Frequent Rear Wheel Flats with Conti GP5000
Old 06-08-20, 08:48 AM
greyfox47
I have a 2 year old Trek Domane SL6 disc brake bike. Prior to about a month ago, I was running Bontrager 25mm AT series tires and joyfully hadn't experienced a single flat since mounting the tires, about 2500 mi. I decided to switch to 28mm and chose the Conti GP500 tires. That was about 250 miles ago. Since then, I've had no issues with the front wheel, but am experiencing a slow leak flat on the rear tire almost every other ride!! After each flat, I carefully feel the inside of the tire and come across nothing, not even a little debry of any kind let alone a nail, piece of glass, goat head, nothing. I haven't used any tubes rated for less than 28mm in the wheel and am my wits end with what could be causing the flats. I'll admit that the Conti are a bit of a challenge to mount but I'm careful to avoid anything to the tube that would result in a pinch. I'm riding mainly on paved roads and on gravel only when I have to. Ditto for groomed trails. Any suggestions on how to pursue this? Nothing ruins a ride sooner than a flat anywhere along it. Thanks!!
greyfox47 is offline
Old 06-08-20, 09:25 AM
WhyFi
WhyFi's Avatar
Quoted: 20791 Post(s)
Liked 9,436 Times in 4,663 Posts
Are you aligning the tire logo with the valve stem? Some people think of the practice as a purely aesthetic thing, but it's really helpful for things like this - once you find the leak in the tube, you should be able to locate the offending debris in the tire by referencing the position relative to the tire logo/valve stem.
WhyFi is offline
Likes For WhyFi:
Old 06-08-20, 09:26 AM
Iride01
Iride01's Avatar
Quoted: 6163 Post(s)
Liked 4,782 Times in 3,300 Posts
So are you finding the puncture in the tube?
Once I find the puncture in the tube then I know whether to look for issues with the rim, side wall or tread of tire. As I keep rim and tire oriented the same way, I can just lay the tube on top of them both and find the cause of the tube failure.
Iride01 is offline
Likes For Iride01:
Old 06-08-20, 09:30 AM
popeye
Bikes: S works Tarmac, Felt TK2 track
Quoted: 359 Post(s)
Liked 179 Times in 111 Posts
Run a piece of cotton aground the inside of the tire looking for it to catch on something. Try it again with the tire inside out. A small piece of wire or glass and be hard to find. Listen to WhyFi.
popeye is offline
Likes For popeye:
Old 06-08-20, 10:14 AM
AndrewJB
Bikes: FUJI Transonic 2.3; Motobecane LeChampion TI SL; Trek 2.3
Quoted: 36 Post(s)
Liked 43 Times in 22 Posts
You don't mention if the punctures are on the inside, outside, or side of the tube...but make sure your rim tape/strip hasn't shifted exposing one of the spoke holes. This would be characteristic of punctures on the inside (spoke side) of the tube.
AndrewJB is offline
Old 06-08-20, 10:47 AM
Elvo
Quoted: 630 Post(s)
Liked 369 Times in 206 Posts
Can you switch to tubeless?
Elvo is offline
Rides4Beer
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times in 414 Posts
This. I was going to say to check the rim too.
Rides4Beer is offline
Old 06-08-20, 03:07 PM
greyfox47
Well, I guess I could.... the wheels are tubeless ready, but not prefered. I think that would be my solution of last resort. Thanks, tho.
Old 06-08-20, 03:09 PM
greyfox47
Yes,.... ironically, the first puncture was opposite the valve stem, which I attributed to being a pinch flat after not being able to find anything else. It was the first ride after mounting the new tires.
Old 06-08-20, 03:20 PM
greyfox47
Ha! Yes, all of the above. First, outsde the tube opposite the valve stem. Looked like a pinch, I took blame for that one when I mounted the tires. The others were 2 in the side wall region (mysteries) and one outside. On the last one, found a tiny goat head that I removed with a finger nail. I'm not sure if it contributed. For the life of me, I had a hard time finding where it might have penetrated the tire tread. All the tube punctures except the first one looked like straight on punctures. The first one looked like a pinch.
Old 06-08-20, 04:00 PM
Cyclist0108
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times in 1,164 Posts
If you have any, put some sealant in the tube (assuming the valve stem unscrews).
Cyclist0108 is offline
Old 06-08-20, 04:59 PM
stevel610
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 365 Post(s)
Liked 457 Times in 240 Posts
Sometimes squeezing the tire, thumb on one sidewall and fore/middle finger on the other will show tiny holes where a shard of glass has worked it's way through.
Good luck. That's a frustrating situation.
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
stevel610 is offline
Old 06-08-20, 07:50 PM
jnesss
Quoted: 9 Post(s)
Liked 8 Times in 3 Posts
I ran through some glass last weekend and have had nothing much troubles since. i had pulled out the glass embedded in my tire and ensured there was no debris between my tire and rim. since then, I've been alternating between 2 specialized presta turbo tubes and noticed they've got what appears to be a manufacturing flaw. there are rectangular seams on these tubes and the holes are almost always at these seams. anyhow, 6 patches later over the course of 1 week, straight to the garbage they go. bought some specialized presta valve tubes and so far, so good.
btw, I could only find the leaking holes when I Aired up the tube to around 10 psi, then rotated it in a bucket of water. my tire itself has been patched at the cuts
jnesss is offline
Likes For jnesss:
