Seat tube water cage only holds a short bottle
Old 11-14-18, 10:04 PM
bogydave
bogydave's Avatar
Bikes: /Skye/ Torker mt, Sirrus flat bar
Quoted: 187 Post(s)
Liked 17 Times in 7 Posts
So I modified one to hold a tall bottle.
Drilled holes so it sets lower & at a slight angle
to the left.
bogydave is offline
Old 11-14-18, 10:09 PM
tajar66
Quoted: 20 Post(s)
I just bought a side load cage
tajar66 is offline
Old 11-14-18, 10:27 PM
veganbikes
Clark W. Griswold
Bikes: Foundry Chilkoot Ti W/Ultegra Di2, Salsa Timberjack Ti, Cinelli Mash Work RandoCross Fun Time Machine, 1x9 XT Parts Hybrid, Co-Motion Cascadia, Specialized Langster, Pink Klein MTB, Phil Wood VeloXS Frame (w/DA 7400), Cilo Road Frame, Proteus frame
Quoted: 1182 Post(s)
Liked 44 Times in 31 Posts
Side load cages solve the problem or you can use Problem solvers bottle cage mount to mount it lower or go with Wolf Tooths B-Rad mounts and have two bottle cages on your downtube like I did on my road bike for a trip I do every year (and then just never took it off). It is excellent and I can use that other cage for smaller stuff or not use it and be fine. I would be bothered by a cage that sits crooked.
veganbikes is offline
Old 11-14-18, 11:02 PM
bogydave
bogydave's Avatar
Quoted: 187 Post(s)
Thanks
Gonna look at side load cages,
Always learning
bogydave is offline
Old 11-14-18, 11:17 PM
bogydave
bogydave's Avatar
Quoted: 187 Post(s)
Side cage don’t seem to be any lower.
Not sure my bike’s mount would have room for the
tall (reg size) bottle.
Next time in the bike shop (with bike)
gonna measure one.
bogydave is offline
Old 11-14-18, 11:45 PM
Pendergast
Quoted: 75 Post(s)
Topeak Alt Position cage mounts are another option. They change the position by 32mm but aren't adjustable.
https://www.amazon.com/Topeak-Alt-Po.../dp/B079NF8BGP
Pendergast is offline
Old 11-15-18, 09:16 AM
Clipped_in
Rubber side down
Clipped_in's Avatar
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 29 Times in 23 Posts
I put a couple of the Lezyne side loading cages on my wife's bike and they work well. AMAZON LINK
Clipped_in is offline
Old 11-15-18, 12:55 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6899 Post(s)
Liked 238 Times in 196 Posts
What's wrong with a few oz less in a regular length bottle?
you can use a longer, liter volume one on the downtube..
add more bottles behind the saddle if you ride in super hot weather..
fietsbob is offline
Old 11-15-18, 01:18 PM
CliffordK
CliffordK's Avatar
Quoted: 8906 Post(s)
Liked 136 Times in 113 Posts
I like to carry 2 bottles for longer rides. Sometimes the same size, sometimes different. But, as I empty the DT bottle, I generally swap positions. So, it is handy to have both bottles fitting into both cages.
Originally Posted by mtb_addict View Post
This is one of the down side of compact frame. Shifting the cage lower has another down side. Which is bottle will get dirty from the crap tossed up by the chain.
Yep. Less of an issue with horizontal Top Tubes. @mtb_addict? Many MTBs have frames squished together so much that there is no second cage, and perhaps not even room for the DT cage.
It is also a frame design issue. In many cases, the two cages meet at some point, and one can be lower than the other. In this case, design it so the Seat Tube cage mounts lower.
CliffordK is online now
Old 11-15-18, 01:28 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
4 bottles , same size, then ..
a little fabrication effort and you can mount the seat tube bottle lower..
fietsbob is offline
Old 11-15-18, 01:46 PM
Mitkraft
Quoted: 46 Post(s)
Liked 5 Times in 4 Posts
I bike in Texas and regularly with temps near 100 (sometimes over) so two 25oz insulated bottles is a must. I had this same problem when I built my Planet-X frame and got one of these to solve it:
https://www.amazon.com/gp/product/B071H4M93Y
Here is a sort of before and after (or actually after and before):
Mitkraft is offline
Old 11-15-18, 05:22 PM
Leebo
Bikes: Kona Dawg, Surly 1x1, Karate Monkey, Rockhopper, Crosscheck , Burley Runabout,
Quoted: 770 Post(s)
Liked 26 Times in 19 Posts
Originally Posted by bogydave View Post
Thanks
Always learning
You drilled a carbon bike?
Leebo is online now
Old 11-15-18, 06:29 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Bikes: '18 class built steel roadbike, '19 Fairlight Secan, '87 Schwinn Prelude, Black Mountain Cycles Monstercross V4, '89 Novara Trionfo, '18 Diamondback Syncr
Quoted: 3167 Post(s)
Liked 275 Times in 190 Posts
that's what I first thought as i read the post, but the pictures clearly show the cages were drilled.
mstateglfr is offline
Old 11-15-18, 07:32 PM
bogydave
bogydave's Avatar
Quoted: 187 Post(s)
NOOOOOO!!!!!!!!
drilled the cage
bogydave is offline
Old 11-15-18, 07:49 PM
bogydave
bogydave's Avatar
Quoted: 187 Post(s)
Yea
4 ounces not much, but have
been out in the desert when 4 more ounces
would’ve been awesome. One time is enough.
Body is learning to sweat, lots of water important
for me, 80 is Hot in Alaska.
I carry a small screw cap in Jersey pocket too.
Some to dump on my head, on hot days is not wasting it.
If I bring some home, I’m OK with that.
bogydave is offline
Old 11-16-18, 06:57 AM
BobbyG
BobbyG's Avatar
Bikes: 2015 Charge Plug, 1997 Nishiki Blazer, 1984 Nishiki International
Quoted: 844 Post(s)
Liked 126 Times in 73 Posts
to the left.
Clever.
I commute, and usually drink at lights and stops where I put my left foot down, lean the bike to the left and grab my water with my right hand. If I were to do this mid, I'd tilt the bottle cage so it could be pulled out on my right side.
Again...very clever!
BobbyG is offline
Old 11-16-18, 12:26 PM
Kedosto
Ambulophobic
Quoted: 437 Post(s)
Liked 123 Times in 76 Posts
Pffft. Just start riding a 60cm frame (or larger). Problem solved. You're welcome.
-Kedosto
*certifiable genius*
Kedosto is offline
Old 11-16-18, 09:03 PM
bogydave
bogydave's Avatar
Quoted: 187 Post(s)
-Kedosto
A reason to buy a new bike “need 2 full size water bottles”
Fitting
bogydave is offline
Old 11-16-18, 09:13 PM
bogydave
bogydave's Avatar
Quoted: 187 Post(s)
thanks,
that’ll work
bogydave is offline
Old 11-19-18, 06:46 PM
bikeaddiction1
bikeaddiction1's Avatar
Bikes: Many
Quoted: 37 Post(s)
Liked 5 Times in 5 Posts
You could always use one of these King Cage Top Cap Mount that attach to any stem with a top cap. Keeps your water bottle handy and clear of road grime. Great place for your bear spray too, if you mountain bike in bear country. .
bikeaddiction1 is offline
KraneXL
Foo
35
01-17-19 10:05 PM
GaIslander
Bicycle Mechanics
12
08-18-15 01:02 PM
jdon
Foo
22
07-15-14 09:48 AM
rumrunn6
Road Cycling
5
08-03-09 12:04 PM
invwnut
Road Cycling
4
01-20-09 12:03 AM
