Need specs on current and recent Altus series hubs...
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
Hi Folks!
Don't often create my own threads...but then again...I don't know EVERYTHING!!!
I am updating my own Excel based spokechart app, and since the hubs below are very common in today's repair environment - I need to cover them. Problem is, I've only had physical access to one. Furthermore Shimano doesn't post specs for them online.
First column is the Altus hub# number, second column is the hub diameter and the third column is the left (non-drive) and right (drive) offsets. If anyone one here has recorded them, I greatly appreciate it if you can fill in the numbers for me. Values for diameter and offset are center-to-center for diameter and on-center for flanges.
Thanks!
HB-RM40 100MM FRONT
FH-RM30-7 130MM REAR LEFT
FH-RM30-7 130MM REAR RIGHT
FH-RM30-7 135MM REAR LEFT
FH-RM30-7 135MM REAR RIGHT
FH-RM30-8 135MM REAR LEFT 45.00 34.50
FH-RM30-8 135MM REAR RIGHT 45.00 20.50
FH-RM40-7NT 130MM REAR LEFT
FH-RM40-7NT 130MM REAR RIGHT
FH-RM40-7NT 135MM REAR LEFT
FH-RM40-7NT 135MM REAR RIGHT
FH-RM40-7QR 130MM REAR LEFT
FH-RM40-7QR 130MM REAR RIGHT
FH-RM40-8 135MM REAR LEFT
FH-RM40-8 135MM REAR RIGHT
Thanks!
HB-RM40 100MM FRONT
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
Hi Folks!
Jeff Wills
Jeff Wills
