trek 800, old school
Quoted: 137 Post(s)
Liked 51 Times
hi, ran across a trek 800, multitrack i'm thinking, along the lines of the older 700 series bikes. are these steel frame bikes? any good? this one doesn't have a seat or seatpost and wondering if its going to be hard to find a seatpost for it. thanks, j
Quidam Bike Super Hero
Bikes: 1995 Trek 800 Sport, aka, "CamelTrek"
Quoted: 331 Post(s)
Liked 415 Times
I absolutely LOVE my '95 800 Sport and have been cycling and commuting on it since Dec 2013.
The bike (like mine) should be Cro-Moly Steel. I've flipped it a few times at relatively low speeds an the only damage has been to me! I've gone from a 3x7 to a 1x9, attached whatever I've wanted (racks, etc.) and almost exclusively from donors, sales and basic good parts. It is a resilient beast
It uses a standard, old mtb seat post, so shouldn't be hard to find. A little search-fu should result in the online pdf for the model, along with specs" https://www.vintage-trek.com/Trek-Fis...d/1995trek.pdf
Quoted: 137 Post(s)
Liked 51 Times
trek antelope
Quoted: 331 Post(s)
Liked 415 Times
2018 Review: https://www.bmxonline.com/trek-antelope-800-review/
Mostly pluses, some minuses, "lowest quality" of Trek. Read the whole (short) review. Gives good context and qualifiers for the aforementioned. The stock bike is quoted at 32 lbs. Other specs are at the bottom of the page.
Likes For Digger Goreman:
Quoted: 1400 Post(s)
Liked 1,885 Times
frame and fork appears to be on the lower end of the 'bike shop bike' steel frames - mix of chromoly and 'high ten' steel
the more desirable steel frames will be all chromoly - most times butted (double and/or triple butted) - often constructed of Tange or True Temper or Columbus or Reynolds thin wall tubing - TIG and/or lugged - and typically weigh less than a lower end steel frame
Quoted: 331 Post(s)
Liked 415 Times
Yes, 26", but there are conversions to larger wheels. Provided the wheel and tire has clearance. From the vids I've seen, brake conversions are the easy part.
Liked 1,885 Times
saw this Trek 850 Antelope at a flea market this morning
