrank:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
https://www.aliexpress.us/item/32568...yAdapt=glo2usa
Likes For dedhed:
Quoted: 4415 Post(s)
Liked 1,567 Times
It's a long shot, but Bikesdirect.com is still around and sold Kestrels. Email them.
Likes For Kontact:
All of these replies are very helpful and I am following up on each lead. How do I measure my seat tube? Do I simply take a ruler to it?
Liked 1,567 Times
If you were going to measure anything, it would be the the top of the frame where the clamp wraps around - width and length. But you really need the part built for your frame.
By law, out of business companies have to offer warranty service for a few years. Some company must be doing that. Find out who and ask them if they have a collar to sell.
Likes For Kontact:
You don't. The shape of your post is specific to the frame, and has curves that might be different that of a similar size post.
Likes For mo211:
