How Can I Store My Bike?
Old 08-14-18, 08:43 AM
CJohnson101
CJohnson101's Avatar
Hi, my name is Charlie and I am going in to College. I need some kind of storage device for my bike (Full suspension mtb, wheel size 27.5 × 2.3) that will not ruin the walls (for example no nails or screws), and preferably store it vertically to save space... Any suggestions? Thanks!
CJohnson101 is offline
Old 08-14-18, 08:48 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
On Campus Dorm room? get a transport bag , and disassemble it enough,
to go in it?
fietsbob is offline
Old 08-14-18, 09:00 AM
brandonk
Bikes: 84 John Howard, 85 Raleigh Kodiak, 84 Ross Mt whitney, 74 Masi, 82 Allez
Quoted: 40 Post(s)
Liked 7 Times in 3 Posts
You can get a wall storage rack that does not fasten to the wall but is jammed between the floor and ceiling instead, if you have a drywall ceiling use a board on top to spread the load.
brandonk is offline
Old 08-14-18, 09:09 AM
DanBraden
Often on Fritz
DanBraden's Avatar
Bikes: Franken-Fritz, Horse-Feathers, Junker
Quoted: 117 Post(s)
Hey man, don't worry about nailing and screwing in your dorm room. It's VERY easy to fill the holes in your dorm room, plus there are some great vertical storage options that require minimal mounting...
Reliancer 4 Color Foldable Vertical Bike Rack
DanBraden is offline
Old 08-14-18, 09:14 AM
Romyan
Just a dumb freshie
Romyan's Avatar
Bikes: Brown Specialized Crosstrail, Specialized Allez Double Steel, and Dahon Speed P8
Quoted: 55 Post(s)
You can buy furniture that makes it looks good, get cheap van off craigslist for under $1000 for storing it, put in a bike bag, or whatever is suggested here.
Romyan is offline
Old 08-14-18, 10:21 AM
Maelochs
Maelochs's Avatar
Quoted: 7648 Post(s)
Liked 3,464 Times in 1,830 Posts
if it is the right frame size ... you can store it at my house.
Maelochs is offline
Old 08-14-18, 10:28 AM
CrewFan
Bikes: Fuji Gran Fondo, Breezer Liberty r 1.3+, Fuji Absolute 2.1
Quoted: 21 Post(s)
Liked 3 Times in 3 Posts
Those wall mounts look nifty - way better looking than the hooks from a hardware store!
CrewFan is offline
Old 08-14-18, 10:31 AM
Phil_gretz
Zip tie Karen
Phil_gretz's Avatar
Quoted: 1465 Post(s)
Liked 1,542 Times in 806 Posts
Charlie,
Congratulations on leaving on your school adventure. At college, you will be challenged to research and solve problems individually and in groups, as well as being tested against standards to prove your mastery of the subjects.
It's good that you've taken on this "bike storage" problem. Have you tried the phone application "Google"? If you launch this application, and type in the words "free standing bicycle storage" it'll give you some options to follow. Click on the "Shopping" tab.
Scroll down a few entries, and you'll find a nice free standing unit from Overstock.com for $66.49. That's the unit that I would recommend.
Good luck with the rest of your college career. PG
Phil_gretz is offline
Old 08-14-18, 10:33 AM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4905 Post(s)
Liked 1,731 Times in 958 Posts
The Minoura DS-1200 is a super cool solution, but runs about a hundred bucks.
I would look at some sort of tripod-base workstand, like the ever-favorite $30 Bikemate stand found at Aldi. Plenty of options also around or under $50 on Amazon.
DrIsotope is offline
Old 08-14-18, 10:52 AM
Riveting
Quoted: 590 Post(s)
Liked 445 Times in 260 Posts
I suggest a vertical wall mount with a single cheap hook. Holes are really easy to fill, or just pay the $20 hole repair charge the dorm charges. A rubber coated hook (big enough for the front wheel to easily fit into) from a hardware store is like $2. Mount the hook as high as you can reasonably lift the bike's front wheel up to while holding the seat tube and handlebars (I did mine at about 8 feet), but make sure the hook goes directly into the center of a wooden 2x4 stud (and not into a weak sheetmetal stud, which may allow the hook to rip out). Using an electronic stud finder to find the dead center of the stud, and then drilling a pilot hole is recommended so the stud doesn't split and lose strength, causing the hook to rip out.
