Pressure washed my bike... is it really really bad?
Old 09-03-23, 05:20 AM
123123user
Quoted: 11 Post(s)
I had to take the bike on a freshly-rained-upon road and had no energy left to clean immediately when I got home. I attempted to at least degrease and wipe off the drivetrain but there was a lot of gravel in between the crevices of the cassette, chain, basically everywhere. I could hear them sanding together while I cycle -- it needed a full body wash.
Just today I popped up the pressure washer and sprayed it straight onto the muck -- my cassette never looked this silvery before! Also sprayed from the top in between the crank arms, the FD area, the brakes, and anywhere else where the gravel had conveniently rested on and it's a relief to feel smooth again. Didn't really bother with the top half though.
Then I turned on the internet for more cleaning advices and it says that I should not ever use a pressure washer ever. Holy crap, did I make a mistake? I watched someone on youtube testing it out on his mountain bike (I washed a road bike) and had some water inside his BB after.
123123user is offline
Old 09-03-23, 05:36 AM
PoorInRichfield
Bikes: Trek Domane SL7 Disc, Cannondale F29
Quoted: 389 Post(s)
Liked 325 Times in 186 Posts
I used to pressure wash my 1999 Trek 5200... until I blasted part of a decal off on the downtube. Unless it's a very low-pressure pressure washer, hand washing is likely a better option.
PoorInRichfield is offline
Likes For PoorInRichfield:
Old 09-03-23, 05:50 AM
bargainguy
bargainguy's Avatar
Quoted: 517 Post(s)
Liked 310 Times in 191 Posts
The problem with pressure washers is bearing surfaces. Any high-pressure application to those bearing surfaces is going to result in moisture infiltration. Now you're talking rebuild.
The good news is that once you've rebuilt the bearing surfaces with fresh grease, you're good to go.
bargainguy is offline
Chuck Naill
Quoted: 408 Post(s)
Liked 184 Times in 120 Posts
Fenders are your friend. I honestly don't know why they are not more popular. Even dirt bikes have them.
Chuck Naill is offline
Likes For Chuck Naill:
Old 09-03-23, 06:30 AM
Pop N Wood
Quoted: 668 Post(s)
Liked 529 Times in 355 Posts
Yeah, got to believe all the over the top warnings on the internet.
The worry is forcing water past the seals into the bearings. Just don't make a habit of it and if you do, avoid areas with bearing seals (like the bottom bracket). Bike wash by hand just fine.
Pop N Wood is offline
Old 09-03-23, 07:05 AM
base2
I am potato.
base2's Avatar
Quoted: 1790 Post(s)
Liked 1,631 Times in 934 Posts
The advice against pressure washing generally stems from days of yore when "sealed" really meant a dust shield in close proximity to prevent general particulate intrusion. The term "sealed" was meant to distinguish from "unsealed" where the bearing balls were plainly visible to both the unaided eye and whatever sand happened to be nearby. Think of the difference between an American Ashtabula bottom bracket versus the tin cover pressed onto the cone of a wheel bearing. These bearing were intended for regular disassembly & servicing owing to their exposed nature and chemistry of the available lubrications of the time.
Modern rubber sealed bearings are unlikely to get water infiltration owing to improved design. The pressure of a jet of water on the rubber seal can actually possibly make it seal harder depending on design. Though bicycle bearings are friction sensitive to the end user and such design is rarely employed outside of some cartridge-style square taper bottom brackets.
Generally the seals in a cartridge style bearing are inserted into the cartridge and the assembly is behind a shield/flange/baffle of some sort. Observe the flanges on an axle endcap. Or the dust shields of a quality headset... The purpose is to take away any direct path and deflect the energy of any incoming jet stream before the rubber seal so that the rubber seal can do it's one job, keeping dust out & keeping lube in.
Your bike is designed to operate in the rain. I think general advice ought to be updated to: "Pressure wash bearing areas no harder than would be experienced by rainfall." But, that may be too much nuance for many people, especially people who have no idea what kinds of bearings they have. Thus the general: "Thou shalt not!!!" still persists.
base2 is offline
Likes For base2:
Old 09-03-23, 07:13 AM
easyupbug
Quoted: 569 Post(s)
Liked 589 Times in 412 Posts
Assuming you used a typical high pressure washer you should check at a minimum your headset, hubs, bottom bracket, derailleurs, & pedals, anywhere there is a seal.
easyupbug is offline
Old 09-03-23, 07:51 AM
Maelochs
Maelochs's Avatar
Quoted: 7653 Post(s)
Liked 3,485 Times in 1,840 Posts
Did you think your bike had been bad so you pressure-washed it to punish it, and now you feel guilty?
Maelochs is offline
Old 09-03-23, 07:59 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6222 Post(s)
Liked 4,222 Times in 2,368 Posts
Excellent advice. I would add that even loose bearing hubs…which are about the only things using loose bearings now…have far better seals than they did back in the 80s and early 90s. We can thank mountain bikes for that.
Stuart Black
cyccommute is offline
Old 09-03-23, 08:00 AM
123123user
Quoted: 11 Post(s)
What could be the implications if water has ever invaded bearing surfaces?
Old 09-03-23, 08:07 AM
cyccommute
cyccommute's Avatar
Rust. Maybe pushing outside grit into the bearings. If the bearings are cartridge bearings, this isn’t much of a concern since those kinds of bearings are replaced if they stop working.
Stuart Black
Old 09-03-23, 09:11 AM
soyabean
soyabean's Avatar
Quoted: 540 Post(s)
Liked 416 Times in 274 Posts
Bearings are made to repel dropping rain and puddle splashes, and even then, I have seen that dry out bearings and rust up. Regardless, even sealed bearings are not designed to withstand 2000 psi of water.
If a bike has never been washed and only a pressure washer can remove cakes grease and cured dirt, then the bike is due for a rebuild anyways. Go ahead, and rebuild that bottom bracket, headset, wheel hubs.
After that, you only need garden hose and water pressure that garden hose provides, a good soap does the rest.
We've also seen electric water guns used in professional cycling pitstops. These give better pressure than a garden hose, but still much lower than a pressure washer. Rhe pit crew using this knows the areas to avoid, and water into bearings is not an issue for a bike that only needs to work that one day.
soyabean is offline
Old 09-03-23, 10:16 AM
Maelochs
Maelochs's Avatar
Originally Posted by soyabean
... even sealed bearings are not designed to withstand 2000 psi of water .... you only need garden hose and water pressure that garden hose provides, a good soap does the rest.
I agree .... the high-pressure water can blow the grease out of the bearing housing so the bearings just grind themselves to nothing. Yes, bearings, loose or cartridge, can be replaced ... but doing something that harms the bike because you can fix it later ... we all make our choices. I do not choose that.
I use Simple Green, but any sort of soap is fine. as was mentioned, if the grease is caked and baked and won't come off with soap and a brush .... maybe time to break down everything and repair and replace in a more serious manner.
Maelochs is offline
Likes For Maelochs:
Old 09-03-23, 10:31 AM
wolfchild
Quoted: 4227 Post(s)
Liked 2,488 Times in 1,286 Posts
Pressure washing a bike is total overkill and unneccessary. You could of used a garden hose to rinse it and that would of been enough.
wolfchild is offline
Old 09-03-23, 01:29 PM
tomato coupe
Quoted: 3957 Post(s)
Liked 7,310 Times in 2,950 Posts
Would have, could have.
tomato coupe is offline
Likes For tomato coupe:
Old 09-03-23, 04:55 PM
Inusuit
Bikes: 1995 Specialized Rockhopper,1989 Specialized Rock Combo, 2013 Specialized Tarmac Elite
Quoted: 213 Post(s)
Liked 588 Times in 278 Posts
Rust.
