Can you convert an Ultegra 6600 standard crank to compact?
Quoted: 353 Post(s)
Liked 92 Times
I have two cranksets, a 52/39 Shimano 6600 and a cyclocross FSA MegaExo 48/38. I want to convert one of them to compact 50/34 instead of buying another crankset. Which would be the easiest to do it with and what chainrings would I need?
Longing for a Tail Wind
The 6600 crank has a BCD of 130mm, which, as I understand means that you can't get to a 34 tooth chain ring that requires a 110 BCD. What is the BCD on the FSA crank?
Yup, 38t is as small as the 130 bolt circle allows,
but, there is nothing to keep you from fitting a smaller big chainring.
so perhaps buy a 48 38 combination, of 2 after-market chainrings?
If you want 34 t , you have to buy a 110 BCD crankset.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
Your easiest and only option is to purchase a set of 110bcd 50/34 fsa rings. Make sure you get the new ones marked 'N10' on them. Not the old ****ty gossamer ones.
