How to take out the freehub on Giant PR-2 wheel?
Old 01-26-20, 01:41 PM
Lidatation
I have a 2017 Giant Defy road bike stock wheelset (Giant PR-2, 12mm through-axle) where the rear drive side bearing got busted. I am having problems taking the freehub out so that I can reach the bearing.
My experience with older wheels was that there is a 12mm Allen opening inside the freehub so that I can unscrew it. But this one has no alllen internal. It is all round inside .
Any advice is appreciated! Thanks!
Lidatation is offline
Old 02-02-20, 02:07 AM
Lidatation
Bump.
Old 02-02-20, 02:16 AM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1789 Post(s)
Liked 1,266 Times in 873 Posts
Did you try a 10mm.
Try from the other side?
Bill Kapaun is online now
Old 02-02-20, 02:27 AM
Lidatation
Originally Posted by Bill Kapaun
Did you try a 10mm.
It is a 12mm through-axle so 10mm Allen will go right through. I tried 11/12/13/14mm but to no avail. It doesn't seem to have a hex that I can use Allen to turn.
Old 02-02-20, 02:54 AM
Bill Kapaun
So you answered 1 of 2 questions.
Old 02-02-20, 01:15 PM
bitpuddle
Bikes: Cinelli Nemo Tig / Battaglin Power Plus / Moots RCS
Quoted: 26 Post(s)
Liked 18 Times in 13 Posts
Those are a bit of a PITA. They loosen via a splined (not hex) socket from the non-drive side. You’d have to look at the service manual to be sure, but it is big (M13 or M14).
bitpuddle is offline
Old 02-11-20, 02:50 AM
Lidatation
Thanks Bill K and bitpuddle! Really appreciate your insight. Now I got it. I have to knock the non-drive side bearing out and used a 14mm hex (not the right tool but it kinda work) to loosen the splined socket.
These are Giant specific parts. I found replacement from a UK website selling these giant wheel parts. https://www.giantbikespares.com/Gian...detail/3-43273
looks like I have to spend nearly $70 for two bearings and a freehubs including shipping. Hmmm.... I have to think about that. these are basic wheels that I hate to dump any money on.
Old 12-04-20, 01:12 AM
didge1987
Lidatation, do you remember which direction you turned then hex key to loosen it? My freehub is on really tight and just trying to confirm the direction before I go all in trying to remove my freehub.
didge1987 is offline
Old 12-09-21, 12:17 PM
ColW
Fix it?
Did you manage to sort this? Did you have to remove just the none drive side bearing only?
also did the 14mm key work to remove the hub..
update..
i removed the non drive side bearing the inserted a 14mm hex and put a socket bar on it to extend the leverage etc I had to hit that with a hammer to get it free but once free came off in seconds and other one back on in no time, bearing in and good to go.
However after purchasing a new job this also is taking after 12 months!!!! They are ****… going have to try and find an alternative that can be serviced as these are a joke…
ColW is offline
Old 02-08-24, 05:27 AM
Haphod
Giant PR2 rear freehub
update..
I have a broken Giant Freehub on a Contend AR1 2021 and am having the same issues.
I've removed the brake disc rotor, the cone & locking nut and removed the axle.
A 14 mm hex will not fit inside from either drive or non drive side.
12 and 13mm hex keys go inside but don't engage the freehub.
How do you remove the non drive side bearing? Where/how do you hit this with a hammer?
Many thanks
Haphod is offline
Old 02-08-24, 05:50 AM
Trakhak
Trakhak's Avatar
Quoted: 2482 Post(s)
Liked 2,952 Times in 1,677 Posts
Many thanks
As he said, he had to use an extension on the Allen key to apply more leverage. When even that wasn't enough leverage to budge the freehub, he hit the end of the extension with a hammer, which finally got the freehub to begin unscrewing.
Use a flashlight to look inside the freehub body. Confirm that an Allen key is the tool needed. Then, if it does take an Allen key, insert the long part of each of your three Allen keys in succession, from the smallest up, until you find the size that fits.
My guess is that you might have to insert the long part of the correct Allen key (the part you usually use as the handle) to reach far enough into the freehub.
Once you identify the correct Allen key, you'll have to use an extension on it to get the leverage you need, especially if you had to insert the long part of the key. (I use whatever pipe-shaped object is closest, such as a seatpost, as the extension.)
Trakhak is offline
Old 02-08-24, 11:26 AM
Haphod
Thanks Trakhaq,
I've knocked out the non drive side bearing and the 14 mm Allen key now fits into the non-drive side an engages the splines inside the freehub body.
Which way do you turn it?
Haphod is offline
Old 02-08-24, 06:01 PM
Trakhak
Trakhak's Avatar
Thanks Trakhaq,
It's a right-hand thread, so loosen counter-clockwise. You might have to use a pipe or something to get enough leverage.
Trakhak is offline
Old 02-09-24, 01:29 AM
ColW
Good advice
That’s correct once the bearing was tapped out I inserted the hex key luckily mine was a long one so fitted but if short just use the other way. I then got some pipe etc to put on the end of it to get more leverage but as it was tight I had to hit a few times down in an anti clockwise direction I think it was as you working from the opposite side (but just look at the thread on the new one , east enough to work it out) then once free the rest too me probably 10 mins to complete… to get the bearing back in I just use a long bolt and a few washers on either side and tightened it up to use a a bearing press which works well 👌 job done
ColW is offline
