Tire Replacement Protoc0l
Medicinal Cyclist
Bikes: 2003 Klein Q Carbon Race; 2009 Giant OCR-1
Tire Replacement Protocol
Since the front tire sees a lot less wear than the rear, what's the best way, in your opinion, to replace worn tires?
1.) Put new tires on both front and back when the back one wears out;
2.) Move the front tire to the rear and put a new one on the front;
3.) Replace them individually as they wear out.
Personally, I like #2 because I hate to toss a tire that's not worn out and putting a fresh tire on the front seems like a prudent safety precaution. And, I'm guessing it's the most cost-effective approach.
But this being BF, I know others will have very strong, contrary opinions on the matter. So, let's hear them.
Quoted: 104 Post(s)
Liked 5 Times
Years ago, Sheldon Brown recommended your #2. If your front tire wears so slowly that it lasts for years, then moving it to the back is a good way to wear it out before it starts to die from dry rot.
If you ride enough miles that your front tire last less than a year on its own, then I would go for #3.
#1 just sounds dumb.
Some people use different tires on the front and rear (e.g. a more puncture resistant tire on the rear), so their choices are more limited.
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
#1 is dumb
#2 is optimal
#3 is what I do
#1 is dumb
#2 is optimal
#3 is what I do
Quoted: 551 Post(s)
Liked 277 Times
#2 works for me
To clarify my above post, I'm too lazy to do #2 and I go through tires fast enough it doesn't really matter. Probably do 3 rears to a front.
Certifiable Bike "Expert"
#1 is for if you have a hang-up about unmatched tires and you go through tires so slowly that your tire model is no longer in production when you wear out the rear.
Personally, I think this probably describes the majority of BF riders...
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
2 for me. I hate taking the rear wheel off. It is so difficult to put back. Is it just me or is there a trick to doing it easily?
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
Medicinal Cyclist
Super Moderator
Quoted: 1173 Post(s)
Liked 929 Times
Put the chain on the smallest cog first, and sometimes pull the rear derailleur back a bit. And open the rear brake quick release.
Medicinal Cyclist
You Know!? For Kids!
Are you a registered member? Why not? Click here to register. It's free and only takes 27 seconds! Help out the forums, abide by our community guidelines.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
no. i really am that useless. i get my hands covered with chain muck and i'm pulling on the derailleur pulleys etc. It's a sad sad sight.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
Dan J
Bikes: 1974 Stella 10 speed, 2006 Trek Pilot 1.2
Quoted: 18 Post(s)
Quoted: 10 Post(s)
This is kind of funny for me. Today I faced this issue at the bike shop. I took the bike in for a tune up and asked them about new tires. They suggested I replace the back one. I told them to go ahead and replace both of them. I didn't want to face having to replace the other one in the future. I'm too lazy.
Bikes: 2007 Giant OCR C3, 1991 Specialized Sirrus Triple & 2002 Diamondback Response
Option #2 for me, unless I want to try a new brand of tire...tire lust is hard to control.
