clean cassette w/Q-tip, pipe clnr, cardboard?
Old 04-08-09, 12:03 PM
epnnf
epnnf's Avatar
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times in 55 Posts
Bicycling mag says to use corrogated cardboard to clean rear cassette. I tried it, but pieces of cardboard were left round the sprockets. A friend told me never use cotton (Q tips, pipe cleaners), for the same reason.
sup?
epnnf is offline
Old 04-08-09, 12:20 PM
demoncyclist
demoncyclist's Avatar
Bikes: 2011 Lynskey Sportive, 1988 Cannondale SM400
Quoted: 20 Post(s)
Either take the cassette off the hub and clean the cogs individually, or use the "edge" of a shop rag, folded in half, to get between the cogs.
demoncyclist is offline
Old 04-08-09, 01:10 PM
capwater
capwater's Avatar
Bikes: Giant TCR Comps, Cdale R5000, Klein Q-Pro, Litespeed Siena, Piasano 105, Redline Conquest Pro, Voodoo Bizango, Fuji Aloha
old toothbrush
capwater is offline
Old 04-08-09, 02:10 PM
grinningfool
Senior Moment
grinningfool's Avatar
Bikes: 2014 Surly LHT, 2003 Giant NRS 3, 1991 Trek 700, 2006 Cannondale Six 13 Team, 1985 Miyata 210
Liked 3 Times in 3 Posts
I give mine a good spraying with degreaser, then scrub using a cheap scrub brush from the dollar store. Clean the chain at the same time, then when dry, lube with a good chain lube.
grinningfool is offline
Old 04-08-09, 02:20 PM
Longfemur
For an effective on-bike cleaning:
Spray something like WD40 on it to loosen all the gunk (cover whatever you need to avoid spraying with newspaper).
Use an old toothbrush on the teeth
Get a piece lace or other kind of string that won't fall apart, and run it through each of the spaces between the gears. With the bike hanging from a stand, or even just upside down, you can turn the pedals and the string will rub everything off. It will end up very clean.
Personally, while I like mine clean for the sake of appearance, I don't think cleaning the cassette makes much difference for your chain.
Longfemur is offline
Old 04-08-09, 02:34 PM
bkaapcke
Quoted: 118 Post(s)
Liked 50 Times in 25 Posts
It's simpler than all that. Costco has white, nappy shop towels that come in a pack of 60. Once a year my ride buddies split a pack and get 20 each. Put some solvent on the edge and use it to floss the cassette. I do it once with solvent and once with a dry edge. 5 minutes, 2X a month and your cassette is always clean. Dirt/mud runners can forget this method. Won't work for you. bk
bkaapcke is offline
Old 04-08-09, 03:32 PM
Silent Otto
Please do not use degreaser on your cassette, that includes wd-40. You sure don't want your freewheel spinning greaseless. Dry flossing is best, and use a small flat screwdriver if you need gunk scraping. Watch your fingers!
Silent Otto is offline
Old 04-08-09, 04:01 PM
EatMyA**
EatMyA**'s Avatar
Butterknife + rag
Best way I have found out.
use Demoncyclists rag method if you cant find a butterknife. The butterknife just makes things so fast though.
EatMyA** is offline
Old 04-08-09, 05:21 PM
tellyho
Your mom
+1 on no degreaser. Just get the edge of a rag in there to get out the serious gunk.
tellyho is offline
Old 04-09-09, 08:09 AM
DaveSSS
Bikes: Cinelli superstar disc, two Yoeleo R12
Quoted: 1098 Post(s)
Liked 559 Times in 446 Posts
Using a 1" paint brush dipped in mineral spirits should not hurt a thing. The solvent should not get into the freewheel mechanism, if you don't get carried away. I use this process frequently and never had any ill effects. You will need to use paper towel to catch the drips coming off the cogs. It's faster and does a better job than any dry method.
