Spoke Tension
Spoke Tension
I'm looking into acquiring a spoke tension gauge. Does anyone use them or what should I look for?
Quoted: 4210 Post(s)
Liked 3,878 Times
Lots of us use them. Many feel that they have to have a specific spoke tension and thus need a number to read. Some are worried about over tensioning the spokes resulting in cracked rims or collapsed wheels. At one time in my shop life I decided to record on service tickets (and label the rim with) the average spoke tension, thinking that it would elevate me above the other shops. I have to say that my wheels weren't any longer lasting if there was a number listed, for an experienced builder a tension meter is more of an image thing as their skills and feel are what really counts. During the actual building pluck tones are far faster to do and give a very good feedback to how consistently/evenly tensioned the spokes are. For beginner builders having a number to aim for helps though.
As to what one to get that's not a big deal. The meter's ability to be consistent and repeatable is far more important then any small drift from perfect calibration. I find the Park ones (both the more recent versions as well as their earlier one) are easy to hold in one hand and apply to the spokes in the wheel. There have been various copies out their and I suspect they will also work well. I haven't used a dial type, except to handle and check out at a bike show. The claimed tighter tolerances of the dial type didn't seem to be of much benefit and their much higher cost wasn't justified IMO. Andy
AndrewRStewart
AndrewRStewart
Quoted: 2604 Post(s)
Liked 1,933 Times
The Park tensiometer (TM-1 Spoke Tension Meter | Park Tool) is all I've ever needed. Look for a good price.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
I use one every time I build or true a wheel. It is the only way to get the consistency needed for good wheel builds. The Park Tool one is ubiquitous...but it needs to be calibrated fairly often. The Wheel Fanatyk and DT tension meters are very nice (I use the WF) but are very expensive. I don't care what kind of skills you claim to have...you can't build accurately and consistently without one.
Bikes: 1988 Bottecchia Professional (for Eroica), 2011 Ridley Noah ISP (retired), 2020 Soma Fog Cutter (daily commuter), 2021 Ridley Kanzo Adventure (gravel), 2022 Tideace Aero (main road bike).
Quoted: 77 Post(s)
Liked 76 Times
I think that a quality tensiometer is essential for consistent and evenly tensioned wheel builds. I used the Park TM-1 and I've never had a wheel build issue as a result. You will find some that say it's not always accurate, but I've always had very consistent readings and Park will recalibrate it for you if needed.
Thank you! This was very very helpful. I was going in the direction of pluck tones, but even with guitars I am frequently off checking with a tuner. I'll look into the Park tool.
Liked 3,878 Times
"I don't care what kind of skills you claim to have...you can't build accurately and consistently without one." cxwrench
I will take issue with this claim. I've built many (as in many dozens) of wheels both before tension meters were available and after they became the "need to have to be called a good builder". If it's impossible to build a good wheel without a meter then there's millions of bikes with bad wheels being used every day. Also this suggests that all the wheels that we built before meters became available were crap. All the gold medals, all the race wins were on crap wheels. This is bogus.
Will having a meter help, sure. Will it insure a good wheel, no way as that's up to the builder's skills. Can a good wheel be built without a meter, yes and has been done since the tensioned spoke wheel was first made. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 77 Post(s)
Liked 76 Times
Likes For keithdunlop:
Quoted: 83 Post(s)
Liked 64 Times
I’ve used the Park and have a similar version at home that cost a fraction of it’s price. The Park might be calibrated better and likely comes with with better info. I’m not sure who designed these first but they both work. They’re helpful but not absolutely necessary to building wheels. I still have wheels I built 30+ years ago without a gauge and they’ve held up fine.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
...aaand this thread has liftoff!
Even with a Park TM-1, I find myself plucking spokes a lot. I think it's a quicker and better way to tell which spokes in a group have the most or least tension. Muting one of a crossed pair helps you hear the other better. When truing a jog in the wheel, it's tempting to tighten/loosen the closest pair of spokes to the jog. But I sometimes find through plucking, that the real tight spoke is one spoke away on one side, and that there's a loose spoke one more over in the other direction on the other side. By adjusting those two, I can take care of the jog and do a better job of evening out the spoke tensions.
With a tensiometer, some of the repeatability comes down to how quickly you release the handle, so initially your readings won't be as precise as just plucking the spokes.
RUSA #7498
Originally Posted by noglider
Last edited by ThermionicScott; 11-15-21 at 04:29 PM. Reason: broke up a long sentence
Liked 1,933 Times
Second, there's more to building a solid wheel than tensioning the spokes evenly and adequately. As Andrew implies, things like correcting a spoke line, balancing tension against trueness (especially for "experienced" wheels), or stress relieving the spokes is as important as getting them tensioned correctly.
As far as tensioning by ear, I was trained early as a musician, so I trued by plucking for years. I was still surprised by how uneven a couple of wheels were when I first got a tensiometer.
All good "war" stories and field experience. I've been a mechanic my whole working life so I understand experience vs. tools. I'll learn a spoke's pitch. (over at Sheldon Brown's a contributor as a whole musical chart on the subject.) For now this is a new skill and I need to start in the ball park with numbers. Lot's of encouraging info. .
Bikes: lots
Liked 2,932 Times
I've never used 'pitch' and I've never plucked spokes. I'd guess this would change depending on spoke gauge, pattern, and hub/rim dimensions. Why bother with it other than to check consistency? Am I right in thinking you can't use the same note if you're building wheels w/ different thickness spokes? At the shop level I have to use processes that both accurate and repeatable. That's why we use torque wrenches and tension gauges. The 3 senior mechanics at the shop I'm at have nearly 90 years of combined experience. We don't 'think' we're right at 5nm or 110kgf we know.
Likes For cxwrench:
Liked 3,878 Times
Not being very "artistic" I find the paint by numbers kits to result in perfect paintings... Andy (trying to make a joke about absolutes and numbers and how they are not always what makes a better wheel.)
AndrewRStewart
AndrewRStewart
Quoted: 1088 Post(s)
Liked 1,026 Times
A spoke tension meter is kinda like instructions. Something nice to have so when I'm finished I can check it to know everything is right. A really good builder should be able to build a wheel without one and have it be right. After getting my wheelsmith version I went and checked the last three wheelsets I built and all three were spot on for tension and all the spokes were within a couple KgF of each other. Personally, from what I've seen of them I wouldn't trust a park to be spot on, I know neither of my truing stands were when they arrived either, and I've heard from people who have tested them they're not always accurate.
Where it will still excel is in telling you if all the spokes are within an acceptable margin in relation to each other. They won't all be perfectly the same, with my wheelsmith if the number is supposed to be 55 and it reads 54-56 for all of them, and the wheel is straight, true and round then that's good enough. Same with the park. Where this can help a lot is dealing with old wheels that can have wayward spokes randomly located from others mis-truing the wheel. If you're gonna build, its a good investment.
In his book The Art of Wheelbuilding Gerd Schraner says "I worked for year without a tensiometer, being under the false impression that instinct and experience were enough. Then I bought one of the first HOZAN tensiometers on the market and started making comparisons. Shamefacedly I had to admit that my super instinct was not so super after all. Even my mood on any particular day gave different results." Sheldon Brown felt a bike shop should have an tensionometer and Andy's cousin John S Allen thinks at least as early as 2002 that a tensionometer has value and you need some musical aptitude to pluck spokes to discern tension.
There ARE millions of bikes ridden every day on crap wheels and there have been and will continue to be gold medals and races won on crap wheels. And crap wheels will continue to be built with tensionometers. Racers that weigh 145 pounds can get a lot of miles out of crap wheels. Not so much on loaded touring bikes and particularly loaded tandem with disc brakes. They need something better than even a "good" wheel. There is a wide range of spoke tension that can result in a "good "wheel but I believe the range of optimal tension is much narrower and results in the best wheel for the application. For me, past experience and the ability to consistently reproduce a result is critical. If I haven't built with a particular combination of components for a few months, a tensionometer check helps me feel confident I have replicated something I know from experience will serve my customer well and not come back to spite me.
When I started working in a bike shop some decades ago, the owner of the shop insisted that each customer be given a spoke wrench with their new bike, calling it "the most dangerous tool in a bike kit". 15 gauge galvanized spokes, thin flange hubs, single wall rims, narrow tires-what can possibly go wrong?
Some might say that wheel building is part art, part science and part VooDoo. We can all have our opinions on where a tensionometer fits in that triangle as long as the wheels stay round.
Quoted: 569 Post(s)
Liked 588 Times
Get a good one like the Park and in my experience you will build confidence and skills much faster and soon find yourself using it less and less.
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
I guess I'm cheap. I use the app on iphone ...I think it was $5.99.
https://apps.apple.com/us/app/spoke-...ge/id518870820
Quoted: 2488 Post(s)
Liked 2,957 Times
Mad bike riding scientist
Quoted: 6221 Post(s)
Liked 4,221 Times
I do this striking throughout the build to guide me on tension and only use the tension meter as a final check/fine tuning tool.
Don’t fall into the trap of thinking that now that you have a number (or a note) that you just have to wind the spoke up to that value and you’ll have a good wheel. There is still a lot of art in wheel building. There is the spoke tension you should use. A lot of people will tell you to check with the manufacturer for the tension needed. If there is a list of spoke tensions for a specific rim out there, I’ve never found it…despite decades of looking. Generally, the only spoke tension guidance I’ve found is similar to this recommendation from Velocity
Each rim may behave a bit differently; the mark of an excellent wheel builder is the ability to find the highest tension a rim will allow while maintaining its radial and lateral true.
Stuart Black
Stuart Black
Quoted: 4412 Post(s)
Liked 1,566 Times
If you only built DT Competition spoked two cross, 32 hole wheels with 22mm high rims, you wouldn't need a tensiometer after some experience. But different diameter spokes at different lengths have very different deflections for the same tension - which is why the tensiometer comes with a magic decoder card to turn the readout into a useful number. So if you went from 2.0mm spokes to 1.5, you'd likely over-tension the 1.5s because they feel looser at proper tension (and only tension matters).
Plucking is a quick way to find high and low tension spokes in an otherwise full tension wheel. It replaces the tensiometer for relative comparison, not tension value.
I've built lots of wheels without a tensiometer, but they weren't weird and I have a lot of experience. A home mechanic can always go to a shop and ask if the finished wheel has good tension. Most mechanics would check without charging you.
There is a wide range of acceptable tensions for most wheels, which is why many can get away with even but unknown tension. And few understand that total tension (number of spokes) is a factor in individual spoke tension selection - 20 spoke wheels should have more tension per spoke than 36, and wide spaced flanges should have less than narrow.
Bed your elbows, stress your spokes throughout.
I've only built about 25 wheels and starting using a Wheelsmith tensiometer after the first few. I have had good luck with my builds for myself and friends.
The Park tension tool arrived. I'll post my experiences to follow. Thanks for the advice so far
Likes For cpach:
Liked 4,221 Times
I have a really, really accurate sense of relative pitch and very good pitch memory because of my experience as a musician/composer so plucking spokes drastically speeds my builds when comparing spoke tension of spokes on the same side of a wheel--I tend to make any adjustments to whatever spoke is the greatest outlier in tension, and also I balance paired spokes pretty early in the build process. I just use a TM-1 and I can compare relative tension way more precisely by ear. But I don't pretend to be able to tell absolute tension by ear--I set my final spoke tension with the meter, and also double check tension evenness with the meter , but the meter definitely only touches the wheel at final tensioning. It's a legitimate technique.
Park’s tension meter has made it so that most everyone can afford to have a tension meter. That’s only something that has occurred in the last couple of decades. It’s also nice to know the sound method if you have to replace a spoke in the field where you can’t carry a tension meter. It’s good to have a work around just in case.
Stuart Black
Stuart Black
