Most bikes in a narrow space, any ideas?
Randomhead
Liked 3,698 Times
Horrors, I need to park my car in the garage. And for some reason my wife doesn't think I should park it on her side and make her park outside. So the frame shop is going to have to get compressed and parts of it moved to the basement. But the bike collection is also taking too much space.
My thought is that putting two levels of bikes parked with their handlebars and rear tires touching the wall will fit the most bikes. Bikes overlapping as much as they can without making it a real mess. Anyone try this scheme?
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
How high is the ceiling? Hang them vertically from the ceiling, one hook per bike. Remove pedals and rotate handlebars 90 degrees and you can pack them vertically just a few inches apart.
Car can probably park underneath the bikes, taking zero floor space.
Randomhead
Liked 3,698 Times
The ceiling is not very high. The way the door rails are situated, it would be a real problem to get a bike on a hook there. But there is room for two levels of bikes below the rails.
Insane Bicycle Mechanic
Quoted: 806 Post(s)
Liked 707 Times
My garage has a 8-foot ceiling and it's drywalled, so the studs are covered. I have a length of 2x4 bolted to the studs about 18" from the wall and there are 6 hooks screwed into the 2x4. I can hang 6 bikes in a space 12' long by 2' wide with the space underneath the bikes free for storage boxes of random stuff.
Jeff Wills
Jeff Wills
Randomhead
Liked 3,698 Times
That's about what I have now, the problem is there are still 3 bikes on the floor. And it's a real pain to hang bikes from hooks. That was one of the least pleasant parts of being a bike mechanic. My back still flinches when I think about lifting a Schwinn varsity
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,485 Times
Put the nicest ones inside the house, you know, as decoration.
"Honey, why is your Bianchi hanging above the bed?"
"Isn't it sexy, dear?"
Maybe hang one bike from another to achieve two levels? Certainly not ideal but if the need is temporary it may be tolerable.
I have a similar issue with garage dedicated to bikes. Recently I had to replace the camshaft in my truck. Rainy season had already begun. I borrowed a tarp and did the job in the driveway, much to the horror of my neighbors.
I.C.
I.C.
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
Quoted: 2338 Post(s)
Liked 2,822 Times
Likes For squirtdad:
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
A variation of this solution is what I'll be doing when I do the make-over of my bike storage in a narrow basement storage space. Slatwall is pretty pricey, so looking top either go with bands of slat, or to adapt similar hangers to attach to studs.
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
Removing pedals and rotating the handlebars is the way to pack the most bikes into a given space. It also helps you keep stems from welding themselves into the steerer tubes. Hanging vertically in alternating orientation will also give you more open floor space. They don't have to be overhead... just high enough on the wall to get them an inch or two off the floor. Those flash-welded Schwinns won't need to be hoisted up high... just tipped up vertically and lifted an inch or two. This arrangement will also keep them from becoming dominoes when you bump the first one getting out of your car.
Quoted: 786 Post(s)
Liked 520 Times
For my riders, in my basement I alternate one bike vertically on a front-wheel hook (rear on the ground), and one bike on the floor facing out, rear wheel leaning against the stud. I fit two bikes per about 22" of wall. It's possible to (carefully) grab any of them without moving the others, and hooking the vertical ones is pretty easy. I also hook spare wheelsets above the bikes on the ground. Here's a quick diagram. In reality, they can be closer - about 2" between handlebars:
Randomhead
Liked 3,698 Times
I didn't mention that these bikes are all riders. The unridden ones are in the attic. I was thinking about the pedal hanger idea. Someone sells that for regular walls, Delta maybe?
With no car in my half of the garage and the frame shop only taking up half of the empty bay, I have really gotten used to having the bike I want on the floor. I have been thinking about parking my commuter on the front porch, but my wife accuses me of making the front porch look like the beverly hillbillies already.
Use hooks like in some of the suggestions above, but mount them on French cleats, so that you can slide them as close together as possible once the bikes are hung. I've also seen some kits that use a similar solution made out of aluminum, but prefer the DIY approach.
Quoted: 1608 Post(s)
Liked 2,216 Times
https://www.amazon.com/Venzo-Bicycle...s%2C136&sr=8-4
Bought one of these but don't like it. But for your situation, it might be the best solution. Hard to get the top on out though.
Current high ceiling solution
P1000485, on Flickr
Single car garage solution
WP_20140302_002, on Flickr
Low ceiling, double car garage solution.
P8031673, on Flickr
P1000485, on Flickr
P8031673, on Flickr
Quoted: 18376 Post(s)
Liked 4,511 Times
If you hang the bikes horizontal, you can probably park the hood of the car under the bikes.
Alternate bars forward/back.
Randomhead
Liked 3,698 Times
the hood end of the garage is still going to be the frame shop, it's just that I'll have to park the car outside to build frames in it.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
How far from the wall can the bike space be?
Saddle height?
As a modified form of the usual "sardine" approach (22 bikes hung vertically and perpendicular to a 17' wall), perhaps the bikes could be twisted 45-degrees or so, by twisting the opposite loops of each hook 45 degrees instead of 90-degrees.
Using this approach, the usual bikes-per-foot spacing would be reduced, but so would the distance out from the wall.
Here is what 90-degrees from the wall looks like. But if they were twisted to be more like fish-scales(???).
Saddle height?
Quoted: 3464 Post(s)
Liked 2,829 Times
Cheaper car- one you can tolerate parking outside? I laugh now at all the extension cords run out to cars in front of the garage door. level 1 charging, 120v. I'm told basically 5 miles per hr of charge...
One acquaintance had to get a level 2 charger, 11k and a new 200 amp service panel later...
Liked 2,822 Times
reconsider the fleet? Heavy bikes go away.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
In my experience, having some bikes hanging from the rear wheel in a tight space makes hanging the bikes awkward. When I had to condense my storage space I went for a two level approach (like what I think you described in your first post).
The upper bikes are still a little awkward to get out, but it's manageable.
My Bikes
My Bikes
Randomhead
Liked 3,698 Times
I hate going to gas stations and I'm still on the first tank, 750 miles later. So I'm happy with the car. The level 2 charger is coming when I upgrade the heating system and need a subpanel anyway. It's rare that I drive the car before it has finished charging.
I have to clear everything out and do some experiments.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,925 Times
What about a garage extension?
Sugar "Kane" Kowalczyk
Randomhead
Liked 3,698 Times
I have a shed, hopefully it doesn't come to that.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
Saddle height?
Saddle height?
Ben
