Old 01-08-19, 11:29 PM
  #5851
RobbieTunes
Quoted: 378 Post(s)
Liked 1,409 Times in 909 Posts
I see no advantage to them, and though I've seen them at Fiesta, I've never seen anyone actually put their hands down there.
RobbieTunes is offline
Old 01-09-19, 12:40 AM
  #5852
canklecat
canklecat's Avatar
Quoted: 4559 Post(s)
Liked 2,802 Times in 1,800 Posts
Yeah, I seem to recall seeing a photo of Greg LeMond on a bike with Scott drop-in bars, but couldn't find a photo or video of him actually using them.
Seems like bar end shifters could work. Not sure about the handling but I guess you can get used to anything.
canklecat is offline
Old 01-09-19, 04:40 AM
  #5853
texaspandj
texaspandj's Avatar
Quoted: 1605 Post(s)
Liked 583 Times in 380 Posts
Ive seen a couple of versions of the drop ins. The regular like sloar had on one of his bikes a few pages back and another that came close enough to be joined with a bridge attachment.
Tthe concept is the same as aero bars, to draw your elbows closer together. This was to be used in solo breakaways in road races. I think as C-Cat said you get used yo anything.
On another note, thanks to Doc, RT, and markwesti for your input and suggestions, yall guys are the best.
One last thing on the aero bar gripshift. It's not the same as what's found on cruiser bikes. It's a different design but same concept. Reportedly the first generation (which I had) were Not Sram but very shortly after they were, including the three versions I have today. The original version had a regular diameter so they could fit regular road bars and we're aimed at riders that were used to using barcons. They were solid at the top nothing like today's models, you even had to drill a hole in your handlebars to run your cable through. Apparently someone came up with the bright idea to use them on the original scott aero bars like the aero bars I have. These are regular diameter so no problem. But after Greg Lemond '89 TDF win, the add on attachments went full production and because of a rule change (you couldn't have open end bars facing forward) they made them with a hole at the top so you could slide a bar through them and install a neon color bridge (which eventually came in hot pink, yellow, and black).
Anyways, that's why they were sold for different components like, campy shimano, and suntour. The weird thing is they also came for specific shimano and campy sets like 105, 600, and dura ace and chorus, record and so on. And finally in small diameter to fit the small diameter mass produced scott aero bar attachment.
I had mine in '88 and Scott Molina used the exact setup as me to win the Hawaii Ironman that year, Dura Ace 6 speed. I've got a pic of him I'll try to find and post.
texaspandj is offline
Old 01-09-19, 05:52 AM
  #5854
texaspandj
texaspandj's Avatar
This is identical to the original,I had however mine didn't have the grip tape it gad ridges. So possibly I had pre sram. Note the enclosed top.they eventually came in 7 speed and neon.
These are the ones I have now. Notice the attachment bridge. These came in 7,8 speed and for different companies.
Finally these are what are commonly used today. Mostly on cruiser bikes and probably all shimano.
​​​​​​​As a follow up and possibly a clarification.
Old 01-09-19, 11:22 AM
  #5855
TXsailor
Bikes: Origin-8 Lactic Acid Giant Escape 2 Centurian Lemans 12 Kuwahara Tandem 1989 Ironman Expert 1988 Ironman Master
Quoted: 241 Post(s)
Liked 82 Times in 59 Posts
Wheels and Sugino 165 triple crank arrived courtesy of SeyPat & SeedsBelize
The frame is looking better I have most of the scratches touched up and the white oxidation buffed off. It actually a little shiner that it shows in the picture and still needs some work but its going to look pretty good.
I have most of the rest of the parts ordered and all the parts we are reusing cleaned up and ready to install. For now its going to be 6 or 7 speed but if she likes it as much as I hope she does we may go 9 or 10 speed in the future.
