Jubile Sport 1982
Jubile Sport 1982
Hi everybody
i just buy this bike for 65$. I think it was a good deal... but maybe im wrong!!?
everything looks original suntour equipment and motobecane break...
what do you suggest me to do to look better? Any suggestion? (Already put back the handlebar)
any tips to clean the bike?
i want to had breaklever on the handlebar any suggestion too?
thanks in advance
thanks in advance
Quoted: 586 Post(s)
Liked 612 Times
Nice buy and nice deal. Regarding cleaning, I've had good luck with a cleaner called Simple Green. Don't use anything abrasive on the paint. There are a lot of automotive products you can buy to shine up the paint and protect it. Any rust spots or paint chips can be touched up with enamel paint.
Everyone has their own way to polish up the aluminum bits. You might search the forum. I have had success with steel wool, type 000, pretty fine stuff. Meguiars also has a tin of cleaning wipes impregnated with a product that brightens aluminum. Works really well.
Likes For TugaDude:
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
I’d replace all cables and use stainless. I’d clean and lube chain and freewheel. BB may be French threaded so if you service it, be careful.
if you are buying to resell, then building a reputation for quality work is key. I’ve had a lot of repeat buyers over the years. Ten bikes to one family is not unusual. Doing good work is key.
If you are buying to keep, same drill really. Do it right,. New brake pads and cable housings too.
i pretty much disassemble the bike and install new bearings and grease.
Likes For wrk101:
Thanks for your response guys
i didnt buy it to sell it! I really want to keep it...
i tight the rear cable but the break dont work as good as i want...
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Ask as you do the rest of the bike. PG
Quoted: 5888 Post(s)
Liked 3,471 Times
As a keeper, I would overhaul the bike (bottom bracket, hubs, headset). Plus you will want to grease the seatpost and bar/stem. Also replace the consumables such as cables and housing, chain, and tires. Once you do that, you have a fine riding machine and you will have taught yourself how to fix up old bikes.
These motobecane branded weinmann brakes need to be centered properly. The rubber hood over the brake pops off and you can use a 5 mm wrench to center them. Otherwise you can center them using the springs. This tool will make that job easier:
https://www.amazon.com/Park-Tool-Off.../dp/B077YMPKQ2
Bikes: Miyata 710, Univega Viva Sport, Centurion LeMans, Peugeot U09
Quoted: 212 Post(s)
Liked 111 Times
I'm not sure what you mean by "breaklever on the handlebar". Are you talking about safety levers?
Its going to be somethink like that... Im going to change the cable break and a friends going to check all the gear system and change the "rubber" in the handle bar with a black brook... And yes im in us in california ventura Thanks
Quoted: 212 Post(s)
Liked 111 Times
To add them to the handlebars on your bike you would need to remove both the original leather wraps and the brake levers. I would recommend you keep the original bars as is. Pick up a second set and use them instead. You might find bars with the levers already mounted. Then if you sell the bike down the road, you still have the nice original bars and levers.
Zip tie Karen
Liked 1,542 Times
Trying to remember, weren't the molded one-piece handlebar/brake hood rubber things made by Hutchinson for Motobecane? It would be a shame to destroy that part. I'd recommend keeping as is.
Quoted: 1819 Post(s)
Liked 1,693 Times
The "safety lever" misnomer was a cruel joke. Often referred to as "turkey wings". They actually reduced your full braking capacity
Bikes: I have a few
Quoted: 340 Post(s)
Liked 210 Times
Quoted: 1324 Post(s)
Liked 927 Times
Those things were referred to as "suicide levers" back in the day. They were truly awful. Modern aero levers with interrupter levers are a much safer alternative
Cheers
Ok thanks.
So i am going to keep the hutchinson handbar and put a new one on the bike. If one day i want to sell the bike i will give the old hand bar...
i've got a family friends who's got a bike shop so i gave him the bike and he is going to fix it perfectly...
Quoted: 790 Post(s)
Liked 1,761 Times
Yes this bike does have the faux leather Hitchinson wraps which are pretty nice a full bar set stem bars , brake brake levers this clean goes about $100 plus the $50 it will take to ship.
Liked 927 Times
Quoted: 1088 Post(s)
Liked 1,205 Times
Liked 927 Times
