Wondering how I'm going to get outside
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4387 Post(s)
Liked 3,016 Times
I'm normally a year-round rider here in Minnesota. Unless the ice is really bad or the weather is truly severe, I'll ride outside through the winter. Last winter I upped my gear to include bar mitts and I was good to go down at -13 °F, at the coldest.
So I'm not afraid of the cold per se, but....
This fall I'm off the bike getting over some orthopedic issues. I haven't been riding outside since early October. I am doing a little work on the trainer, but that's neither here nor there.
My concern is that whenever I am ready to go outside, I won't be acclimated. It's one thing to go through the season with the temperatures dipping lower and lower, and getting used to the shock and the conditions. It's another to go from not riding outside at all, to getting oneself out the door for the first time in months at, say, 10°F.
I think that if I don't get out soon, I may well be indoors all winter long.
Quoted: 1364 Post(s)
Liked 1,677 Times
While jumping back in at -13F may be too much, You can do 10F. You know how to dress for it. The endorphins and euphoric sense of accomplishment will make up for any discomfort in the first 10 minutes.
You don't have to do a full ride (unless you commute). And you will feel better for any length ride...even 5 minutes.
You can do this.
You can do this.
Likes For BobbyG:
Sr Member on Sr bikes
I concur. I ride through the winters here in southern New England. Granted, it's not quite as cold as you get there in Minnesota...but I do think that aclimating through the beginning of each season...especially fall into winter...is necessary. Like you...I have had a few years where, due to injury, I wasn't able to get out during that aclimating period and consequently had a miserable time through the winter. Good luck, and do the best you can.
Dan
Dan
Quoted: 5224 Post(s)
Liked 3,581 Times
now git!
Liked 3,016 Times
Well, I did it and it was great. 25 miles in light snow and 12 °F.
The challenges are more about coming back from the injury and regaining stamina. I've been zwifting, which helps a ton, but I have a long way to go.
The temperatures were fine. My fingers were a little cold, but then again, I wasn't using the bar mitts.
Likes For MinnMan:
You can do it. Start with shorter rides to refresh your memory on gear choices and build up your tolerance. And if you can, look for other riders to share the ride with you and keep you motivated. Also, it doesn’t get really cold here until the third week in January, so you have time.
Just like running a race, the hardest part is getting to the starting line. The same applies to biking. Just getting out the door in the hardest part, but once you do, it will all come back to you and you will feel like a million bucks!
And if I see you out there, I’ll be the one wearing ski goggles and mittens and waving.
Quoted: 7348 Post(s)
Liked 2,465 Times
Wait for a warmish day to acclimate yourself. Decide on an acceptable range of temperatures and stick with that for a few days. Then push the limit lower.
Liked 3,016 Times
Ski goggle, mittens? That's a lot of people 'round here. Well, a comparative few. But it's good to have company out there in the Minnesota winter. Now, if they would just finish with all that trail construction and detours....
Liked 3,016 Times
Anyway, going out the first day was indeed something of a mental barrier. But man-o-man, it has to be really cold for me to prefer that basement torture zwift thing, where minutes crawl and joy goes to die. (Just kidding, I can sort of get into the Zwift thing sometimes.....)
Quoted: 1324 Post(s)
Liked 927 Times
I really enjoy riding out into the country near here at night when the snow is on the ground. The snow really brightens things up and often a headlight isn't even need other than to let anyone else see me. It's so quiet and often the only sound is the sound of the tires softly swishing as they go over/through the snow when the roads haven't been plowed yet. It's invigorating as well as extremely restful. I had decent quality large knobs 26" x 2.125" tires on my MTB. It does not have studded tires since studded tires are for ice not snow. If I encounter really bad ice I just reduce the air pressure in my tires. that's worked well for me for over 30 years including all-weather commuting in Toronto Canada.
Enjoy your winter rides..
Cheers
