Super short rivets for head badges
Bikes: '73 Raleigh Competition, Guru Sidero, Soma Groove, Smolenski,
Quoted: 15 Post(s)
Liked 15 Times
Hi all,
I am assuming a few of you have re-attached headbadges in the past. I bought a hand riveter for just this task with my Raleigh Competition that I restored (which turned out pretty nice, if I can pat myself on the back) but I cannot find rivets short enough so that the rivets as installed do not interfere with the steerer tube from the fork.
Where have you sourced rivets that work for this? I really want to get the headbadge back on (I just think it looks better) so any help is appreciated. Thanks
Smiles and Happiness
Splendidtutional
Splendidtutional
Quoted: 1601 Post(s)
Liked 2,187 Times
@Splendidtutiona - Check out this thread - Removing head badge - Bike Forums
Quoted: 767 Post(s)
Liked 1,897 Times
Also this thread: https://www.bikeforums.net/classic-v...ss-rivets.html
@3alarmer had great results there.
Velo Heaven in the UK sells them but they are Covid closed at the moment.
https://www.velo-heaven.co.uk/collec...-badge-fixings
Pull the nail out and cut the rivet short, then put the nail back in. Does this work? No idea I just thought of it.
The few times I refitted head badges onto bikes, I cheated-- I glued them on and filled the holes with small nails cut to just below the head. You can't tell the difference!
Quoted: 3788 Post(s)
Liked 6,574 Times
I’ve done the same as my left-handed compadre:
Likes For nlerner:
I had bad luck with them btw. They didn’t want to penetrate; just dented the tube although I was careful to drill the pilot hole to spec. I wound up doing the glue/faux rivet method mentioned by others.