Thanks again Saypat SeedsBeleize & RobbieTunes for helping with this project. She is excited
TXsailor is offline
Old 01-09-19, 01:26 PM
  #5856
seedsbelize
smelling the roses
seedsbelize's Avatar
Quoted: 7081 Post(s)
Liked 901 Times in 612 Posts
Well I am excited too,to be a part of this.
seedsbelize is offline
Old 01-09-19, 01:47 PM
  #5857
RobbieTunes
Quoted: 378 Post(s)
We do this while the Italian guys are still fighting about purity.
Old 01-09-19, 04:16 PM
  #5858
canklecat
canklecat's Avatar
The only grip shifter I can recall using is the low end Shimano RevoShift on my comfort hybrid/errand bike and some popular comfort cruiser type bikes. I think one used bike I tried a couple of years ago may have used SRAM instead. Better quality but felt the same when shifting.
The RevoShift work fine, but are cheaply made and need to be replaced every few years depending on use and outdoor conditions. It's mostly plastic and eventually pawls break and it won't shift smoothly anymore. I paid $10 or less for a replacement set with cheap cables/housings just as a backup.
But the right/rear derailleur grip shifter is fine. The left/front needs more wrist power to move that front derailleur. It would be even more awkward in the TT aero bar position, at least with my achy old wrists. Not sure whether that's a factor with most time trials since you're probably in the big ring the entire ride. One of my favorite TT segments here is 6 miles and ends in a roller coaster with an increasingly steep series of short but steepish climbs. A couple of times when I didn't have a tailwind I might have shifted to the small ring, but I usually try to avoid that.
Old 01-09-19, 05:47 PM
  #5859
texaspandj
texaspandj's Avatar
Yeah with the original gripshifts some had issues with having to twist their wrist too much. So the next version pretty much fixed that. Eventually the gripshift faded out of favor. Mostly I believe because the age groupers follow pros and component sponsored pros like Dave Scott, Mike Pigg and Mark Allen had to use the attachment that allowed you to use regular down tube shifters and then eventually moved to bar end shifters when the components companies caught on. I think the gripshift are efficient and aerodynamically better plus they look cool and different. ..oh looks smooks.
Old 01-10-19, 10:56 AM
  #5860
texaspandj
texaspandj's Avatar
Originally Posted by RobbieTunes
+1
Different RD's move different distances given the same length of cable pull.
I'd check the RD for "catches" due to grit or grease or cable routing, etc. A lot of them catch right at the first cog, you adjust for it, only to pay the price farther up the cassette/freewheel.
^^^That is Some solid knowledge there.
Given that does anyone know if the 7 speed 6400 tri color rear derailleur (oem on the '88 '89 Master IM) has a different pull ratio than the 8 speed 6401 tri color rear derailleur?
I use the 6401 on my '89 but for 7 speed. It is Awesome, so smooth, and precise. I don't even want to take it off to try it out on the Carbon for the 8 speed gripshift. But.. I will when I get me a dura ace 7700 rear derailleur and 7700 braze on front derailleur for my '89 Ironman.
Old 01-10-19, 11:56 AM
  #5861
top506
Death fork? Naaaah!!
top506's Avatar
Bikes: Seriously downsizing.
Quoted: 559 Post(s)
Liked 629 Times in 280 Posts
Same/same.
Top
top506 is offline
Old 01-10-19, 12:15 PM
  #5862
fleslider
fleslider's Avatar
Quoted: 477 Post(s)
Liked 179 Times in 91 Posts
all of the Shimano SIS derailleurs have the same pull except for the 7400 Series Dura Ace.
fleslider is offline
Old 01-10-19, 02:30 PM
  #5863
texaspandj
texaspandj's Avatar
Well I transferred the 7 speed gripshift I had on my Miami Vice on to the Carbon Ironman. It shifts fine no issues.
Two years ago I used my Miami Vice for a few triathlons and it had the oem DT shifters and I wished I had the gripshift and since I'll be using the Carbon Ironman this season I need the gripshift.
So now I'm reinstalling the OEM 105 group back on the Miami Vice sans the downtube shifters (I gave them away) instead I'll be using Dura-Ace 7 speed DT shifters. Well back to work... uh on the Miami Vice.