Inusuit is offline
Old 09-03-23, 05:47 PM
Quoted: 18428 Post(s)
Liked 15,582 Times in 7,337 Posts
English be hard.
Old 09-03-23, 08:30 PM
rsbob
Grupetto Bob
rsbob's Avatar
Bikes: Bikey McBike Face
Quoted: 2590 Post(s)
Liked 5,656 Times in 2,927 Posts
I used to regularly pressure wash my MTB after mud caked rides. However, I was careful to avoid the headset, BB and wheel hubs.
Road 🚴🏾‍♂️ & Mountain 🚵🏾‍♂️
rsbob is offline
Likes For rsbob:
Old 09-03-23, 08:35 PM
Yeah. I got mired in Montana mud up to the spokes, which splattered mud everywhere, including on the brakes. (Glad I didn’t have fenders.) Fortunately, there was a car wash place with a power washer maybe 9 miles up the road. Made sure to spray down whenever possible and use as little pressure as possible.
Old 09-04-23, 03:04 AM
PeteHski
PeteHski's Avatar
Quoted: 4420 Post(s)
Liked 4,873 Times in 3,017 Posts
IME pressure washing a bike will soon compromise the BB, wheel bearings and headset. Especially if you are pointing it straight at them at close range.
Even regular riding in the rain and mud greatly reduces the lifespan of these bearings. They are not that well sealed.
PeteHski is online now
Old 09-04-23, 08:44 AM
cyccommute
cyccommute's Avatar
Bearings don’t “dry out” because of water. Grease is hydrophobic and doesn’t dissolve in water. Older greases used salts of fatty acids to hold the oil in suspension but the oil can flow away from that kind of grease over time. The salt of the fatty acid was generally not water soluble either. More modern greases use different formulations that retain the lubricating part of the grease better than older greases. The days of “grape jelly” in bearing surfaces is mostly gone.
While the pressure at the nozzle may be as high as 2000 psi, the pressure drops to atmospheric as soon as it exits the nozzle. There may be a small gradient very, very close to the nozzle but, as long as you don’t put the nozzle directly on the bearing, there is little chance the you’ll be in that pressure zone. The water will have a fairly high velocity but it won’t have any pressure.
The guys over at GCN actually tested this and found even putting the nozzle right on the bearings for minutes at a time didn’t cause problems.
Stuart Black
Old 09-04-23, 08:54 AM
cyccommute
cyccommute's Avatar
Do you offer that advice to motorists? The bearings on bicycles are adapted from bearings found in various spots on motor vehicles. They are most like what you will find in the steering system. Those bearings carry heavier loads and are exposed to more harsh conditions. They, however, last for 10s of thousands to hundreds of thousands of miles with no maintenance at all.
The cartridge bearings used in bicycles aren’t bicycle specific. They have wide applications in many industries that operate under far more harsh conditions that we cyclists put them through. No one seems to be all that concerned about their ability to handle the conditions.
Stuart Black
Old 09-04-23, 09:50 AM
PeteHski
PeteHski's Avatar
Yeah I definitely go easy with the pressure washer on cars. Although it's a lot harder to directly spray bearing seals in a car. But you can certainly get water into places where it causes trouble. For example I've seen alternators destroyed from pressure washing engine bays.
I presume you pressure wash the crap out of all your bikes and they last forever. I just use a garden hose at most.
Old 09-04-23, 11:03 AM
GhostRider62
Quoted: 2333 Post(s)
Liked 2,097 Times in 1,314 Posts
I use the power washer with 45 degree nozzle when there are a lot of dried worms on the downtube. I never apply water pressure to a bearing. You just have to not be stupid.
GhostRider62 is offline
Likes For GhostRider62:
Old 09-04-23, 01:39 PM
Hvac
Bikes: About 10
Quoted: 28 Post(s)
Liked 7 Times in 6 Posts
Lessons learned for us all.
Hvac is offline
