Tire replacement - rotation
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Today, while cleaning the bike, I noticed that my rear tire it almost down to the wear marks. It will last to the end of the season and need to be replaced. The front tire has plenty of meat left.
Not my tire
So do i just replace the rear tire or do I move the front to the rear and put a new tire on the front?
my tire.
Not my tire
my tire.
On Your Left
Liked 2,434 Times
Quoted: 344 Post(s)
Liked 20 Times
Not my tire
Not my tire
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Replace rear when worn. Replace front when worn. The whole rotating dogma is kind of funny.
Super Moderator
Quoted: 1173 Post(s)
Liked 929 Times
I wait until the cords are about to show.
I don't bother rotating. I ain't got time to take off a perfectly good tire, just to move it.
On Your Left
Liked 2,434 Times
Here's my tire.
Rubber side down
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times
I wait until the cords begin to show as well, but I do rotate front to back. No big deal to pop the tires off and rotate. It takes 10 minutes tops.
IMO the tire in your photo has a lot of life left in it.
Quoted: 6556 Post(s)
Liked 58 Times
You shouldn't be so smug. It isn't becoming.
Quoted: 2490 Post(s)
Liked 2,960 Times
I've always replaced the rear when it looks worn and then replaced both when the front is ready to be replaced.
On Your Left
Liked 2,434 Times
Should Be More Popular
Quoted: 22609 Post(s)
Liked 8,930 Times
BTW, I do replace the rear tire when it's truly worn and move the front to the back. That is Sheldon's way and it makes the most sense. But nothing terribly wrong with doing it differently.
Quoted: 1422 Post(s)
Liked 7 Times
It is generally accepted that moving front to back and putting the new tire on the front is the safest thing to do.
The reasoning is that a blowout is more likely on a worn tire and a blowout on the front is harder to control, so put your best tire on the front.
Also, unless there is other damage, or you are starting to get too many flats, you can ride those Contis to the bottom of the dots.
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
EDIT: Re-read your post. I guess I might ask though what constitutes or how do you figure out when the rotation is supposed to happen, assuming you have two tires both of which are not worn past a place where you'd want to use them (on either wheel)? I guess I'm of a mind that if I'm unsure whether a tire is prone to blowing out, on whatever wheel, then I'm not going to want to put it on either wheel.
Advocatus Diaboli
Liked 1,533 Times
So you rotate at some point before the cords start showing? At what point or how do you determine when this is?
Non omnino gravis
I don't rotate, because I get 2x the life out of a front compared to a rear. I get right about 3,000 miles out of my Maxxis in the rear. By that point, the front is just starting to flatten out in the center of the carcass. If I were to switch it to the rear, it would be dead within 1,000 miles, while the brand new front would have a good 5,000 left in it (give or take.) The vicious cycle of rotating would go on forever. So I replace one rear at ~3k, then both tires at ~6k. While it might work out the same in the end, I feel like replacement + rotation would just have me constantly buying new tires, and having to keep a detailed log telling me when to move what tire where.
Liked 58 Times
