Help finding an axle
I just wanna ride
Bikes: 2013 BMC Impec
That's what I need. The axle I have is for 120mm spacing and as such isn't long enough to fit my 130mm spaced road bike, and it's solid so I can't use a quick release. I plan to just use a QR skewer so I actually don't need any threading on the axle/don't care about it. It's proven exceedingly difficult to find a replacement axle though. All i can really find is Wheels Manufacturing Axles, Cones & Hub Parts
What sort of hub is the axle for? Cup and cone bearings or sealed cartridge bearings?
I be leave you want a 141mm hollow axle for a 130mm dropout not a 149mm axle.
Someone may want to chime in on this, as I'm not 100% sure on this.
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
I just wanna ride
It's actually 147mm spacing according to my caliper.
Current axle and the hub it belongs to. Ya it's cartridge bearings.
Mechanic/Tourist
Can you let us in on the hub brand - have you checked with the manufacturer or asked a bike shop to check with distributors of that hub?
Quoted: 4210 Post(s)
Liked 3,878 Times
We just did a hub overhaul (actually two, Ft and Rr) on a fixie with very similar axles. We were unable to find the exact replacement through our usual sources so we wire wheeled off the rust after grinding/Dremelling off the axle nuts and two of the four bearings. (The typical uncared for bike used in the Winter and left wet over the Summer makes for a lot of rust).
I have seen retrofitting an axle which has threaded sleeves (held in place with lock nuts) which the bearings slide onto. This allows for a "standard" axle (w/out ground diameters and shoulders). Good luck finding the sleeves and the proper bearing that fits them as well as the hub shell. Andy.
I just wanna ride
The local machine shop said they could drill a hole through the axle to make it hollow, but that would take about a half hour which cost $40. And I'm not sure if that's the best idea
