Trainer for fixed-gear bike
My wife has a fixed-speed, coaster-brake bike that fits her. But my trainer is designed for a bike with a cassette and quick-release skewered axles. The axle on her bike is short (6" long with no cassette) and held in by bolts on either side (no quick-release). Is there a trainer or a trick that would let her use the bike indoors during our snowy weather? Many thanks!
Clark W. Griswold
Quoted: 4371 Post(s)
Liked 4,010 Times
You cannot have a fixed gear with a coaster brake however you can have a freewheel with a coaster brake and that could be a single speed. You can use rollers quite easily but any trainer that isn't direct drive could potentially work, Saris/Cycleops, Tacx, Kinetic...all make some fine trainers.
Quoted: 99 Post(s)
Liked 115 Times
Rollers are easier to use than you might think. Modern ones have "waisted" rollers which draw the wheels back towards the centre. Riding on rollers requires a certain amount of concentration and is therefore not completely boring. Rollers can be adjusted to fit any bike.
Regarding riding a fixie on rollers, I do it all the time. I also sometimes ride my fixie on a wheel-on trainer. The difference is that the rollers require concentration to avoid crashing. On the trainer, I can zone out and watch TV while I ride.
Regarding rollers, there are several varieties. Most brands have straight cylindrical rollers - Minoura, Inside Ride, TruTrainer, Kreitler, CycleOps, Masvis, Rock Bros, & Saris. The TruTrainer and Inside Ride rollers are available with small wheels on a vertical axis that serve as bumpers to keep the front wheel of the bike from going off the roller. Some brands have rollers that are straight cylinders with a flare at either end to catch the wheels before they go off - Elite, Tengma, & Souzier. One brand has rollers that taper down in diameter toward the middle - TACX. Another brand has rollers that taper up in diameter toward the middle - Crown.
That TACX and Crown have adopted opposite solutions for keeping the wheels on the rollers is perplexing. I have TACX rollers and can attest that I can easily ride off the ends of the rollers; however, TACX rollers do seem to be popular with YouTubers who do bike roller stunts. I'd like to try the Crown rollers, but they are pricey.
I have been riding my fixed gear on the trainer for the last 3 weeks as I am recovering from pacemaker surgery. With any luck I can ride outdoors next week.
Fixed gear on trainer
Riding indoors as I am recovering from pacemaker installation
Likes For bmwjoe:
Clark W. Griswold
Liked 4,010 Times
Good luck with recovery...I like the new training duds from Rapha!
Likes For veganbikes:
If you don't like that outfit I have my night riding attire...
Night Training
Night Training
Likes For bmwjoe:
Clark W. Griswold
Liked 4,010 Times
Her bike is not truly a 'fixed gear' bike. It's a simple one-speed, with coaster brakes. Bolts on either side hold the 6" axle in place. The sockets on my trainer (into which the quick-release mechanism on my road bikes slide) don't come together close enough to grab the short axle on her bike, and I'm pretty sure she wouldn't be comfortable with rollers.
Thanks again for recommendations/solutions!
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Thank you, Veganbikes, and others for clarifying my use of words.
Otto
Just got a saris m2, currently using with 120mm rear track wheel. The trainer cups fit fine without qr scewer, using 15mm track nuts on the wheel. I would guess they use the same cups for all their trainers and checking on line they fit 120mm wheels for most of the trainers.
Clark W. Griswold
Liked 4,010 Times