Old 01-10-19, 05:50 PM
  #5864
RobbieTunes
Quoted: 378 Post(s)
I have a set of 1050 DT shifters from an '88 Expert. Just sitting here.
Old 01-10-19, 06:23 PM
  #5865
RobbieTunes
Quoted: 378 Post(s)
Here you go, one shifter for both derailleurs. I'll bet there's math involved.
Old 01-10-19, 06:59 PM
  #5866
seypat
Quoted: 3241 Post(s)
Liked 2,512 Times in 1,510 Posts
You know I have multiple sets sitting around collecting dust.
seypat is offline
Old 01-10-19, 07:04 PM
  #5867
RobbieTunes
Quoted: 378 Post(s)
Mine go either to Tex or to the swap meet on Saturday. Maybe I can get a cup of coffee out of them.
Dude, that crankset! you had to laugh putting that in the box! Bars are already mounted.
We need to make a list of the organ recipients from that bike.
Old 01-10-19, 07:05 PM
  #5868
seypat
Do you want a set? I owe you a favor anyway. PM me with an address and I'll send you a set. Include the details with exactly what you need.
seypat is offline
Old 01-10-19, 07:13 PM
  #5869
seypat
A little salt spray doesn't hurt. How about those derailleurs! Calipers are in pretty good shape also. How about the plastic spindle sleeve? That thing looked brand new. I did get a chuckle including the old cables and bar tape I figured you could use those for setup tests.
seypat is offline
Old 01-10-19, 07:23 PM
  #5870
RobbieTunes
Quoted: 378 Post(s)
They're cleaned up now. I actually considered using that cable housing for a project I can't discuss just yet, but it would just not work. the cables were surprisingly clean and slick, so I'll likely use them on another Centurion....
I laughed at the bar tape. I restored a yellow-white Master for a friend, and he insisted on me finding the same bar tape. That stuff is so bad, even the mice won't chew it.
Old 01-10-19, 07:31 PM
  #5871
seypat
Look at the wheels that went to Txsailor. They need some cleanup from being at the beach, but look at the brake tracks on the rims. That bike was not ridden a lot.
seypat is offline
Old 01-10-19, 08:40 PM
  #5872
RobbieTunes
Quoted: 378 Post(s)
Yep, no corrosion on the bars. A couple of nicks. They're already on the Comp TA
Old 01-10-19, 10:14 PM
  #5873
TXsailor
Quoted: 241 Post(s)
Yep those wheels don't show much wear and will clean up fine.
TXsailor is offline
Old 01-11-19, 07:14 AM
  #5874
texaspandj
texaspandj's Avatar
Thanks RT and Seypat for the 1050 DT shifters offer. I probably should take you up on the offer in case I ever want to take my Miami Vice completely back to stock including handlebars (which I have). But someone else will probably need them before I do. But thanks guys, however I might be wanting to borrow seypats bottom bracket retapping tool as I have plans to remove my Carbons crankset today and I think I may need it.
I'm not overly familiar with bike forums but I do recognize the generosity from members of the "cool kids club" and I think it's just superb the way we we keep the Irongents freewheels turning. From @markwesti and his offer to mill down a metal part for me to members finding complete Ironman bikes for fellow members and to practically building bikes with donations from all members, just truly amazing. I just can't help but to think how lucky I was to get the Ironman-itis back in 1986.
Old 01-11-19, 08:24 AM
  #5875
seypat
Are you talking about a Crank Arm Thread Chaser like this? If so, PM me an address and it will be sent. For those following, I have a crank arm thread chaser if anyone needs to use it. Here is a PSA announcement for those that don't have much experience pulling cranks. If those threads are a little iffy and you can't get the crank puller to screw in all the way, do not try to pull that crank. You'll strip it. Borrow/get a thread chaser and clean up the threads until you can get the puller in there without forcing it. No project is too urgent to ruin a good crank.
https://www.amazon.co.uk/Bicycle-Res.../dp/B001PTALQ8
seypat is offline