Riveting is offline
Old 08-14-18, 11:24 AM
BikeLite
Quoted: 381 Post(s)
Liked 145 Times in 93 Posts
https://thewirecutter.com/reviews/be...nd-apartments/
Wirecutter recommends Delta Cycle Michelangelo Gravity Stand
https://www.amazon.com/dp/B000ACAM38
BikeLite is offline
Old 08-14-18, 11:28 AM
DanBraden
Often on Fritz
DanBraden's Avatar
Quoted: 117 Post(s)
I've had some wall mounts that didn't have the little tire guards and my walls got pretty jacked up from all the smudges. Wasn't hard to clean off, but it looked pretty gnarly. So If you DO decide to go for a wall mount, think about getting one with those tire guards, helps to keep things clean!
Old 08-14-18, 11:33 AM
CrewFan
Quoted: 21 Post(s)
That's a good point - the little lady will appreciate the cleaner look for sure!
CrewFan is offline
Old 08-14-18, 11:39 AM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
If you're going to be in a dorm, contact the campus housing office right now, before you arrive on campus, and ask what the options are. Be specific.
caloso is offline
Old 08-14-18, 11:48 AM
DanBraden
Often on Fritz
DanBraden's Avatar
Quoted: 117 Post(s)
but use another persons name and room # in case you have to bandit the whole operation!
Old 08-15-18, 07:03 PM
Le Mechanic
Le Mechanic's Avatar
Bikes: 2020 Pivot Vault, 1983 Rossin Record, Garneau R1, Mesamods home built gravel/rain commuter bike, 1995 Barracuda A2V modified with Surley single speed dropouts, 1969 Bottecchia junkyard special fixed gear, Cervelo P4, Mesamods 650b klunker
Quoted: 96 Post(s)
Liked 72 Times in 50 Posts
I was in a similar situation a couple of months ago. Moved into an apartment and needed to store a couple bikes indoors (the others were ok on the balcony). I was pretty limited on cash, so with some basic tools I already had, I purchased 3 2x4's frome Home Depot and made a free standing 2 bike rack. So far it's worked out really well!
Le Mechanic is offline
Old 08-15-18, 08:09 PM
cyclist2000
cyclist2000's Avatar
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times in 604 Posts
or if you want to hang it vertically, use the above rack and hang the bike by the handlebars, you may need to make the feet extend out further to prevent the rack from falling over.
cyclist2000 is offline
Old 08-16-18, 03:45 AM
KeithMcPherson
KeithMcPherson's Avatar
Liked 2 Times in 1 Post
You can search for Swagman 80955 - Bike Storage, Wall-Mount, that's the one I've got in the garage. However, it does require nailing... Yet, it's reliable, as I've had it for several years with no probs at all
KeithMcPherson is offline
Old 08-17-18, 06:45 PM
Cougrrcj
Cougrrcj's Avatar
Bikes: A few...
Quoted: 620 Post(s)
Liked 370 Times in 256 Posts
Waaaay back in the Dark Ages (1970s), while in the dorm at Ohio State, I took the wheels off and stored the frame under the (bunk) bed in my dorm room. Roomie did the same with his bike (two frames under one bunk bed), wheels were in the closet. Never had a problem.
Cougrrcj is offline
Old 08-27-18, 07:47 AM
CJohnson101
to go in it?
Hmm, thanks for the idea but I'd rather not have to do all that when I'm headed out riding and returning again.
Old 08-27-18, 07:48 AM
CJohnson101
Ok, that's a good idea ill keep that in mind!
Old 08-27-18, 07:53 AM
CJohnson101
Wow, thanks for such an awesome response! Its a good idea, and very descriptive which I really appreciate! However, I'm not really allowed to store my bike in my room so I'm keeping it on the down-low. They may ask why I drilled into their walls because I dont believe they'd be too keen on me drilling holes to store my bike haha, thank you so much though!
Old 08-27-18, 07:55 AM
CJohnson101
Thank you so much for the tip! I'll keep that in mind!
Old 08-27-18, 07:57 AM
CJohnson101
This is an amazing idea, thank you!
Old 08-27-18, 11:06 AM
IvyGodivy
Gravel Rider
IvyGodivy's Avatar
Bikes: 2019 Trek Checkpoint ALR5 | Trek Farley 5
Quoted: 93 Post(s)
I wouldn't be bringing my nice/good bike to school unless planning to go on trails and etc.*
I would say get a folding bike.*
IvyGodivy is offline
