Who makes the best road hubs?
#52
Half the "best" hubs mentioned have the drive side bearing close to drive side flange, like an old school freewheel hub. - Some even under or behind it. Imo thats a terrible design. For that reason i vote Dura ace.
Likes For Racing Dan:
#53
Quoted: 3241 Post(s)
Liked 2,512 Times
Doesn't it depend on how much noise they make?
#54
bike whisperer
Quoted: 1528 Post(s)
Liked 718 Times
Yesterday I churned out something like a thousand words leading to that conclusion, but the damn board ate my post because it had logged me out.
Cup and cone bearings, or at least adjustable preload on cartridge bearings, is compulsory for a decent hub, that eliminates a whole bunch of contenders. Include using the cassette body as a stressed member to put the drive side axle bearing next to the dropout, and you're left with Shimano or the likes of Joytech.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Likes For kansukee:
#56
Not a clue what the best hubs but:
I like my White Industries T11 Hubs. They are light and roll nice.When I needed to replace a bearing, they were very easy to service.
For affordable, long lasting, low maintenance, relatively light hubs that just work, its hard to beat Shimano Ultegra and 105
Edited to add: Because of my second point, if I was making my decision about hubs today, rather than T11 hubs, I probably would go with Dura Ace. At the time I bought the T11s, I wanted light, high end hubs that were different than what everyone around me was running (mostly Dura Ace). I have no complaints about the T11, but I have had to replace a couple of the bearing cartridges (although thats pretty easy to do), and Shimano hubs just work;, the cup and cone design is simple and effective, and Dura Ace is as good as it gets.
#57
Bikes: Cervelo Prodigy
Quoted: 478 Post(s)
Liked 87 Times
Chicago? I recall the "Pre-Uno's) days when the pizza joints had that thin crust, round pie, cut in squares. And that Italian sausage had that very sharp taste. I was trying to figure out what made that sausage so unique.
While in NY, Manhattan, there was this joint, Joe's on Carmine Street near NYU. That's the closest I ever got to that sausage flavor.
I tried to figure it out, thinking its the fennel that had been toasted before going in the casing sausage.
#60
#61
My point was more about Shimano cup and cone vs. cartridge hubs. I don't know why my White industry hub bearings failed (one in the front wheel, one in the rear over a period of about two years). I suspect some piece of grit worked its way passed the seals and jammed up one of the balls. I think that sort of thing is more common with cartridge bearings than with cup and cone.. At the end of the day, replacing two cartridges was cheap and it has been necessary at about the periodicity I would be repacking cup and cone bearings so the amount of effort required on maintenance is probably a wash. Also, a theoretical upside of the White and other cartridge hubs is that when a cartridge goes bad, I can replace it, but if enough grit gets into a Shimano hub the races could get damaged and that’s the end of the hub. So in that regard, one might argue over long term my White Hubs might be more durable because there are no races to get pitted that cant be replaced.. But race damage is not something I have experienced with any of my Shimano hubs, and my experience with them has been so positive, that I guess on balance I come out in favor of cup and cone for reliability and ease of serviceability over cartridge bearings. But I still love my T11s, which are lighter (slightly — at least that was the case when I bought them) than Dura Ace and very pretty.
Oh, and for Campy advocates, I have a set of 80s Record hubs on my Schwinn Paramount that spin like new and are beautiful. So, yay Campy, too.
#62
bike whisperer
Liked 718 Times
Do the T11s have steel strips to protect the no doubt aluminium splines?
Is the axle aluminum too? Wonder if you'd be able to get a replacement when it eventually fails from fatigue due to the bearing placement...
#63
The rear hub axle is cromo and the freehub body is titanium. The front hub axle is aluminum.
#64
bike whisperer
Liked 718 Times
Hmm, if the drive side axle bearing is three times the size of the NDS one, I might concede it's properly designed... Adjustable preload, too?
#65
Drive side has two 6902 (one in shell, one in freehub body separated by a thrust washer) and a 3802W (15x24x10). The latter can be replaced by 2 6802 bearings (15x24x5).
Preload is adjusted via an adjusting collar under the end cap that is held in place by three set screws. Instructions say to loosen end cap set screws and press adjusting collar to remove play, then tighten end cap set screws (see figure 23
https://0104.nccdn.net/1_5/30d/138/24...ADJUSTMENT.pdf)
#66
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times
Campy Bora Ultra ceramic Cult followed by DT Swiss 180
#67
bike whisperer
Liked 718 Times
NDS axle bearing is 6902=15x28x7).
#68
Well not exactly. There are identical 28mm OD 6902 bearings pressed into both NDS and drive side of the hub shell, then there is a third 6902 bearing in the interior side of the freehub body and a thrust washr creates sepration between it and the hub-shell bearing so both bearings spin freely.Without the washer the two bearing interfere with each other. The smaller 24mm OD bearings are in the exterior facing side of the freehub body. They are smaller in diameter but wider at 10mm. As for prelod, yes, one just presses the adjusting collar while tightening set screw. Seems less precise that a being able to make incremental adjustments via slight turn of a bolt or threaded cone as with a headset top cap or cup and cone hub, but so far I have not had any trouble with too much play.
#69
bike whisperer
Liked 718 Times
The bearings for the cassette body aren't what interest me; it's the axle bearings I'm asking about. So the drive side bearing isn't oversized, it's just the same as the one specced on the left. Right?
#71
Quoted: 1163 Post(s)
Liked 442 Times
Check out Gokiso high precision Japanese made hubs. They don’t appear to be sold outside of Japan and they most likely cost >$1,000 USD per set, but wow!
GOKISO Climber Hub
GOKISO Climber Hub
#72
But one point of clarification on freehub. The smaller fatter 3802W bearing (or two 6802s) are in the interior side of the freehub, adjacent to th drive-side axle bearing, not in the exterior side as I previously stated. A third 6902 bearing is in the exterior side of the freehub and visible when the cassette is removed.
#73
Likes For DOS:
