are all 1x11 speed cassettes the same?
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 906 Post(s)
Liked 1,934 Times
I know stupid question but have to ask. I have a 1x11 speed and the rear cassette is a VG sport cassette 11-42 so probably a lower quality cassette. My rear derailleur is a Deore M5100 and I have a bar end microshift 11speed bar end shifter. I want to run two sets of wheels and would like to use a better quality shimano 11 speed cassette in the same 11-42 configuration on one of the wheels. right now bike shifts really well if I swap the cassettes am I going to have to make adjustments to the shifter every time I switch back and forth between cassettes? thanks
Quoted: 1838 Post(s)
Liked 1,711 Times
Apart from the cassettes, different free hubs can be slightly different. Unless you buy wheels exactly the same as your originals there is always a chance that the cassettes will not line up correctly. If you have disc brakes, you can also have issues with brake calliper rub
Likes For alcjphil:
Quoted: 3295 Post(s)
Liked 2,127 Times
Likes For Steve B.:
Quoted: 906 Post(s)
Liked 1,934 Times
Likes For Yan:
Really Old Senior Member
It would be totally normal to have to tweek the RDER barrel adjuster a click or 3 when swapping.
Manufacturing tolerances on supposedly identical parts.
