Going from tubeless to tubes
Old 12-05-17, 11:15 AM
drowling23
Bikes: R&M Delite GX Rohloff, Crescent Elgar 27,5 FS, Haibike SDURO HardFour 4.0
Quoted: 46 Post(s)
I bought some spiked tires for my bike only to be unpleasantly surprised that it's setup tubeless. I never asked for this and want to go to tubes ASAP, but am not entirely clear on what the process is. I know I have to unstick the tires from the tubes, but:
  • What tools do I use to do this? Is there a safe/reasonable way that will prevent possible damage to the rims/tires?
  • Is there any residue that I have to clean off once I've decoupled the tires?
  • Are the tires still usable (with tubes) or do I have to throw them away?
Not that it matters, but my current tires are 27.5"/2.35 Rock Razors. I like them but it's winter over here :|
drowling23 is offline
Old 12-05-17, 11:20 AM
ksryder
Bikes: yes
Quoted: 953 Post(s)
Liked 239 Times in 142 Posts
Just let the air out and take the tires off like normal. Might need some tire levers to help but nothing special. Might be some cleanup but I wouldn't stress about getting it spotless. Yes the tires are usable with tubes; that's basically how you fix them in the field if they don't seal.
ksryder is offline
Old 12-05-17, 11:43 AM
Quoted: 9052 Post(s)
Liked 675 Times in 415 Posts
You bought a bike not knowing it was equipped with tubeless rims and/or tires?
Note that some tubeless tires can be finicky when it comes to inserting a tube. My current road tubeless tires are. Had trouble getting the tube to seat correctly in the field. Maybe wider MTB tires are more forgiving.
BTW...If you want to clean the inside of the rims and/or tires, the sealant is water soluble.
Old 12-05-17, 02:41 PM
Juggy_Gales
Juggy_Gales's Avatar
Bikes: 2018 Giant Toughroad SLR2
Quoted: 154 Post(s)
Liked 3 Times in 3 Posts
you'd prefer tube over tubeless?
Juggy_Gales is offline
Old 12-05-17, 02:49 PM
Leebo
Bikes: Kona Dawg, Surly 1x1, Karate Monkey, Rockhopper, Crosscheck , Burley Runabout,
Quoted: 771 Post(s)
Liked 26 Times in 19 Posts
Just ride them like they are set up? Put the tube in the seatbag.
Leebo is offline
Old 12-05-17, 03:41 PM
drowling23
Quoted: 46 Post(s)
Thanks for the responses, everyone, but I've been an idiot, assumed the tires were tubeless because they were stuck shut to the rims. In fact I figure they might have been stuck deliberately, or it could have been an effect of inner pressure against the rim. At any case, I got them unstuck (took a lot of force!) and hooray, there was a tube down there after all.
You live and learn. Also learned that Rohloff is really easy to disconnect.
Old 12-06-17, 03:35 PM
OBoile
Quoted: 782 Post(s)
Liked 94 Times in 52 Posts
I'd still love to know why you preferred tube to tubeless?
OBoile is offline
Old 12-06-17, 09:49 PM
veganbikes
Clark W. Griswold
Bikes: Foundry Chilkoot Ti W/Ultegra Di2, Salsa Timberjack Ti, Cinelli Mash Work RandoCross Fun Time Machine, 1x9 XT Parts Hybrid, Co-Motion Cascadia, Specialized Langster, Pink Klein MTB, Phil Wood VeloXS Frame (w/DA 7400), Cilo Road Frame, Proteus frame
Quoted: 1183 Post(s)
Liked 45 Times in 32 Posts
When you put a tube in make sure to put a little talcum/baby powder in first to prevent things from getting too sticky. It is an old mechanics trick that sadly isn't practiced as much.
veganbikes is offline
Old 12-06-17, 11:54 PM
tajar66
Quoted: 20 Post(s)
Tubeless all the way.
tajar66 is offline
Old 12-07-17, 06:56 AM
Kapusta
Cyclochondriac
Quoted: 1007 Post(s)
Liked 120 Times in 83 Posts
There are a boatload of other threads that go on for 10+ pages debating tubes vs tubeless if you feel like having that debate.
Kapusta is online now
Old 12-07-17, 07:05 AM
IKR. There is even one going on right now in the Touring forum.
Old 12-07-17, 08:02 AM
chaadster
Thread Killer
Bikes: '15 Kinesis Racelight 4S, '76 Motebecane Gran Jubilée, '17 Dedacciai Gladiatore2, '12 Breezer Venturi, '09 Dahon Mariner, '05 Novara Big Buzz, '12 Mercier Nano, '95 DeKerf Team
Quoted: 1026 Post(s)
The request wasn't for a debate, but for the reasoning why they prefer tubes to tubeless. Especially to avoid the hassle of removing an IGH wheel, and especially for winter riding where low pressures are oft welcome, it's a particular point of curiousity for those of us who think about things like pros and cons.
chaadster is offline
Old 12-07-17, 08:07 AM
chaadster
Thread Killer
If this thread https://www.bikeforums.net/touring/1...s-touring.html is what you mean, I wouldn't call that a debate. Everyone seems pro-tubeless for touring except the guy who needs to remove and deflate his tires for travel. Again, there are good reasons to go tubeless, and good reasons not to. I don't get the problem with having the knowledge (through questions and discussions) to make an informed decision.
Old 12-07-17, 08:19 AM
Give it a chance. Just look at the canti brake thread there.
Old 12-07-17, 09:23 AM
ksryder
Bikes: yes
Quoted: 953 Post(s)
The OP said he wanted to put on studded tires for the winter. I can see not wanting to mess around with tubeless for that.
ksryder is offline
Old 12-07-17, 10:17 AM
OBoile
Quoted: 782 Post(s)
I'm not trying to have a debate. Just curious. I know very little about the pros and cons of either beyond the fact that the trend seems to be moving towards tubeless. I was hoping to learn something.
OBoile is offline
Old 12-07-17, 10:23 AM
ksryder
Bikes: yes
Quoted: 953 Post(s)
In a nutshell, you can run lower pressures without pinch flatting, and the sealant usually takes care of most small punctures.
ksryder is offline
Old 12-07-17, 10:52 AM
chaadster
Thread Killer
Because why?
Old 12-07-17, 11:37 AM
ksryder
Bikes: yes
Quoted: 953 Post(s)
Because why?
Because.
ksryder is offline
Old 12-07-17, 11:57 AM
chaadster
Thread Killer
Because.
We all have opinions, but the trick is having a good one!
Old 12-07-17, 02:02 PM
Kapusta
Cyclochondriac
Because why?
Becuase changing tires is easier with tubes, and he is likely going to be changing tires twice a year as he goes between studs and his summer tires.
Old 12-07-17, 02:27 PM
chaadster
Thread Killer
That’s a good thing to consider; there are certainly specific steps for tubeless installations, and one would have to weigh the burden of doing that once a year against the possibility and frustration of grabbing a flat out on the road in the winter. Totally an important consideration, though.
Old 12-07-17, 03:01 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6905 Post(s)
Liked 239 Times in 197 Posts
I have a separate bike with studded tires, its in the basement..
the removal and re installation wears the tire bead with the tool use.
so I fitted out an old MTB.
Consider an extra wheel-set?
fietsbob is offline
Old 12-07-17, 03:44 PM
Kapusta
Cyclochondriac
My apologies for assuming you were looking for a debate.
This is a subject that get re-hashed over and over and over on this forum.
ksryder
Bikes: yes
Quoted: 953 Post(s)
He's got a Rohloff so getting a second wheelset would require a second mortgage.
ksryder is offline
