Rust on top tube guides
Old 04-28-20, 02:13 PM
Chicago Al
Chicago Al's Avatar
Bikes: 1974 Motobecane Grand Record, 1987 Miyata Pro, 1988 Bob Jackson Lady Mixte (wife's), others in the family
Quoted: 66 Post(s)
Liked 37 Times in 26 Posts
I have had my 1985 Pro Miyata stored under a porch, under a cover, for a few years, and apparently I did not do an adequate job of cleaning it up before putting it there, as now it has the rust you see around two of the cable guides (worst is pictured). The paint is still there but bubbled. I know about OA, have used that successfully, have not had such good luck with 'rust converter' as it never seems to do anything, but possibly I had the wrong brand/bad batch/bad luck.
Other than this the bike's paint just has the usual nicks and scratches, no big deal to touch up, so I would like to do a precise job on this. Maybe that means carefully scraping this down and painting with red Testor's, or...?
What have you used (successfully) on this kind of situation?
I never think I have hit hard, unless it rebounds.
- Dr Samuel Johnson
Chicago Al is offline
Likes For Chicago Al:
Old 04-28-20, 02:52 PM
gugie
Dilberteur at large
gugie's Avatar
Bikes: It's complicated.
Quoted: 2765 Post(s)
Liked 703 Times in 399 Posts
a) Live with it
b) Remove the paint and rust around it, and use touchup paint
c) Repaint frame
Cost and quality go up from b to c.
Choice b sounds like the direction you'd like to head in, ain't that ain't bad. 80 grit garnet cloth is probably your best bet, to get to the rust you'll need to get the paint off the affected area, at that point you could use naval jelly (good for small areas) OA, or whatever you have on hand to remove the rust, rinse, sand just a bit, and touchup. I can imagine making a small dam out of putty if you go the OA route.
I think you're on the right track.
gugie is offline
Likes For gugie:
Old 04-28-20, 06:03 PM
jonwvara
jonwvara's Avatar
Quoted: 436 Post(s)
Liked 119 Times in 74 Posts
I don't like OA, but as Gugie suggests, I once made some little cup-shaped dams around rusty cable guides from modeling clay, and filled them with Evaporust. The trick is to really smear the clay onto the tubes to get a liquid-tight seal. I forget what I used to get the clay residue off when I was done--mineral spirits, probably.
www.redclovercomponents.com
--Ogden Nash
jonwvara is offline
Likes For jonwvara:
Old 04-28-20, 08:40 PM
Chombi1
Chombi1's Avatar
Quoted: 1125 Post(s)
Liked 142 Times in 110 Posts
Do not leave it alone as it will just get worse pretty quick.....
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
Chombi1 is offline
Likes For Chombi1:
Old 04-29-20, 12:37 AM
gaucho777
gaucho777's Avatar
Bikes: '72 Cilo Pacer, '72 Peugeot PX10, '73 Speedwell Ti, '74 Nishiki Competition, '74 Peugeot UE-8, '85 De Rosa Pro, '86 Look Equipe 753, '86 Look KG86, '89 Parkpre Team, '90 Parkpre Team MTB, '90 Merlin
Quoted: 473 Post(s)
Liked 172 Times in 82 Posts
+1 to gugie. if this is a frame you like and consider a keeper, I'd opt for option b--sand area down to bare metal and repaint with touch up paint. As a heavy sweater and steel rider, I'm consigned to a lifetime battle against top tube rust. I ended up repainting a good portion of my Look's top tube this past winter. The red on your Miyata should be fairly easy to match, but there does appear to be some texture to your paint beyond the rust areas (maybe just the photo?). This texture will be hard to duplicate and may contrast with touch-up. Still, I'd do it. The cable is your friend; it'll hide some of the paint. Try to sand in a uniform circle/oval area with smooth sanded transition from steel to orig paint. Mask off, spray, wet sand to blend. Repeat if as needed.
Sometimes you can treat it early while it's surface rust. Unfortunately, your rust seems to have formed decent sized clumps under the surface--too far gone for soaking in any anti-rust solvent to be totally effective. You can try picking off the tops of the rust bubbles before soaking, but at that point may as well sand & repaint in my experience.
Coincidentally, here is essentially a live photo from my garage (taken a few minutes ago). I noticed surface rust on all my cable guides and a couple other spots on my Parkpre recently. I soaked some strips of rags in Evaporust, wrapped it in & around the cable guides, then covered it all in plastic wrap. (Was held in stand upside down to keep liquid concentrated around guides, but flipped right side up for photo). If you catch it early, this will buy you some time:
if this is a frame you like and consider a keeper.
gaucho777 is offline
Likes For gaucho777:
Old 04-29-20, 12:51 PM
markwesti
markwesti's Avatar
Bikes: 86' Centurion Ironman , 84' Bianchi Alloro
Quoted: 520 Post(s)
Liked 77 Times in 68 Posts
This might be a option for touch up paint , It's Krylon SCB-005 Red Pepper .
IMG_0585 by mark westi, on Flickr
markwesti is offline
Likes For markwesti:
Old 04-29-20, 02:55 PM
SurferRosa
SurferRosa's Avatar
Bikes: old school 531c & Campy
Quoted: 1079 Post(s)
Liked 753 Times in 465 Posts
a) Live with it
c) Repaint frame.
d) Drew
e) Sell
SurferRosa is offline
Likes For SurferRosa:
Old 04-29-20, 03:39 PM
Doug Fattic
framebuilder
Quoted: 160 Post(s)
Liked 183 Times in 94 Posts
I go at those cable guides with a little wire brush on a Dremel. If for some reason you go the whole repaint route, be sure and have the builder/painter take off the 3 top tube guides and put 2 stops on the 7 or 10 o'clock position. Unless of course it is important to keep it looking original. I've done many braze-on redos and repaints and those 3 are always the most problematic for rusting.
Doug Fattic is offline
Likes For Doug Fattic:
Old 04-30-20, 11:32 AM
Chicago Al
Chicago Al's Avatar
Quoted: 66 Post(s)
I'm a little disappointed with you all as a group, as no one has come up with a product like 'Magic DEE-RUST #999 ,' of which a mere light dusting would solve the problem, leaving no trace behind.
But then I never got a pony for my birthday, either.
So thank you all!
Seems like I'm on the right track. I'll have to see if our Dremel kit includes a little wire brush, as that sounds perfect.
- Dr Samuel Johnson
Old 04-30-20, 03:57 PM
Bladeputr13
Quoted: 5 Post(s)
@jonwvara that anti-rust pool idea is interesting! I'll have to try that.
Bladeputr13 is offline
