Shimano Ultegra Crankset
Hi
Just looking at spoiling myself and getting a new bike, I am a larger guy so hills can be fun, not!!!. I am trying to stay away from triple so I know there is a 34/50 and 36/52 but wondering if there is a 34/52 crank set?
Cheers
Bug
Cheers
Bug
Just change chainrings .. get the out of the box, 50-34 & then buy a 52t 110 BCD chainring .. I ran 52t in the 80's
13:52 before the cogs were as small as they are now
an 12:52 seems higher than useful .. 11:52 even more so..
because they ship so many for OEM builds stock combinations are cheaper than the custom choices ,
but that is easily changed. just takes Money thrown at the project.
Retired dabbler
Location: Acton, MA (20 miles west of Boston) - GORGEOUS cycling territory!
Bikes: 2007 Specialized Roubaix Elite Triple - 1st ride = century 9/19/2010 , Ultegra
Quoted: 46 Post(s)
I have no experience with the 34/52 - I would think you can do it, although you might need to swap some cogs. The question is if the FD will handle the 18 tooth difference - the official limit is 16, I am quite sure.
Cheers back at you.
Quoted: 453 Post(s)
Liked 104 Times
For the BCD, going on the info given by the OP this indicate he is looking at a 6800 crank, which has the 4 bolt pattern, not a standard 110BCD
Mechanic/Tourist
the 52 is no great benefit, especially with todays cassettes that end with an 11 or 12 tooth cog. It just makes the top gears more useless.
A 52/12 at only 100 rpm is 33mph. I guarantee you can't hold that speed on the level in that gear, and you're better off coasting on the downhills. I also don't understand the aversion to a triple. I have no problems at all with mine, and most people don't. I would never consider a compact, as one has to choose between a wide range and small jumps.
Quoted: 453 Post(s)
Liked 104 Times
Shimano did, and they don't offer it as an option from 105(5800) up now. Do understand your thinking with the jumps and range though.
Thanks for the replies so a possible inner ring change looks workable
Th avoidance of a triple i trying to get a better bike, I have my heart set on a carbon but all teh triples seem to be running the lower end group sets sora or tiagra rather than 105 or ultegra
Expired Member
Quoted: 3674 Post(s)
Liked 5,438 Times
I agree that replacing the smaller ring is cheapest but I'd be surprised if you could regularly spin out the 50/11. Some configurations are more common for a reason.
Liked 5 Times
Yep. Shimano seems to have dropped triples in at least 105 and above. Hard not to see why, since 105 and up are all 11-speed now. A compact crank with an 11-32 11-speed cassette is going to have more range and spacing pretty close to what a 7- or 8-speed triple would have. When you retire and move to Florida you can then change to an 11-23 11-speed cassette and be able to get your cadence to exactly what you want +/- about 3 RPM.
If you're not tackling anything super steep though, then I agree that a compact (or even a standard double with a wider range cassette) is probably the way forward and you don't need to worry about losing out on range.
You don't need 52. 50/34 is plenty. I run 50/34 and 11-25 out back and have never needed any more. I can rip 40+mph on hard descents and climb w/ the best of them for most of what I do here. I could *possibly* (said lightly) see myself doing an 11-28 cassette if I keep this bike long enough to age significantly but otherwise, 11-25 is great. (I could jump to 11-32 but then I'd need a long cage RD and I don't think I'd ever use the 32 anyway).
Again, 52/36 is a trend.....it will fade. Most bikes that ship with 53/39 are ridiculous too. I don't know anybody other than racers that can handle that, especially with 11-25 out back.