If I take the cassette off for a real thorough cleaning, I still use mineral spirits. I use an old plastic cool whip container for a wash pan and enough solvent to cover the cogs. I finish up with a hot soapy water bath.
DaveSSS is offline
operator
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times in 19 Posts
sup?
Bicycling mag, rofl what a joke. Pull the cassette apart and clean it with a rag.
operator is offline
Old 04-09-09, 08:13 AM
operator
cab horn
Quoted: 42 Post(s)
This is such bad advice my eyes are hurting.
operator is offline
Old 04-09-09, 09:08 AM
Psydotek
Body By Nintendo
Psydotek's Avatar
Location: Videogames ruined my life. Good thing i have 2 extra lives.
Bikes: Giant TCR2, Giant TCX, IRO BFSSFG SE, Salsa Casseroll, IRO Rob Roy.
Take the cassette off if you can for a thorough cleaning. Drop the whole thing into your favorite degreaser and let it soak while you're working on the rest of your bicycle.
Originally Posted by jsharr
A girl once asked me to give her twelve inches and make it hurt. I had to make love to her 3 times and then punch her in the nose.
Psydotek is offline
Old 04-09-09, 09:30 AM
DMF
Elitist Troglodyte
DMF's Avatar
Bikes: 03 Raleigh Professional (steel)
If I'm not going to take the cassette off (and apart), I use a Pedro's cleaning brush designed for just this purpose. (Park Tool has one too.) Then wipe the exposed teeth with a rag.
Then clean the #%^ brush...
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
DMF is offline
Old 04-09-09, 02:16 PM
RickLafayette
Bikes: Lynskey MT 650
Use a cotton rope slightly thicker than the cog spacing if you are going to clean it on the bike. At some point you should disassemble the cassette and clean the cogs individually.
RickLafayette is offline
Old 04-09-09, 03:37 PM
Al1943
Liked 7 Times in 6 Posts
Fold a rag over and floss between the cogs. No need to take the cassette or freewheel off.
WD40 or a grease solvent will not hurt a cassette or freewheel as long as you don't get it into the internal working parts. But generally it's not needed to clean the cogs.
Al
Al1943 is offline
Old 04-09-09, 05:25 PM
bkaapcke
Quoted: 118 Post(s)
What's wrong with using a towel edge that has been soaked with degreaser? How is it going to get into the freewheel? bk
bkaapcke is offline
Old 04-09-09, 07:17 PM
zacster
Bikes: Kuota Kredo/Chorus, Trek 7000 commuter, Trek 8000 MTB and a few others
Quoted: 22 Post(s)
Liked 464 Times in 365 Posts
I just use a rag edge with citrus cleaner, and a toothbrush on the stuff that it doesn't get. You don't have to soak it in cleaner, just enough to loosen the crud.
zacster is offline
Old 04-10-09, 11:44 AM
tellyho
Your mom
Rag soaked with degreaser = no problem. Spraying degreaser or WD40 willy-nilly = problem.
People actually take their cassettes off? Seems like overkill to me.
tellyho is offline
Old 04-10-09, 12:03 PM
keisatsu
Eternal n00b
Bikes: Giant OCR3, Marin Mount Vision, '94 Bontrager Racelite, Mirraco Blink
I find in the end the best way is to remove the cassette, takes a few seconds to take off, but is MUCH faster to clean.
Though if you don't want to take it off, I've never had a problem with spraying wd40 directly onto the cassette, just don't spray it where it'll get into bearings.
keisatsu is offline
Old 04-10-09, 01:08 PM
milnerpt
Bikes: Scott scale 29er, Gary fisher Rig SS 29er, Fuji Cross pro, Novara Randonee, Scattante TI custom build, Fuji Team
I submerge the bike into my 500 gallon tank of WD40, use a pressure washer aimed at the rear hub, then tighten EVERYTHING down until the screws round off.
either that or just take it off. thats the ONLY way I get it super clean, and its actually faster than fiddling, flossing, cursing.
milnerpt is offline
