2015 Post Your Singlespeed/Fixed Gear Megathread
#2251
Bikes: Handsome Fredward, Trek 1.1
Quoted: 481 Post(s)
Liked 131 Times
I am not really a fan of carbon bikes, but this one has made me reconsider my prejudices. Nice bike @Aka_ricerocket
#2252
Quoted: 12 Post(s)
I sorta understand what you're saying but guess that even though I can afford it, my innate frugality keeps me from spending like you do/did on a bike.
I'm not going to post it here again...but I do own one of my own dream bikes, which gets ridden hard almost daily, and I certainly do smile every time I ride it or even look at it - so I get that part of your argument.
One last question if you don't mind? What is that brake lever and cable housing? Sorry, guess that was 2
Hope you continue to enjoy your wunderbikes for a long time...
#2254
Bikes: KHS Flite 100 Road Track Fissie Biek
I've rebuilt the Windsor while my KHS is having problems
#2255
Looking good. Why such a huge drop between saddle height and bar height though? Mega long arms?
#2258
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
Some significant updates to my BD steel bikes.
1) Kilo WT gets a rack top trunk bag, taller gearing with a 19T Eno freewheel and a second water bottle cage. It is now a full on touring bike.
2) Motobecane Messenger gets converted back to SS with low 40 x 18 gearing and a rear brake.
3) Windsor Clockwork SS gets slightly lower gearing with 48 x 20.
4) SE Draft Coaster gives back the brake caliper and lever to the Motobecane Messenger.
#2259
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
¿Dónde has leido eso?
- Gates Carbon Drive Belt System
[h=5]CAN THE BELT DRIVE BE USED WITH COASTER BRAKES AND FIXED GEAR BIKES?[/h]
- If a belt drive is used with coaster brakes or fixed gears, we recommend a hand brake as an additional braking system. Gates does not support the use of the belt as the sole braking system.
#2262
^that guy^
Felt Brougham, Origin8 hubs w/ hollow axles, Weinmann DP18 wheelset, Bontrager saddle
#2263
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12768 Post(s)
Liked 7,682 Times
#2264
Gah! Hatehatehate those Speed Limit brakes. Hard to adjust and center; weak-sauce braking. But light...
Cool Carbon District, though. Built one up for a customer, but he kept it drop bar; love the cut down flat bar setup here.
You can't run the OEM hub fixed because it runs a proprietary freehub setup with a splined belt cog. However guy at the shop I used to work at converted one of the regular aluminum belt-drive Districts to fixed with what at the time was a prototype threaded belt cog on a regular fixed/free hub.
#2265
Veteran Racer
Liked 764 Times
Some anti-bling here, aka my designated beater / lockup bike since I tore down and disposed of the Vilano. I had initially installed the unused rear brake from my Motobecane Messenger as a front brake, but then returned it to the MM when I changed it from FG to SS. I then remembered that I had an old Dia-Compe single pivot front brake with a long fork through bolt and external hex nut that I had used on the Vilano. It's a pretty wimpy flexy brake and the brake blocks are not very good, but it's still better than just having a coaster brake. The only brake lever I could find is a Tektro RL721 31.8"mm cross lever, which is way too big for the 22.2mm bar diameter, so I clamped it over grip. It kinda sorta works, but the lever squirms around a lot and tries to pry itself of the grip when I grab it, so I've ordered a Dirt Harry mtb lever as a more permanent solution.
#2266
Brown Jersey Winner
Quoted: 243 Post(s)
Liked 13 Times
revelate gear came in, i actually got them for the trek but couldnt help but test them on the ecr first since i havent been in the woods since joaquin phoenix came around
#2270
Bikes: Bareknuckle, Kilo TT Stripper
Just finished building my Bareknuckle this weekend. Photo was taken before I wrapped the bars, but it turned out well. Bars now have Brooks honey tape. I kind of want to quit my job and just ride bikes.
#2271
Bikes: GT Gutterball, Electra Townie
Nice bike! I'm digging that color. I too want to quit my job and ride my bike.
#2273
Bikes: 1967 Carlton team/ 2013 BMC GF02 Disc/ 2013 Bianchi San Jose SS commuter
Quoted: 7 Post(s)
Picked up a used ugly Trek 2nd district for next to nothing a couple months ago. Stripped it down my painter buddy painted it and I bought a few parts and got it back on the road today. Will still probably install a black crankset and black brakes in the future if I keep it. This will be my grocery bike so going to pick up a set of Ortleib pannier's soon.
KF
KF
